Question about Air Conditioning Condenser 2008 Chevrolet Impala
How do you recharge air conditioning on 2008 impala
    Novelist:
    Scholar:
  • 187 Answers
There is a tag that is generally under the hood that will tell you the amount of R134a that is needed to charge the system properly. These are crittically charged systems and require a vacuum pump to remove non condensibles from the system and then charge the system with the amount of refrigerant EXACTLY required by chevy by the ounce which requires a scale. If you can find a scale that weighs in ounces and can start the count down at 30 pounds you have a good chance at sucess, or if you are using the local auto parts 14 ozs cans you might consider using your wife's diet food scale?
Posted on Aug 15, 2013
2008 Trailblazer Air Conditioner not cooling. blows warm air for the first few miles then cools. It has been recharged.
Philip, You may have to have a good tech, check,diagnose and estimate repair. Could be a few things causing poor AC, recheck your charge level,check your fan at the condenser, make sure the condenser isn't obstructed, compressor clutch could be faulty, system could be plugged with contaminates limiting refrigerant flow.You say the system has been recharged, was it done properly, if not system could be plugged. AC system should of had system checked for leaks,evacuated, flushed, new orifice tube, then recharged with proper quantities of oil and refrigerant. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Car Air Conditioning Problem Diagnosis Repair Help
Automotive Air Conditioning adsbygoogle window adsbygoogle push Repair...
Car AC Not Blowing Cold Enough Car Repair Information From MasterTechMark
Aug 18, 2016 | 2008 Chevrolet Trailblazer
Why is there a clicking noise from air conditioning vents?
Mode door or temp. door actuator, plastic gear is worn out . Can you change air flow , defroster , vents , floor direction etc... ? Change heat to A/C etc.. ?
Dec 23, 2015 | 2008 Chevrolet Impala
2008 impala says engine hot ac off I recharged the ac correctly and it still says engine hot blah blah blah but ac only works every once in awhile
Why are you messing with the AC? It's telling you the engine is overheating and that's why it shut the AC down.
Aug 15, 2014 | 2008 Chevrolet Impala
How to recharge air condition in 2001 chevy impala?
If you need to recharge the ac system in your car they there is a major leak or problem that you have to fix first. Ac system will run for ever unless they develop a leak and the gas leaks out . Take it to an accredited ac specialist shop and have it checked out first for leaks and the exact nature of the problem
Jul 19, 2014 | 2001 Chevrolet Impala
Security light came onm and car would not start could not even get the remote locks to work and all lights stayed on. We unplugged the battery and left the cra overnight. Went back the next day and hooked...
The security light is a real common problem on GM vehicles. You can fix this yourself, read this link for information, symptoms, and ways to fix it. http://vatspasslockpasskeysecurityhelp.yolasite.com/
The air conditioning probably got messed up when unhooking the battery. Id be looking for a fuse or relay that has been tripped.
Jul 04, 2011 | 2003 Chevrolet Impala
I am writting to you because i am getting air conditioned problem in my Smart Fortwo 2003 passion. When i switched on the engine and pressed AC button twice RPM shows AC ON status, however it does'nt...
had same problem on 2008 smart.over winter by not using ac it was blowing cold air.recharge unit.it lasted the entire summer.i know this isnt a complete fix but saves you money
Apr 14, 2011 | Air Conditioning and Heat for Smart fortwo
I have a 2004 Impala.. My A/C is not working I
Buy a new line at a dealer, find a shop which does air conditioning, have them install it and recharge your system. Often shops which do a lot of radiator replacement also do air conditioning service.
Apr 27, 2010 | 2004 Chevrolet Impala
2008 Impala heat problems
remove the radiator cap and let the car run for 30 minutes to let the air out of the heater coil, these radiator caps on the 2008 Impala will not bleed off, while running notice if air bubbles air slowly rising to the top of the radiator cap, re-install cap and see if this fixes problem, we also purchased a new radiator cap, this fixed my wifes car.
Dec 07, 2009 | 2008 Chevrolet Impala
Air conditioning problems with 2000 impala
What stuff did you put in it? You might need a freon recharge.
May 07, 2009 | 2000 Chevrolet Impala
Want to replace the air senser in or around the air intake on my 2008 impala v 6
Isn't this vehicle still under warranty? Dealer should then repair.
Are you referring to the MASS Airflow Sensor? I had to replace one on a 02 Impala (3.8L). It was located right on the top of the air intake passed the air filter. It required 5 minutes to change, but a trip to the hardware store to find tools to remove the torx security head screws took about an hour.
Mar 11, 2009 | 2008 Chevrolet Impala
Air Conditioning Condenser 2008 Chevrolet Impala Logo
55 people viewed this question
Top Air Conditioning Condenser Heating & Cooling Experts
Lawrence Oravetz
L Pfaff
L Pfaff
Dan Smith
Are you an Air Conditioning Condenser Heating and Cooling Expert? Answer questions, earn points and help others
