Question about Orion Televison & Video
How to hook up speakers to tv - Orion Televison & Video
Hook mz506 surround sound to my Samsung tv
Typically surround sound is run through a receiver or stereo. The sound from the tv is carried to the receiver by cables (hdmi or Audio-Video connected to input area of receiver). Then the speakers are connected to the output area of the receiver.
If you are not using a receiver, then the speakers must be able to connect directly to the tv and you have to see what kind of cabling your tv supports.
Jan 27, 2015 | Logitech X-540 Multimedia Surround Sound...
How do i hook them up to my tv
yes you can hook up computer speater speakers with tv just what you have to do buy this cable shown in below picture. rcamini.jpg
the red and black (RCA CONNECTORS ) goes to TV for RIGHT AND LEFT... and stereo pin goes to your speaker.
Dec 26, 2010 | Creative Labs Inspire P7800 Computer...
I have a 5.1 speaker setup. i have a 5.1 sony dvd amp. a ps3 and a old toshiba tv. ( the one with the orange white red plug in the back. i wanna hook up 3 speakers for front and the subwofer. how do i do...
So, you don't want to use the TV speakers, right? Hook your PS3 audio output RCA jacks to the input on the amplifier and hook the PS3 video cabe to the yellow (orange) video input of the TV. Then hook your speakers to the front or rear outputs of the amp and the sub to the sub output of the amp. If you want to use your TV speakers, you can connect them to the front or back output of the amp for a 4.1 setup. OK?
Dec 09, 2010 | Toshiba Toahiba Satellite A60 A65 Series...
When plugged into my tv they are not very loud, why please
Probably because your TV does not have a built in speaker amplifier. You'll need to hook up a small amplifier to your speakers. Hook up audio cables to the TV AUDIO OUTPUT and then to the INPUT of the amplifier. Hook the speakers up to the AUDIO OUT or SPEAKERS OUT on the amplifier. Probaly have to take a trip to a place like Radio Shack to get the correct cables.... Good Luck.
Nov 22, 2009 | Harman Kardon Harmon Kardon SoundStick II...
I'm trying to hook up a 5-speaker Dolby surround
out of tv, into the combo, out of the combo into the surround amp and this work
Sep 01, 2009 | Televison & Video
Need a diagram to hook my Bose CinemaT speakers. When I hook it directly to the tv no problem but can't figure out how to hookup my reciever and CD player to work also? Help Please
You'd be better off hooking the speakers to the RECEIVER'S speaker outputs, THEN hooking your TV audio output to an unused receiver input, such as AUX. The signals from your receiver cannot reach the TV; thus your CD player and radio will not play through the speakers if the speakers are hooked to the TV. All receiver INPUTS are designed to accept the same signal level; thus, you can use any input for your TV audio, such as Aux, DVD, CD, etc. Just remember which input you're using for the TV audio, and everything should work fine. Almost all receivers have an AUX input; hopefully yours also has a dedicated CD input to avoid confusion. The you simply select the AUX input to hear your TV through the speakers.
Dec 26, 2008 | Bose Cinemate Digital Home Theater System...
Want to add an external speaker to TV
If you have audio out RCA jacks then you can hook up some computer speakers that have RCA jack inputs. If you don't have audio outputs and your TV has a HOT chassis then you won't be able to do it. If your tv has a switching power supply then you can install a jack to TV speakers, so they disconect when you hook up your other speakers, if you try and hook up speaker to the TV speakers then the impedence will change, and your audio output IC will get hot and short out.
Oct 26, 2008 | Televison & Video
How to hook up additional speakers to the TV
If you have a surround sound system, (amplifier and speakers), run the DVD speakers out wires to the amplifier IN. Thi way, you don't even need the TV speakers.
Jul 26, 2008 | Sansui HDLCD3200 TV
HOW DO I HOOK IT UP TO MY NEW RCA FLATSCREEN TV?
how do you hook up x-530 speakers to a samsung tv
Jun 01, 2008 | Logitech X-530 Computer Speakers
Televison & Video Logo
12 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
