Question about ASUS P5E-VM HDMI Motherboard
Asus P5E-VM HDMI motherboard: PC was working and all of sudden starting giving an error of keyboard and cpu fan. Later, it stop even loading the BIOS screen. When turn PC on there is no beep but CPU fan runs and DVD etc. eject. Please HELP me. I did reset CMOS but no luck. Is there any way to fix it. Thx in advance.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • ASUS Master
  • 2,226 Answers
Sounds like the board is going or heatsink fan go for the fan first
Posted on May 23, 2014
Panth3on
  • 71 Answers
SOURCE: No any display in the monitor, no beep of the RAM while CPU fan is running
Check your power supply. It sounds like you have a bad power supply. Even though the computer powers up, it does not mean that it's good. I have had this problem before, and almost 9 out of 10 times the power supply had gone bad. Just try a different one and see. hope this helps you.
Posted on Oct 01, 2007
yalmer
  • 549 Answers
SOURCE: motherboard problem
If your cpu fan is faster,it may be due to a higher frequency setting.
The frequency that it runs best at is 60 hz, but it can be running at 70 hz or higher.
Posted on Jun 14, 2008
SOURCE: asus p5p800s
i had the same problem, and was the motherboard something burned next to the chipset
Posted on Nov 09, 2008
rtrahan
  • 741 Answers
SOURCE: ASUS P5GD1-VM motherboard not booting when powered on
First are you sure it is the CPU fan and not the Power Supply fan? Open up the case and make sure the power supply cable is snug into the slot. Make sure that Pin 1 is lined up with Pin 1 on the motherboard. There should be a notch or red dot or different looking Pin to show you where pin 1 is...sounds like it may be a connection problem from power supply to motherboard...try that and let me know what happens we have other options but have to start somewhere..
Posted on Mar 06, 2009
SOURCE: Asus P5Q-VM CANT BOOT
CPU Should work with board.Try removing cpu and replace in socket check for bent pins if all is well..reinstall.make sure to use pad or silver paste and reinstall fan.rebootRichardm69
Posted on May 05, 2009
TIme and Date not update when system restart of
This problem is caused by a flat BIOS battery. Replace this battery with a new battery.
May 10, 2013 | ASUSTeK P5E-VM DO GREEN P5E-VM DO Desktop...
Good morning sir i have not lan driver in my motherboard cd because my motherboard has been changed by hcl service centre.plz give me solution. thanks my motherboard model no( asus-p5e-vm)
Access the ASUS web-site.
Select MOTHERBOARD.
Select ASUS-P5E-VM.
Select DRIVERS.
Select NIC or LAN.
Download via a computer that *does* have Internet access.
Copy the downloaded-file to a USB memory-stick.
Move the USB memory-stick to your computer.
Install from the USB memory-stick.
Oct 27, 2009 | ASUS P5PE-VM Motherboard
WHAT FOR??
its probably the cmos clear but it could be something as obscure as power-on-by-keyboard.
May 02, 2009 | ASUSTeK P5E-VM DO GREEN P5E-VM DO Desktop...
Intel cpu loading error
You will get better, quicker sensible help if you describe your peroblem better. There is all the typing space and time.
CPUs need proper voltage and clocking timing. What type of loading is that?
Mar 02, 2008 | ASUSTeK P5E-VM DO GREEN P5E-VM DO Desktop...
Motherboard related problem
you need to update your bios for the later stepping proceesors from asus, download to a floppy disc and insert before you start up your system http://support.asus.com/download/download.aspx?SLanguage=en-us
Jun 14, 2007 | ASUS P5PE-VM Motherboard
Open Questions:
See all ASUS P5E-VM HDMI Motherboard Questions
ASUS P5E-VM HDMI Motherboard Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
