Question about Panasonic KX-MB781 All-In-One Laser Printer
Replace drum change supplies - Panasonic KX-MB781 All-In-One Laser Printer
How do i change the color of riso drUm from red to burgundy?
How-to: Convert Z-type Color Drums ' stencil.wiki
stencil.wiki/how-convert-z-type-color-drums Procedure for converting the color of a Z-type drum. Steps 1 - 9 also work ... Z-type Color Drums. Posted: 17 Oct 2014 14:04 by issuepress Last edit: 01 May 2015 14:20 by issuepress ... This tells the Riso to recognize newly installed ink tube.
Riso RP3505 drum color change - CopyTechNet.com
www.copytechnet.com > Forum > Technical Forums > Digital Duplicators Sep 9, 2008 - 3 posts - ‎3 authors Is there any way to change an RP color drum to black? How to change a drum color on a Riso MZ 770E? (I'm new ... 3 posts 8 Apr 2014 Riso gr3750 Drum versus GR377\GR373 Drums. 6 posts 1 Jul 2013 Riso RP3700 Print drums wont ink up 7 posts 28 Sep 2012 Riso GR 3750 alignment, drum and colour change ... 9 posts 3 Oct 2009 More results from www.copytechnet.com
change color drum riso Questions & Answers - Fixya
www.fixya.com > Forum > Tags Find solutions to your change color drum riso question. Get free help, tips & support from top experts on change color drum riso related issues.
Risograph GR drum conversion.mp4 - YouTube
z? 0:25 https://www.youtube.com/watch?v=YCttIfFdu0Q Jun 30, 2012 - Uploaded by SpareResidency Used citrus solvent to clean the exterior of an old red drum then switched the ink for a new tube of blue.
My Top 7 Risograph Lessons - Alfalfa Studio
alfalfastudio.com/my-top-7-risograph-lessons/ Jun 16, 2014 - When you need to add another color, you open up the drum door and change the drum to use purple, for example. The Risograph prints one ...
Replacing The Print Drum (cylinder) (color Change ...
www.manualslib.com > ... > Printer > RZ1090 > User manual Riso RZ1090, RZ1070 Manual Online: Replacing The Print Drum (cylinder) (color Change), Replacing The Print Drum (cylinder) (color Change), Removing The ...
Riso printing - Instructables
www.instructables.com/id/Riso-printing/ Risograph The underlying technology is very similar to a mimeograph. ... This master is then wrapped around a drum and ink is forced through the ... Change the color drum, change the paper on the glass sheet, make a master layer and . ... Remember that every different color you want to print, you have to print separate.
Jan 31, 2016 | Office Equipment & Supplies
Continue to get a message to change drum soon. Changed drum already. Print quality is still not good.
hi
This message would continue to appear if the drum counter was not reset when you replaced the drum. To reset the drum counter, follow the instructions listed below.
  1. Open the front cover.
  2. Press the Options key on the control panel.
    The display will show "REPLACE DRUM - 1.YES 2.NO".
  3. Press 1 to reset the drum count.
  4. Close the front cover.
Oct 07, 2008 | Brother Office Equipment & Supplies
The error show replace drum unit and developer but when i replace it with new drum unit and developer the error still shows drum unit and developer need to change?
you did not do it right first you run drum dry, then clear the counter then install the new drum and developer, now get new developer and drum and follow the service manual drum dry first then clear counters then run TCR adj. then run gradation procedure Better to get a tech to do it.
Aug 13, 2015 | Konica Minolta Bizhub 423 Copier Printer...
Why Oki b4600 after changing drum devolves toner empty
The toner cartridge is only a supply chamber. The cartridge simply dumps toner into the feed hopper in the drum. When you change the drum the feed hopper is empty and it is likely that the cartridge dropped the last of it supply into the hopper - ergo it is now empty. I recommend shaking the toner back into the cartridge before separating the cartridge from the drum unit when changing them
Sep 08, 2014 | OKI B4600 Printer
Trouble with Oki B6300 drum/toner cartridge replacment. Can't get back into the menu to reset the printer.
Try removing and then reinstalling. If this happens since you changed the drum and toner, then the issue would be with the defective replacement. Way to test is to reinsert the old drum and toner and if this does not happen, then you know the issue is with the new supplies
Jun 12, 2012 | OKI B6300 Laser Printer
What does a belt life ends soon mean, on a brother MFC 9440ch color laser printer?
Are you sure of the error message? The Brother printers that I have used have Drum Ends Soon and Change Belt messages.
The Brother MFC-9440CN has a belt that can be replaced. The Belt unit has an life expectancy of ~50000 pages. The belt unit is part BU100CL and costs a bit over $150 at office supply stores. Amazon.com and some other stores have the unit for under $100. http://www.amazon.com/Brother-BU-100CL-HL-4040CN-HL-4070CDW-Series/dp/B000SC245E is one source.
When the unit says Change Belt Unit, follow the directions from the manual's maintenance section to replace the belt unit. See page 178 (page 189 of the PDF) http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002252/mfc9440_usa_usr_b.pdf . You have to remove the Drum and then the Belt Unit. Then slide in the new Belt Unit and replace the Drum unit. Then close the printer and turn it on. Finally reset the counter from the Machine Info sub menu (press Menu 8 4 and select the Belt Unit and press OK. Then press 1 followed by Stop/Exit).
If you mean the Drum Unit, that is part DR-110CL and costs over $175 at the office supply stores. Order this part when the Drum End Soon message appears and replace it if the print quality deteriorates (or when you have the new drum). The Drum Life is ~17000 pages. The steps start on page 166 (182 of the PDF). You need to remove the old Drum unit. Then remove the toner cartridges from the drum. Prepare the new Drum Unit, including putting the cartridges in the new Drum. Then replace the Drum unit and reset the counter.
I hope this helps.
Jun 04, 2012 | Brother MFC-8460N Laser Printer
Panasonic dpc264 error u29 what is this
u 29 requires you to change drum unit, as this is a general instruction, the control panel would say which drum it is. there should be instructions in the front cover, if not there usually is supplied with the drum depending on your supplier, but yes one of the drums needs two be replaced.
May 03, 2010 | Panasonic DP-C264 Copier
Brother HL-5250 DN - Drum Replacement Problem
Try a new toner, if its still a problem then the drum is a dud. I've had dud generic drum's before.
Feb 26, 2009 | Brother HL 5250DN Laser Printer
ERROR CODE E000020-01b0
your yellow drum unit is bad replace it if the error ship to 000020-02b0 replace all your drum unit because all the units could be bad but the machine will show one at a time as you replace the drum units
Jun 13, 2008 | Canon imageRUNNER C3220 Color Copier
Panasonic KX-MB781 All-In-One Laser Printer Logo
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
