Question about Water Sport
Yamaha waverunner oil in airbox
I have oil running into the hull checked all oil lines and they are fine,seems to all be coming from inside airbox
finish line
  • 207 Answers
SOURCE: My 2005 Yamaha FX HO Waverunner runs smoothly, but
yes yes yes the new yamahas foul plugs like crazy i dont know if it is a valve defect or what but you will be changing them every year one trick i have been doing to my coustmers watercraft and has been working well insead of ngk cr9eb plugs use a cr8eb it is a hotter plug there for it will burn better and no it will not hurt your ski trust me i have over 15 yrs ex and 6 in r&d research and design
Posted on Jul 08, 2009
finish line
  • 207 Answers
SOURCE: 2006 yamaha waverunner wont idle
what is it idle at? how much? remove your seat check air filter if is black oily remove it and see if that fixes your problem you may want to change your spark plugs as well # one cylinder may be starting to foul the new yamahas are the worst for fouling plugs use a cr8eb instead of the cr9eb the 8s are hotter and work better try those and let me know thank you
Posted on Jul 09, 2009
SOURCE: 1997 yamaha waverunner 3
My 97 gp760 did this. I checked almost everything. Replace or clean your plugs, then run carb cleaner through your fuel filter both ways, and then spray carb cleaner into the fuel line from the fuel filter to the carbs. Run 10 minutes, more carb cleaner into the fuel line, and run it 15 more minutes. Then zip tie fuel lines at the fuel filter. I figure there was trash or buildup in the carb. Its easier than rebuilding the carb. Try it. Daniel at the MEXPIPE Pto Escondido Oaxaca.
Posted on Jul 27, 2009
SOURCE: excessive smoke coming from waverunner exhaust
is their a trick to putting on exhaust 1998 waverunner xl 1200?
Posted on Aug 23, 2009
SOURCE: 1994 Yamaha Waverunner 3 will idle but wont take throttle
Switch to reserve tanke to check to see if there is a clog at the fuel pickup in the tank.
My friend had the same issue with his waverunner 3.
Posted on Aug 31, 2009
What is the size and year model of my yamaha waverunner the hull id # yama31321394
Yamaha did not make the GP model until 97 and if the numbers you posted are correct you have a 94, that being said all yamahas up until 93 were either a 500 or a 650 so im guessing its not a superjet which is a standup so you may have a waverunner 3, Raider, Blaster, or a wave runner LX. What colors are on it? does it have twin carbs? there will also be a sticker on the engine cases noting engine size.
May 29, 2014 | Yamaha Boating
Oil in airbox
Hi, Anonymous oil leaking from your air cleaner is caused by oil carryover from the engine. For whatever reason, the breather system is not separating enough oil mist and air from the piston downstroke. There are cheap and quick easy fixes and there are more expensive ones. First, make sure your breather hoses are not dry and cracked if they are ok you can start by trying the following:
1. Run your oil level half way between the add and full mark when hot.
2. Run oil breather lines from the head into a TEE fitting below carb/induction module then a single line into a mini filter under the frame.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Oil Dripping Out Of Airbox Workshop Help
Re help oil dripping from air filter Road Star Forum Yamaha Road Star
1999 2003 Yamaha XJR1300 Service Manual Moto Data Project
OEM parts for Yamaha
http://www.yamaha-xjr.cz/download/owners_manual_2001.pdf
May 20, 2014 | 2002 Yamaha XJR 1300
I have a 2009 Yamaha VX Cruiser waverunner there is a very strong gasoline odor when I lift the seat to check the oil or do other maintenance I'm wondering if this is normal, I bought it used it only has...
check all fuel lines are in good condition , check fuel tank pipes etc ! run on a hose ( start engine first ) and look round for leaks ! water off then stop engine ! P...
Oct 28, 2013 | Yamaha 2009 WaveRunner VX Cruiser
Yamaha waverunner
check for corrosion of the engine as leaving it for long any water left in the system will cause problems.
May 26, 2013 | Yamaha XL700Z Waverunner
Got my 2009 Yamaha FX sho waverunner under water, drained the water from the hull and tried to start it. Turned over 5 or 6 times and stopped. Pulled the air filter out and of course had water in it....
remove all sparkplugs and hold full throttle and crank over several times to get water out of cylinders ! have a jump pack ready as battery will die ! use carb cleaner on the plugs each time you try to run after this , hope this has only just happened as internal damage might already started ! if all ok check the engine oil also as water normally gets in after this problem ! if oil is milky then change oil several times , run for 15min on hose each change until oil normal colour ! then you must take for a run for an hour to help dry it out !
Mar 19, 2013 | Yamaha 2009 WaveRunner FX Cruiser SHO
Warning and oil lights come on at 6000rpm
check wire connections are clean and check the oil sencer !
Jul 05, 2012 | Yamaha Boating
Cavataion with my 800 yamaha waverunner will not get up on plane
check hull type as a freshwater hull and a sea hull are different as sea water has a higher level of buoncy .Although i doubt if you will encounter a freshwater hull but it is a thing to think about and check.Main cause though could be lack of engine power for whater reason .
Oct 24, 2011 | Yamaha 12V Air Pump
Water Sport Logo
29 people viewed this question
Top Water Sport Experts
Bill Boyd
Tom Chichester
Are you a Water Sport Expert? Answer questions, earn points and help others
