Question about Health & Beauty
My dad has a status xl6 mobility scooter and while on his travels it just gradually slowed down then stopped, when you press throttle or reverse it doesn't even try to move just bleeps until you turn it off then same again, I cannot see any obvious problems/ damage iv found 3 fuses they all seem to be ok not a great idea what I am looking at, any help or ideas much appreciated as se needs to be back on the move
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 346 Answers
Yes,there are set things to check & series of beeps etc mean certain things.This should help you get your dad back mobile.Download as a PDF File:SHOPRIDER SERVICE MANUAL 2007 1-800-743-0772 .Something to bear in mind,if you do anything on a scooter or wheelchair,then take it to a repair place.A lot will not touch it,so stay on top if you are taking the job on.Take a photo of everything you do on your mobile,then you can relay back to things.Also check when taking things apart,it can be easy to break a wire in the tilller mainly.I hope i have helped you.Colin
Posted on Jul 17, 2013
  • Adam swannick Dec 01, 2013
    Only just seen reply as my dad got better and hasn't been using it but has now been passed to my grandad so need it fixing I will look at the link, thanks
  • 177 Answers
SOURCE: 7 bleeps on my GO GO ELITE TRAVELLER SCOOTER
Hi. 7 beeps is fault code for a faulty speed potentiometer. Might also be a broken wire on the pot or a faulty connector. Most times, a new pot will fix the problem.
Good luck. Neil.
Posted on Jul 09, 2010
  • 50 Answers
SOURCE: I have an x-treme xb-420M
You said it
Most likley the throttle pot but can be the speed pot.
I would rplace them both.
Good Luck
Tim
Posted on May 03, 2011
ekcnoel
  • 998 Answers
SOURCE: HELP! hurricane scooter - model #PMV55001
If your battery is a year old should replace it a new one, When battery reach in a year the ampere rate is getting weak. And to prevent that you should always check the battery water level if your battery is a maintenance type. Feel free to send feed back best regards.
Posted on Jul 23, 2011
taran_2005
  • 10515 Answers
SOURCE: Pride Legend 3-wheel scooter. I
This problem can be caused by a faulty signal from the throttle lever to the processor due to an intermittent failure of the throttle lever or the temperature switch for the motor is showing an "over heat " condition & the processor shuts down the system , until the switch is cycled. This will need to be checked & tested by a technician to verify the problem for repair.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 24, 2011
gfreed100
  • 60 Answers
SOURCE: go go traveller mobility scooter lurches forward
That lever is attached to a pot. Pots have this nasty habit of oxidizing. You can either replace it or get some CRC QD Contact Cleaner. Wash it down trying to get as much cleaner into the pot as you can. These pots are normally not sealed find a little hole and spay it there. While your in the control head use the cleaner to clean anything you find in there. Stall having problems contact me.
Posted on Jun 02, 2012
My scooter won't start when it does it won't go in reverse whenever your going straight it won't slow down and stop you have to coast till it stops Judy Carter.
Judy,
You have a dangerous situation there, The throttle does not sound like it is attached very well to your lever. When you release the lever and the scooter keeps going! This is not safe. The throttle must be in the center of the throttle pots range. Most throttle pots are 5000 ohms. So the center is 2500 ohms or in neutral. The the throttle lever must be checked for cracks in the middle, which release the pressure of the setscrew on the pot shaft. also the return spring may be broken, which would cause a similar situation. Please check these things or get a tech on this before using this scooter again, for your safety and others safety. Scooter Doctor App
May 30, 2016 | Health & Beauty
My reverse goes faster than my forward what's wrong
Sounds like the throttle is connected backwards. The parking brake maybe hanging up. if the scooter is run for 10 mins forward, then carefully check with your hand that the parking brake is warm and not hot. Hot indicates brake slowing you down and making the motor work too hard. For other answers to Scooter Problems goto my free app.
Scooter Doctor App
Aug 07, 2015 | Elite Pride Go Go Traveller 3 Wheel
What battery fits a Status XL6 mobility scooter
Hello,shop around for prices on batteries and telling them the required distances you do should help in selecting what best suits you.Happy New Year,I hope my answer helped you.Colin
Jan 07, 2015 | Health & Beauty
Go Go Scooter travels in reverse, but when going forward it comes to an abrupt stop every few seconds. Everything else appears to work normally. Any ideas?
csr4 Well it could be the throttle pot or the speed control pot My leanings is toward the throttle pot since it works in reverse with the speed pot not being changed but not forward. when you are just changing the position of the throttle to forward thereby changing the pot wiper and getting the error. Contact Pride about the problem at 1-800-800-8586 and ask for Tech support for scooters and explain your problem to them. I hope this helps
Oct 02, 2010 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
I have a ctm scooter the battries are charged fully when i switch on the scooter will not work switch off and on again it then will travel a few feet before stopping
I would say the throttle pot is slightly out of neutral allowing the scooter to travel slightly when turned on. Try moving the throttle lever slightly in the opposite direction to which the scooter is travelling (i.e. if the scooter moves forward when turned on, press the lever to go backwards, but only a small amount). If the scooter stops and you hear a clicking noise from the back of the scooter (this would be the brake clicking on) then that would be your problem. Would just need a small adjustment but best left to a dealer as it has to be sopt on! Sometimes scooters will not work if the throttle is slightly out but if its only a very small amount out of neutral, it might sometimes work in the manner you have suggested. We have come accross this fault on a few occasions. Hope this helps...
Mar 07, 2010 | Health & Beauty
My pride go go elite scooter dies
it is either a bad throttle pot, or the set screw that holds the thumb forward/reverse paddle is loose causing the speed to slip, allen wrench to tighten if setscrew is problem
Apr 17, 2009 | Elite Pride Go Go Traveller 3 Wheel
Golden companion 2 scooter moves slow in reverse
i would suggest there is either a loose connection or the speed control has failed, the scooter will still run but at a slow speed, the part is fairly standard in all scooters. if i can be any furthur assitance please email me rick @ lxrixta.co.uk (remove the spaces)
Mar 23, 2009 | Golden Technologies Companion II Travel...
Health & Beauty Logo
182 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
Jeff Tilburn
Jeff Tilburn
Are you a Health and Beauty Expert? Answer questions, earn points and help others
