Question about Mitsubishi WS-55807 TV
Can't display 1080i from DTV
Just hooked up with Verizon Fios HD. Connected at the DTV area in back of tv that says it displays in 1080, but its not working. Any ideas??? Help
    Champion:
  • 317 Answers
You may have to go to setup and turn on this setting
Posted on Sep 11, 2007
SOURCE:
How do i get 1080i, my tv shows im only in 480i. i think i might have it hooked up incorrect. my other tv of another brand is much newer so all i did was connect the hdmi cable from the tv to the cable box...
Hello
Your TV will display all High Definition signals as 1080i True HDTV™ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
YPbPr(480i/480p/1080i)
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
InputDTV
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Ok.
Feb 05, 2011 | Mitsubishi WS-73909 73" Rear Projection...
I am attempting to connect a Verizon Fios QIP6200-2 HD set top box to my Mitsubishi WT-46805 HD TV using the Y, Pr and Pb RCA connections (no HDMI port on TV) I cannot get any HD channels to work.
The set will have two component inputs, one is NOT HD.
You want to connect to the DTV input which if you look from the back will be marked 480/1080 I .
Also double check the connections to be sure blue-red-red and green to green.
SD TECH
Aug 18, 2010 | Mitsubishi WT-46805 46" Rear Projection...
If we have an hd-ready television and we have dishnetwork hd does their box make our tv hd? Or do we have to have their magical piece of equipment to make our television hd?or tv is the WS-55315 model.
You need a HD box connected to the DTV input on the back of the set (it is marked 1080) This set has only one HD input for this---HD ready means it will work only with a box (some newer sets have a HD tuner built into them and for basic HD channels do not need a box).
SD TECH
Jul 11, 2010 | Mitsubishi WS-55315 55" Rear Projection...
HDTV goes blank when connected to Fios HD-DVR or Fios DTV recvr.
If you can first connect the Fios box via component and that will rectify the issue and still allow HD. HDMI is funny, if there is anykind of communication issues between the TV or the Fios box you see what happens. You might also call Samsung to see if there is ANY firmware/software updated for your TV specifically to fix such an issue with the Fios/Mortorola connection. If there isn't then the issue is the cable box since the TV works ok on HDMI with other devices.
Jul 23, 2009 | Televison & Video
Mitsubishi WS-65711 HDTV
The Verizon installer did not set the reciever to 1080i, had to set reciever to 1080i and then push 3 buttons in order on the reciever to take me to the nonstandard menu to check a box so that all channels without 1080 would automatically fill the screen.
Jun 28, 2008 | Mitsubishi WS-55809 55" Rear Projection...
JVC TV crisis.....HELP
yes... i actually work at verizon the tv is to old for fios because fios is so advanced we run off ot 720 to 1080 depending on areas. what kind of box is it? is it the hd box or stb>
Feb 13, 2008 | JVC AV-32230 32" TV
Converting up to 1080
Hello. You have to use the HDMI port and connect to the HDMI, or DVI, port on the back of the TV to get 1080. Even if playing HDDVD, this cable is necessary to get the increase. That, and the TV has to be in 1080 too. If you look at the display, on the front of the player, while watching the DVD, it will tell you at what resolution the DVD is playing. The HDMI to HDMI/DVI must be installed to get the increase in resolution. I have a Panasonic HD 34" 1080i widescreen TV, with DVI connection. When connected, the player played my DVD's at 1080i on my TV, while at only 480i thru the composite cables.
On some older movies or series(I like Star Trek- TNG), it doesn't work well due to the transfer to the DVD. Most newer DVD's, such as Batman Begins (there is an HD out, but I have DVD only), improved on the upconvert for me nicely.
Jan 21, 2008 | Toshiba HD-A30 HD-DVD Player
Can you connect to upconversion DVD Player for HDMI performance
The TV supports 1080i so if your hardware is plugged into the Component Cable Connection for Digital TV on the back the signal will come out 1080i as long as the hardware supports the size.
For example, my 360 is connected like this and when the dvd player is in use it upscales from the 480 format dvds use to 1080. More on the HD-DVD for the 360 and how it handles the sizes here:
http://www.engadgethd.com/2006/09/21/xbox-360-hd-dvd-playback-maximum-1080i-via-component-1080p-vga/
Kind of an old article since the newer 360s have hdmi and support 1080p that route.
Hopefully this helps.
Dec 16, 2007 | Mitsubishi WS-65807 65" Rear Projection...
"Not supported Mode" message
Hook up the component cables on the tv and the dtv box
go to set up on the menu select HDTV or display and deselect all of the 480i and 480p and in some cases also the 720 and only select 1080i to be display. you can then hook up your hdmi cable again and it shoud be supported. Let me know if that works.
Nov 18, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Mitsubishi ws-55809
Looks like you are going to be working with the following:
1080i (HDTV) • 480p (EDTV) • 480i (SDTV)
Hook up depends on what else you have connected to the TV.  If you have nothing connected to the DTV component inputs, I suggest using those, as it will allow up to 1080i.  Otherwise, use the 2 other component connections directly to the left of the DTV connections.
Oct 19, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55807 TV Logo
137 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
