Question about Toshiba 40SL412U LCD TV
No channels... this is less than 2 yrs old, and it's only picking up 13 cablbe channels...why? it won't even pick up any HD
2 Suggested Answers
james tv man
  • 91 Answers
SOURCE: only picking up one digital channel
digital air signals are weak and fussy. They are easily lost by having trees or large buildings in the way too.
The best thing to do is install a long range roof top antenna and re program the set. Be sure to aim the antenna correctly. if you cannot use a roof top antenna you can try the indoor digital antennas,but less likely to work consistently
Posted on Jun 02, 2010
My 32inch Murphy LCD TV can not find the new
This could be a problem to do with your aerial rather than the TV. However, your first action should be a "Factory Defuault" reset. Make sure the TV does a full retune rather than just looking at the channels where the stations were previously.
The TV will have a flat response through the channel frequency range. Your aerial though could be a very different matter. Depending on the type of aerial, and especially if it's a banded aerial that discriminates against certain frequencies, then the retune may well have moved certain channel into frequencies that your current aerial really struggles to pick up.
You don't say what your TV region is, so I can't be specific because you didn't give the necessary information in the question. But I'll give you an example based on my region which is North West England, receiving off the Winter Hill transmitter.
Anyone with a Group C/D banded aerial will be okay picking up most of the channel muxes because they're grouped up at the top end of the frequency range (ch 49~57). That's pretty perfect for a C/D aerial. However, the new Freeview HD channels that give BBC 4 HD, 4 +1HD, BBC News HD is down at ch 37. A C/D aerial will struggle to pick that up because it is far less sensitive at that frequency, and particularly so if it is a contract Yagi type aerial.
The majority of aerials fitted though are the so-called Wideband High Gain. These favour the upper end of the frequency range again. So channel 37 will be picked up. But is is much weaker than the other muxes.
Sep 03, 2014 | Televison & Video
ABC 1 & 2 channels
ABC on Roku is one of the most watched channels on Roku. This channel provides complete set of channels be it news channel or entertainment. The ABC channel is now available on Roku. You could always activate the ABC channel by setting up your Roku Code Setup. To activate this channel you need to first activate your Roku device and then get the subscription for the Roku Channel. Roku also has many other set of entertainment channels which you could enjoy.
Steps to activate ABC:
    ·If you have an online Roku account, go to the Channel Store.
    ·Select the ABC Channel.
    ·Enter the code
    ·Activate the channel and go ahead. If you don't have an online account:
      ·First generate the Code.
      ·Register the Code.
      ·Create your online user account.
      ·Then follow the above steps.
      There might be some errors or some issues at times while activating the Roku device which needs to be rectified by the correct way or else will lead to the unsuccessful activation of the device. To avoid such issues get the best technical support always to activate your device.
      If you still are wondering upon how to activate this channel on your Roku give a call @1-844-965-4357.
Jul 20, 2008 | Televison & Video
Poulan pro bvm200vs
Take off the muffler and you should see the piston and ring..with a small pick push at ring to see if it moves. If no movement, you have carbon buildup from too much oil in fuel. Remove cylinder and carefully try to free the ring.
Jul 13, 2013 | Garden
No Database - won't pick up channels when doing the Auto Scan
Mine did that and I had to tighten the connection better from the wall cable into the input.
Feb 16, 2013 | Pegasus St09-b 9-inch Digital Tv Atsc...
TV won't pick up channels 7-13
These are what once were VHF channels and are still mostly assigned to local stations.
You didn't mention the source for your received signals, if antenna, cable or satellite and it does make a difference as to the possible source of the problem.
If you are receiving via antenna, then the problem is within the set itself. If from one of the other two sources requiring a 'box,' then the problem is likely within the cable or satellite box that is between your incoming signal and the set.
Jul 29, 2012 | Magnavox 39" LCD 1080p HDTV 39MF412B -...
Sony Bravia Digital TV won't tune Channels 350 and 350, can't manual tune wither as it will only accept 2 digit numbers, even though it tunes 201 ...
These numbers are the LCN (Logical Channel Number) assigned by the broadcasters. It will only be at 350 if it is the same channel from a different transmitter. You need to know the 'channel' of the frequency to manually tune it in. You are talking about the program number not the channel (frequency), a common mistake. i.e ABC in Sydney is transmitted on CH12 (226.5Mhz) and the LCN's for each program are 2,21,22,23,24,201 & 201. If your antenna also picks up the signals from the Kings Cross transmitter ABC is CH30 (543.5Mhz), as these are later in the spectrum they are put in the LCN list starting at 350.
May 10, 2011 | Televison & Video
Can't pick up all available channels
Well, remember that in USA all olds tv do not can receive signal because the new signal transmitting is in high-definition and old equipment do not receive that kind of signal.
Mar 27, 2010 | Zenith SY1324S 13" TV
Is this tv able to use the convertor box to get digital signals?
Here is the manual: http://www.symphonic.us/pdf/om/SC313D.pdf Follow the instructions for connecting a cable box to connect your converter box. Front panel buttons can be used to make menu selections if you do not have a remote.
Jul 12, 2009 | Symphonic SC313D 13 in. TV/VCR Combo
DH Channels
I cant get all my channels on my tv. I do my channel scan but all i get is 13 channels
Mar 20, 2008 | Hitachi 57F510 57" Rear Projection...
Toshiba 40SL412U LCD TV Logo
15 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
