Question about Vizio VP42-20A 42 in. Plasma TV
Television screen flickers when bathroom fan is turned off?
Well, I bought this television and it would not turn on. Capacitors where blown and I replaced the power board. Works great. When bathroom fan is shutoff the screen turns off for about a second or two. Something tells me this is very bad. Is this why the board blew in the first place? Will this cause it again? Should I get something like a backup battery or something to provide a clean steady current, since the television apparently is not.
    Top Expert:
  • Vizio Master
  • 38,003 Answers
If the bathroom fan and your TV are on the same circuit, it is likely that the problem will continue
Posted on Jul 16, 2013
  • Jeremiah Dawson Jul 16, 2013
    well I was just shocked by the TV slightly. and the screen flickered. I think there's a grounding problem. would that be accurate?
Tv comes on as it should, but picture and sound both go out after a few minutes. Then it comes back on after a minute or so. This continually happens and there are no blinking lights. Help
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
Apr 08, 2014 | Sony KDF-E55A20 55 in. LCD Television
Samsung plasma tv ps42c7hdx flickering lines
Yes, yes, yes. Change all bulgy, puffy capacitors by exactly the same value and voltage. Look for any excessive voltages in these areas where you find such capacitors. But replace capacitors only one by one. Never remove all of them together, as you are likely to misplace the capacitors, creating more problems. Also look for any loose contacts and dry solders.
Aug 04, 2012 | Samsung PS-42C7HD 42 in. HD-Ready Plasma...
Does not Turn On
You will have to remove the back cover, they are a few screws to undo, once undone gently prise the back cover off. You are looking for the power board, if unsure just follow where the cable plugs into the back of the tv. Check for any signs of blown componants on the board, the main culpruts are the capscitors, they are barrel like in shape with silver tops, if you see any dark liquid resadue on or around them they are blown and need to be replaced, also check the tops of the capacitors, if they are slightly domed or pretruding they also need to be changed.
Check the board for any fuses, there should be at least one on the board, if you have or can get hold of a continuity tester, test the the fuse, if it has blown you can get them from your local appliance repair shop or stores like maplins, or online electronic stores, the same with the capacitors. hope this helps and post back if you require further assistance.
Feb 12, 2010 | TruTech PLV1615T 15 in. LCD Television
The screen flickers
The backlight inverter board may be going bad or the power supply problem. Look for bad capacitors.
http://en.wikipedia.org/wiki/Capacitor_plague
Nov 10, 2009 | Polaroid LCD-1700 17 in. Television
Samsunb 4051: TV screen turns off sound stays on.
Most likely this set has an "integrated" inverter, as most samsungs do--and this DOES sound like an inverter problem. Make SURE thought, there are no more bad "10 volt" caps on the power supply...ALL of them need to be replaced no matter HOW they look.
Oct 15, 2009 | Samsung LN-S4051D 40 in. LCD Television
Tv doesn't turn on
power pack probably has blown capacitors on it. need replacement of those and the tv should be fine.
Apr 03, 2009 | Akai LCT2715 27 in. LCD Television
TV will power up
sounds like a bad power pack, blown capacitors most likely.
it can be replaced or the caps can be soldered into the board to replace the bad ones.
Mar 29, 2009 | Akai LCT2715 27 in. LCD Television
Television turns on and immediately turns off
it costs $2.50 to fix its 2 capacitors in the motherboard need to change them very easy i just fixed mine took me an hour all together and less then 3 bucks .if you open the tv look in the middle motherboard and you will see witch capacitors are blown because the top of them is raised up change them and ure done,all the capacitors have a cross scored in the top ,so they dont blowup ,so if you see 1 raised just a little bit its fried change it while ure in there , they wanted $400 to $500 to fix lmao now .
Jan 18, 2009 | Philips 42PF9431D/37 TV
Flickering t.v.
There are bad capacitors in the power supplky and or the PIP board. if you have no solid state repair experience, call in a pro to assist you in this repair. Good Luck
Apr 07, 2007 | Mitsubishi VS-45605 50" Rear Projection...
Vizio VP42-20A 42 in. Plasma TV Logo
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
