Question about Acer Aspire Z5763 All-In-One 3D Desktop Pc Intel Core I5-2400 Processor, 4 Gb Ram, 1 Tb Hdd, Digital Tv Tuner, Blu-Ray, Windows 7 Home Premium With 23 Inch Full Hd Monitor
Blotchy picture My screen has split into two colours black and dark red. I have emailed acer about 3 times and had no answer.
  • 3,799 Answers
Plug in a different monitor. This will tell you if it is a graphics problem or a screen problem.
Posted on Jul 16, 2013
The dark areas of a picture is red
the screen itself is going bad and wearing out . there is no repair except replacement of the tv .
the screens are so expensive to buy there would be no point
sorry i could not bring you better news
Feb 02, 2016 | Sony BRAVIA KDL-40EX400 40" LCD TV
Can you fix the colours of the pictures on the screen of my Toshiba Satellite pro P300. It looks like the negative of a colour photograph. Light colours are dark and black is white. Red appears as blue...
In windows 7 , -
1 Go to the ease of access column in the control panel
2 Then go to the link "Turn on high contrast..."
3 Deselect it if it is selected
If it doesnt work then-
1 press Alt+Ctrl+Del
2 On the lower left corner their would be a button to Ease of Access
3 press it and deselect "Turn on high contrast "
This should work cause i tried it on my own computer
Mar 27, 2013 | Toshiba Satellite Computers & Internet
Fixing the picture in my Philips rear projection tv
As far as mostly red--turn color to zero and examine screen--if not gray or black and white it may need the screen controls adjusted.
Dark---with back cover off clean the three lens this model has--they are the light source for your picture and if dusty picture will be darker and somewhat dull looking.
Answer is based on brand/model number listed here.
May 16, 2012 | Philips 50P8341 50" Rear Projection...
The colour on my TV is a reddish colour. Have tried the colour adjustment. Skin colours in particular.
simple. easy. you have 3 screen adjustments. red green blue. turn color all the way down. you should then get just a black and white picture, but in your case, it will still be reddish. behind the speaker grill is an access panel for screen adjustment. remove speaker grill. remove access panel. you will see a block assembly roughly 6 inches square with 6 knobs on it. 3 are for screen, 3 are for focus. adjust until you have a black and white picture. then go into menu and turn your color back up. enjoy!
Nov 14, 2009 | Televison & Video
Elonex webbook displays anything black as red
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 08, 2009 | Computers & Internet
Screen has red dots all over the picture
its look like your lcd panel is getting break down. need to take to service.
May 19, 2009 | Acer AL1715 (Black, Silver) 17" LCD...
ATI RADEON X1650 -- Video degrades during vewing - becomes blotchy and red
welcome to fixya
the video card might not be getting enough power you should have a 500w power supply or higher with that video card if you have this already might want to see if you can download any new drivers for the video card
i hope this helps out have a good day
Jul 18, 2008 | ATI RADEON X1650 Graphic Card
Hitachi 32LD6600 - When the TV has been on for abot 30 minutes the colours start to go blue/red and the picture is distorted,noting I do gets the picture to display as normal.
Hi i have this tv and last night the screen went black i can hear sound ok but no picture just a black screen, Also i can see dark
outlines /shadows of whats on the tv, can you tell me please what has caused this
Mar 05, 2008 | Hitachi 26LD6600 26 in. HD-Ready LCD...
Red blotchy picture
try an AV memory reset in the tv menu. each input has different settings for picture options
Jan 30, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Try # 2... Green Fog
The green gun in your picture tube is set a little too high. If you are experienced in removing the back cover of TV's,etc., you may try to find the drive and/or bias controls either on the circuit board that plugs on to the neck of the picture tube or mounted on the main circuit board of your TV. These controls are usually labeled. If you can find them, locate the green bias or drive control and back it down a little while watching the picture through a mirror. A slight adjustment may correct your problem.tJIS IS CALLED GRAY SCALE ADJUSTMENT. BE CAREFUL THERE ARE SOME HIGH VOLTAGE CIRCUITS NEARBY. WORK WITH ONE HAND AND USE AN INSULATED TOOL TO MAKE ADJUSTMENTS I hope this may help you.AGAIN BE CAREFUL!! Stargazer
Feb 26, 2007 | Toshiba 32HFX71 32" TV
Acer Aspire Z5763 All-In-One 3D Desktop Pc Intel Core I5-2400 Processor, 4 Gb Ram, 1 Tb Hdd, Digital Tv Tuner, Blu-Ray, Windows 7 Home Premium With 23 Inch Full Hd Monitor Logo
70 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
