How can i solve when get error in usb port on tvp2588u+ flash programmer
Connect with pc
parag2010
SOURCE: nokia n72 pc suite problem
my nokiaN72 pcsuit does not work properly & display an error of pcsuit file in mobile is missing.
Posted on Nov 01, 2008
  • 9 Answers
SOURCE: Lost software.So cannot connect USB port to download photo
go to this link http://www.sharp-cart.com/ecom/accessories.htm?action=getSearchItems&ss_id=979&view=catalog/ss_items they have the CD on stock.
Posted on Apr 20, 2009
efs_perpends
  • 1996 Answers
SOURCE: An error message stating that the device overloaded the usb port appears (yellow light at the port).
Go to the device manager and uninstall all usb devices. Turn off computer, unplug all usb, reboot twice, plug usb in again. Also helpful are troubleshooting usb articles here and here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 21, 2009
kev1952
  • 26 Answers
SOURCE: usb not working
Check that all the USB ports are turned on in the BIOS setup.
Posted on Sep 14, 2009
  • 5 Answers
SOURCE: loading to usb data card programmer
you can not see the data card programmer as a drive in My computer , but you use Mapsource to send dat to your card
Posted on Jan 29, 2010
USB port for wireless mouse gets hot and not working
1-try to connect another USB peripheral like USB flash or something else,if this does happen again you have some problem with your USB chip or maybe your main board or USB cabling in your laptop (some kind of short circuit),
2-if your problem still did not solve you have some short circuit or problem with your USB device and try repair or replace the device ,
3-if your problem persist and doesn't solve even with another device you must consider this note:
some USB devices needs 500ma current mode that only available in PCs and some devices and most laptop available in the market just support 100ma USB port
Dec 15, 2013 | Toshiba Computers & Internet
I got a new transcend USB jetflash drive 16GB, but my system not showing any response towards it, what shall i do..??? is to download a software for it...??
Flash drives do not need a drivers (plug and play). There are several possibilities:
1. Assumptions: USB port error, computer drivers normal, normal flash drive.
Solution: insert a flash drive into another USB port. If the USB port 1 is not detected, insert flash drive into a USB 2, USB 3 or USB 4.
2. Assumption: normal USB ports, computer driver error, a normal flash drive
Solution: reinstall the chipset drivers, or USB.
3. Assumption: normal USB port,
computer driver normal, flash drive is broken
Solution: try to insert the flash drive into another computer. If the flash drive is not detected, it means your flash drive is damaged.
Solution to determine the cause of damage:
1. If you have a USB mouse, use the mouse to check the damage to the USB port. Example: connect the mouse to the USB 1, USB 2, USB 3 or USB 4. If every USB port, mouse is detected, the conclusion normal USB port
2. To check your computer's drivers, right-click My Computer - Properties - Hardware - Device Manager
3. If points 1 and 2 are normal, the possibility of flash drive damaged.
Because the new flash drive, flash drive is most likely normal. Based on experience, cause damage to the flash drive is a USB port is dirty. The USB port is dirty, can cause short-circuit flash drive. The characteristics of short-circuit flash drive. When inserted into a USB flash drive (about 5 seconds), the temperature of the flash drive become extremely hot. If there are problems like this, immediately unplug the flash drive, to prevent permanent damage.
I hope this information helps.
Oct 11, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My mother board gigabit 61pme s2p series mother board.with amd althon 3ghz processor.the problem is when i connect the usb pendrive to back of the usb port...if i send data 1 or 2gb data to pen drive.the...
your problem is kind of complicated. Check if you have a defective usb flash drive or an usb connector by doing so:
  1. Try other usb flash drive. If it solves the problem you have a defective flash drive
  2. Try to plug in to other usb port. Observe each port. If you see that you have a problem with your usb ports, buy a new usb port card
Aug 01, 2011 | Intel Motherboard
When I connect to my computer it gives me a message saying device not recognized
Merry Christmas!!!
Greetings for the festive seasons!
It seems like you are connecting a USB device to our computer. USB is a PNP bus. whenever you connect anything to USB, some handshaking is done by the OS with your USB device, so as to recognise its class (if it is a storage device or printer etc,) and other details like its manufacturer, capacity etc. If, for any reasons, this handshaking is not done, this error is raised.
to solve this problem, try following things
1. change cord and try again.
2. If it is a USB hard disk, try twin USB cable. where single USB end is connected to the USB hard disk, and twin USB side (both the pins) are connected to the. PC. It happens, when device is consuming more power, so some additional power is needed to drive it.
3. If it is a mobile, printer or camera, install drivers first and then connect the device.
4. If you are connecting it to front USB ports and the wiring inside is made incorrct. This nmay cause damage to any device you connect to that port. if any other product is working on that port, then simply rule out this probability
5.Try different port, as the device you are using may be using higher version (USB 2.0 or USB 3.0). but this is rare case, as PC itself will prompt you by "This device can work faster"
6. Device itself is faulty. try connecting, similar device to your PC and confirm.
If it is not solved, give brief description of what are you connecting to your PC and what have you tried before.
Dec 27, 2010 | Computers & Internet
How to solve usb not reconized error in sony vgn-s36gp?
Hello
Disconnect the flash drive from your computer, then plug it into a different USB port. On occasion some USB ports do not detect inserted equipment (either because the port is damaged or because the flash drive is not supported by the particular connection).
Connect the flash drive after the computer has powered on. If you plug the drive into the computer before starting the system, the computer may not detect the USB device.
Open an Internet browser and navigate to the drive manufacturer's website. Although most USB flash drives are plug-n-play, the computer may not have the appropriate drivers installed, which means you must install the driver before the system can use the flash drive.
Select the "Support" option, then choose "Drivers and Downloads". Click on the model of flash drive you are using, then the operating system. Click on the driver download link and wait for the driver to download to the computer. Double-click the downloaded file to load the installation wizard. Accept the license agreement, then follow the prompts to install the driver. Restart the computer and the system is ready to use the USB flash drive.
Oct 12, 2010 | Sony VAIO VGN-CR220E/P Notebook
I have been trying to connect a canon printer to my elderly parents eel top. Drivers are installed and usb connected but pc cannot see the printer. Used windows xp printer wizard but could not see USB in...
It looks like the error in ur registry because of invalid registry errors so make ur registry error fix by using reginout registry cleaner it will solve ur problem
Aug 31, 2010 | ASUS Eee Top ET1602 PC Desktop
Canoscan 8800f error as ''cannot connect with scanner''
I had the same problem with a new canoscan 8800f. I found by connecting the scanner USB lead to a USB 1 .1 port instead of a USB 2.0 port the problem seems to have been was solved. I was fortunate to have both. Originally it was just USB 1.1 ports on my PC, but I added USB 2.0. I don't know how you solve the problem if you only have 2.0 ports.
Oct 24, 2009 | Canon CanoScan 4400f MultiFunction Color...
May 21, 2009 | HP PhotoSmart 7960 InkJet Printer
My FlipShare software cannot recognize my Flip MinoHD
Have the same problem with my Flip Ultra HD on my MacPro! Who can solve the problem??
Mar 19, 2009 | Pure Digital Flip Mino Digital Camera
How to transfer video from a sony handycam 105e to a pc
I solved the problem by searching the internet until I found the programme that fixed my problem.
Nov 15, 2008 | Sony Handycam DCR-PC105E Mini DV Digital...
Washing Machines Logo
62 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
