Question about Canon PIXMA iP1600 Printer
Paper Jam Error
Canon PIXMA ip1600 everytime I try to print a picture or anything the right corner goes down first paper goes crooked and it gives me a Paper Jam Error... I just got this thing and it has been doing it since I got it... since it was on clereance they won't take it back...
  • 2 more comments
  • Anonymous Nov 04, 2007
    Canon PIXMA ip1600 everytime I try to print anything the right corner goes down first paper goes crooked and it gives me a Paper Jam Error...Please Help
  • lekc89 Nov 10, 2007
    When I try and print something the right hand corror just goes in and then it says that the paper isn't in right when it is
  • Anonymous Nov 14, 2007
    right corner of paper goes down but the rest of the sheet does not get grabbed. Then I get a paper jam error and it still doesn work when I follow all of the error intructions.
  • earthangel Nov 26, 2007
    When I go to print, the rightside pulls down only and I get a paper jam error. This happened after I printed an envelolpe
    Problem Solver:
  • 11 Answers
Just clean and observe yaar , I dont have more knowledge , In my knowledge i am telling , just clean your printer and see yaar ,
Posted on Aug 28, 2007
Will not print paper jam light comes on
if the printer take in one side of the paper and then stop or jam, then most probably something, small item was caught or trapped in between the roller or wheel
Feb 23, 2012 | Canon PIXMA iP1600 Printer
My cannon pixma ip 1600 keeps giving an error
Hello there
You may not see a paper jam, so this is worth trying.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 25, 2010 | Canon PIXMA iP1600 Printer
Describe your Canon PIXMA iP1600 Printer Problem
Hi You can Try 2 things.
ERROR 5100 means that there is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Mar 16, 2010 | Canon PIXMA iP1600 Printer
Every time I try to print I get a paper jam.The paper starts loading but then goes crooked and gets stuck. Error 3 comes up on the display.
sounds like one roller is pulling more than the other, which is why it starts going crooked. You may have to replace the roller, or the entire feed assembly. not sure which.
you could also try cleaning the rollers with alcohol, ... see if that gives them a little more grip.
Sep 24, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Skewed or crooked paper uptake on Canon Pixma Mx300
Sounds like the roller(s) on the left side is missing or is slick (or split). You should have returned it to the place of purchase when you discovered the problem.
Jul 09, 2009 | Canon PIXMA MP470 All-in-One Printer
Canon Pixma iP1600 Printer problem
this is the service error download canon chip resetter utility, then reset your printer , download IP resetter utility
Nov 14, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
sure..disconnect printer from computer and then try a test page from printer stand alone
Aug 19, 2008 | Canon PIXMA iP1600 Printer
'Paper jam msg' when there's nothing stuck in there...???
Sorry can't help. Maybe you have damaged one of the paper jam sensors?
Try the link below which is the manual
http://alpha03.c-wss.com/inc/ApplServlet?SV=WWUCA900
Dec 29, 2007 | Canon PIXMA iP1600 Printer
Paper jam
Just for sharing,
Yesterday i got same phenomenom. After i check , i found the root couse came from, printer head (PG-40) is hit foreign part in the left side when printer is initialize. So the home posistion of head become shift to right. So when the head move to right in parking area, become hit stopper of waste ink platen, that impact to mechanism of paper feeder.
After the foreign part is removed, my printer can work normally.
Sep 26, 2007 | Canon PIXMA iP1600 Printer
Paper Jam Error
Hello there
You may not see a paper jam.
Apr 14, 2007 | Canon PIXMA iP1600 Printer
Canon PIXMA iP1600 Printer Logo
378 people viewed this question
old marine
old marine
