Question about Yamaha 12V Air Pump
Yamaha xlt 1200 oil leaking into hull
I have alot of oil leaking.I have checked all the lines connecting to the oil pump tank and carburators.It all seems to be coming from the airbox!
3 Suggested Answers
finish line
  • 207 Answers
SOURCE: Overheating YAMAHA XLT 1200 jet ski
you may have something clogged in a water passage but more than likley u have a bad sensor the sensor is located on the main exhuast if you go on the right side of the ski and look in the engine compartment it will be located at 9 oclock u will see it sticking out of the exhuast with one wire comming out after u run the ski and the buzzer goes off pull the seat and see if the engine is really hot if u can not touch it will be hot but it has to be very hot for the sensor to pick it up if u can touch the motor and exhuast it is a bad sensor
Posted on Jul 08, 2009
finish line
  • 207 Answers
SOURCE: 2001 Yamaha 1200 XLT seems to have engine locked up
you can take the whole pump *** out from the back of the ski you will see the main bolts at 2,5,8 and 11 oclock there are two sets of them one on the nozzle and a set on the pump take all of the steering cable bolts out first and the reverse cable as well once you get the nozzle off the pump assembly will come out complete that way u can find out if it is a impellar bearing seized that will lock your whole motor if you need a break down go to riva yamaha and go to origanal parts finde4r and pick your ski it will help
Posted on Jul 09, 2009
My 95 yamaha waverunner 3 will crank but won't stay ctanked what's going on?
check connections clean and no breaks in wires , check solinoid and starter in good order !
Jun 22, 2013 | Covercraft Personal Watercraft Cover -...
97 yamaha yz250 excessive oil in exhaust keeps fouling plug
Hi, Anonymous and the usual suspects are:
1. Oil tank/pan overfilled.
2. Restricted oil return line to oil tank/pan.
3. Restricted breather operation.
4. Restricted oil filter.
5. Piston rings badly worn or broken.
6. Valve guides worn and or seals worn, crushed, missing, or have come of guide and are literally pumping oil through the valve guide.
7. O-ring damaged or missing from oil pump at crankcase junction (also results in poor engine performance). For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Dirt Rider Magazine
YZ250 spark plug fouled after every half tank
YAMAHA YZ250 LC Owner Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
May 25, 2012 | Yamaha YZ 250 Motorcycles
2002 sportster wont spray gas to the carb sometimes
Hi Anonymous, if you have a carburator the usual suspects are:
1. Damaged or restricted fuel tank venting system (gas cap).
2. Inlet system air leak.
3. Vacuum piston malfunction.
4. Accelerator pump leaking or no output.
5. Plugged bowl vent.
6. Fuel level (float chamber) too low.
7. Restriccted fuel supply passages.
8. Plugged jets or passages.
9. Worn or damaged needle or needle jet.
10. Enrichner valve not seated or leaking.
Good luck
Apr 02, 2012 | 2002 Harley Davidson XL 1200 C Sportster...
Cavataion with my 800 yamaha waverunner will not get up on plane
check hull type as a freshwater hull and a sea hull are different as sea water has a higher level of buoncy .Although i doubt if you will encounter a freshwater hull but it is a thing to think about and check.Main cause though could be lack of engine power for whater reason .
Oct 24, 2011 | Yamaha 12V Air Pump
Adjustment on oil injection on xl 800
There is no adjustment on the oil pump it is a steady direct drive/flow system. If the oil pump is not working correctly you have two options. One is to replace it for around $400. The other is to remove the pump, cover the opening with an aluminum plate, and pre-mix your oil and gas at a 50:1 mixture.
Jul 21, 2011 | Covercraft Personal Watercraft Cover -...
What steps do I take to get a Yamaha EF1000 gas powered electric generator going again after it has been sitting around for years with gas in the tank? How do I drain the gas from the tank and carburater?...
You can disconnect the fuel line from the carb and drain the gas. It would be even better to then remove the fuel tank. If this is the generator with the large plastic tank, quite often the rubber gromet in the bottom of the tank with shout off vavle in it will deteriorate into a black gooey mess, and leak. If so that will have to be replaced. Clean inside of tank with fresh gasoline. Remove bowl from carburator and clean throughly. If you know how to work on engines, remove the carburator and clean throughly, notice how all springs and linkage were connected before removeal. Be sure all passage ways in carb are clean. Always use sta-bill in your gas.
Jul 23, 2010 | Yamaha Electrical Supplies
Gas not getting to the carburator. Starter turns
Check all of the fuel lines very carefully for breaks or cracks in the fuel lines, especially between the fuel tank and the fuel pump.
If the fuel lines are all in good condition then you can safely assume that the problem is in the fuel pump and you will need to replace it. (If the fuel pump is in really bad shape the engine oil on the end of the engine oil dip-stick will smell like fuel)
May 13, 2010 | 1986 Dodge D150
Fuel problem
Hi. you may have two issues here. you may want to check the fuel pump o ring for lose or worn fit. i would also do a line check from the tank all the way to the engine. make sure your lines are ok. if all checks out, this may be isolated within the tank hull. replace the fuel tank if a leak is present.
May 21, 2009 | 1987 Alfa Romeo Graduate
Yamaha 12V Air Pump Logo
93 people viewed this question
Top Yamaha Water Sport Experts
Colin Stickland
Colin Stickland
Piyal Perera
Piyal Perera
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
