Question about Nextbook Tablets & eReaders
Screen wont rotate on nextbook - Nextbook Tablets & eReaders
My ipad is cracked inside it wont slide to let me unlock it
Rotate the tablet so you can use a different part of the screen to unlock it.
Sep 30, 2015 | Nextbook Tablets & eReaders
I WANT SCREEN TO ROATE?
1. Go to your desktop on the nextbook.
2. Tap on the screen and hold for 2 seconds, then remove your finger then a list of choices will appear.
3. Choose screen resolution, it's the second last choice, choose it, it will open another page where you will find the box to check that allows the screen to auto rotate!
Jan 17, 2015 | Nextbook Tablets & eReaders
HOW CAN i GET SCREEN TO ROTATE?
3. Choose screen resolution, it's the second last choice, choose it, it will open another page where you will find the box to check that allows the screen to auto rotate and enjoy!
Jan 17, 2015 | Tablets & eReaders
Rotate screen
In your Settings menu .
(Probably looks like a large cog ) .
Look for Screen and it should be a tick box for it to rotate when moved.
Jan 02, 2015 | Nextbook Premium 8 Se Android
Auto rotate does not work on my Nextbook 8. Why?
Go into the settings, go to display and make sure the Auto-rotate screen button is checked off. I hope this fixes this issue for you.
Dec 31, 2014 | Nextbook Premium 8 Se Android
My next book tablet won't rotate back to its right place, how do I get it back to normal?
I'm assuming that the Nextbook uses an android OS for this answer. On the drop down menu that appears when you "pull down" the top right corner of the screen there should be a "rotation lock" button if it's on then turn it off, if it is off then there may be something wrong with the position sensor in the tablet.
Nov 22, 2014 | Nextbook Tablets & eReaders
My nextbook display is upside down,,,the power button and camra is at the bottom
If the auto rotate system is on it will switch the controls so try restarting it and then if it still does that go the the programs settings and see if u can fix it.
Jan 20, 2014 | Nextbook NEXT2 Touch Screen Android Tablet
Screen display upside down
I think you should go to the settings and make sure rotate is not turned off. Also, try to calibrate your screen again.
Jan 20, 2014 | Nextbook Tablets & eReaders
Tablets & eReaders Logo
1,106 people viewed this question
Top Nextbook Tablets & eReaders Experts
bigdawg7299
Beej West
Level 1 Expert
Are you a Nextbook Tablet and eReader Expert? Answer questions, earn points and help others
