Question about Cameras
SONY DKC-C300X We are getting a line in all images and we have use there cleaner serval time what can we do now
I have a 91 s10 4x4 5 speed I just put a new master cylinder and line for fluid to run to slave cylinder an I have bled the line serval times without the truck started I put the truck in gear it just rolls...
you have to pressure bleed the air out
you do that by getting a friend to pump then hold down the pedal while you open the bleed screw
close of the screw and re-pump and hold down again repeat the operation until there are no bubbles
Dec 13, 2017 | Chevrolet S 10 Cars & Trucks
Ge upright freezer, like 1988 - model # says ca 21 dkc rwh
by the time you have fixed any faults,you might just as well buy a new(er)more effecient f/freezer.cost you less in the long run(got mine from a garage sale,owners were moving far away....)
Apr 06, 2010 | Freezers
Camcorder is display 3 large grey line horizontal
you may have a problem with the heads. try buying a head cleaner. you can buy them cheap online.
Jul 19, 2009 | E.Digital Sony DCR-TRV265E camcorder Pal
SONY KV-32TW67 FAINT GREEN AND RED LINES ACROSS WHOLE SCREEN
friend maybe your LCD was broken or loose. try to pull gently if it return to normal image.
Jun 30, 2009 | Sony KV-32TW67 TV
Screen shows blurry vertical lines instead of image
It is failure of ccd imager chip in your Sony DSC-T1 camera and Sony will repair it free of cost.
Click Sony CCD Imager Support for details.
May 20, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Lines appear across the photo when you print it
Try running the head cleaner function a couple of times.
That should solve your problem.
Feb 24, 2009 | Epson Stylus 1400 InkJet Photo Printer
Switches off after 3 to 4 secs--little bright screen hor line and small retrace lines
On the my sony website, they said try unplugging the set for 3 or 6 minutes. Then plug it directly to the wall. If that don't work, and it won't; seek a service center. I have the same problem.
Next time we better buy Panasonic. Sony products fail ALOT. I had a 5 disc DVD Changer and it was defective and it was part of a class action lawsuit,
I believe this is the same sort of problem.
The sony Vaio laptop computer gets consistent poor reviews.
I brought an alarm clock and its back up battery never worked right out of the box.
I brought a cordless phone and the LCD display went blank.
I am so DONE with Sony.
Good name; Bad products.
Aug 23, 2008 | Sony KV-24FV12 24" TV
Horizontal Green Lines!
Hi Tim
I've seen this many times. Only way to get rid of it is to replace the Mainboard.
This will get worse as time goes by.
Jan 17, 2007 | Sony VPL CS1 Multimedia Projector
D770 Mini Plug to IEEE 1394 Interface
Hi Paul, Sorry, but there is no firewire setup on the D770. There is a video output jack on the camera only. You will have to use big ATA or PCMCIA cards and plug them into the PCMCIA card slot. You can also use PCMCIA card adapters for MemoryStick, SmartMedia, and CompactFlash cards(CF). Those are your only options of media for the laptop or PC. The camera comes with a parallel port PCMCIA cardreader. It is reccommended to be used on your PC. Hope this info helps you out.
Sep 11, 2005 | Sony Cyber-Shot DSC-D770 Digital Camera
Cameras Logo
162 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
