Question about Toshiba 40SL412U LCD TV
Reset button tv
The cable guy is here and needs to reset my tv...how do we do it??
Where is the reset button
Sanyo Service Menu - Factory-Reset.com
factory-reset.com/wiki/Sanyo_Service_Menu
Jump to Sanyo TV Service Menu Method 2 - Unplug the power cable. Press and hold the {VOL -} button on the TV while plugging the power cable back ...
Sanyo TV reset button location? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 27, 2007 - Does anyone know where to find the reset button on a 32" Sanyo TV? The thing is just totally dead and I am thinking maybe if I push the reset it ... I have a Sanyo TV, I accidentally hit the reset button twice. I ...
Aug 6, 2012
36 inch sanyo tv won't change off video 2?
Apr 17, 2010
I accidentally hit the 'reset' button the remote of my sanyo tv ...
Jan 6, 2010
Sanyo DS32224 TV Problem!!?
May 21, 2009
More results from answers.yahoo.com
Nov 29, 2015 | Sanyo DS31520 31" TV
Televison station won't scan
If you are receiving a "No Signal" error message, verify that:
  1. All of the cables physically connected to the TV and the input device are secure.
  2. The input device is turned on.
Your TV needs to scan for channels before it can show programming from an antenna, from cable TV when the cable comes directly from the wall (no cable box), or from a cable or satellite box connected to the TV with a coaxial (RF) cable. Do not scan for channels if you have a cable or satellite box connected using AV (Composite), Component, or HDMI cables. The box selects the channel, not the tuner inside your television. If you are not using the "TV" input, press the INPUT button on your remote until the correct input mode is selected.
To perform a channel scan using the coaxial input:
  1. Press the INPUT button on your remote to view your current input source. The TV (coaxial cable) input must be selected. This may appear as "TV," "ANT," or the channel and call letters of a station.
  2. If the TV input is not selected, press INPUT until the TV input mode is selected.
  3. Open the on-screen menu and select TV or Tuner option. (This varies by model.)
  4. Highlight Tuner Mode and select the correct option:
    • Antenna-over-the air signals from an antenna
    • Cable-direct from the wall cable TV, or a cable or satellite box connected to the TV with coaxial cable
  5. Select Auto Search or Auto Channel Scan. (This varies by model.)
  6. When the search reaches 100% complete, exit to the menu.
  7. Check the available channels:
    • Antenna or direct-from-wall cable-Press the Channel Up and Channel Down buttons on your VIZIO TV remote to view the available channels.
    • Cable or satellite box- Will return only one channel. Use the cable or satellite remote's Channel Up and Channel Down buttons.
If this does not resolve the issue, power cycle the TV and then re-run the channel scan:
  1. Turn off the TV.
  2. Unplug the TV from the electrical outlet.
  3. While the TV is unplugged from the wall, press and hold the Power button on the TV for 30 seconds.
  4. Release the power button.
  5. Plug the TV back into the electrical outlet.
  6. Turn on the TV.
Note: There is also an option to reset the TV to the factory default settings. This option is in either the SETUP or SYSTEM section of the on-screen menu. The option may be "Reset all settings", "System Reset," or "Reset & Admin." Consult your TV's user manual for the location and steps for resetting your model.
  1. Remove the coaxial cable from the DTV/TV connector on the back of your television and perform a channel scan to clear the existing channels. See the procedure above. This should not find any channels.
  2. Re-attach the coaxial cable to the DTV/TV connector and perform a new channel scan.
This video shows troubleshooting steps to use when a "No signal" message appears.
Jun 25, 2014 | RCA 46 46LA45RQ LCD TV
I am trying to turn my TV, but I cannot find where I am suppose to turn it either #3 or #4, to connect with my Comcast Cable adapter ? I have looked on the back side of my TV, where the cable guy told me...
Use your TV remote that came with the TV to put your TV on, 3, or 4, and there should be a witch on the back of the cable box to switch it to 3, or 4.. It is possible that the box is already preset for 3, or 4.
Mar 01, 2011 | Sharp Televison & Video
I am trying to programme my jvc television and I am wondering what does std means.
I have a problem with JVC Plasma TV having a split-screen and i can't get rid of it. Last night an on-line guy told me how to do it with a remote...but we don't have an OEM remote so the reset button does not work(neither does the OK button) and then another guy told us to push the reset buittton on the back twice. Well, we got the TV down and can't find the reset button...or is it on the back of the TV turner?
Does anyone out their have another suggestion?
btw, the cover of the TV looks like it has about 40 screws on the back..
Jun 26, 2010 | JVC AV-48WP74 48" Rear Projection...
The cable guy programmed the cable remote to turn on/off the TV. We used it to turn the TV to stand-by. Then pushed the power button on the TV to turn the power off. Haven't been able to turn the TV on...
First use the original remote control that came with your tv, or just manually turn it on at the tv itself to bes sure it is working. If it works you should call the tech support for the cable company to program their remote control to a different code - or put it back to to factory state and just use two remotes.
Sep 12, 2009 | Panasonic TC-32LX50 32 in. HD-Ready LCD...
We have a durabrand tv and it is Du2701 model and we have a cable box hooked up to it and the remote that went with the box is running the tv. This remote got dropped and some button was pushed and we...
It sounds like there must be a captioning button on your cable remote (if that is the one that got dropped). You should probably call your cable company and talk to one of their service guys and see if they can tell you which button controls Closed Captioning (on my remote, it is clearly identified as "CC"). If that does not work, then maybe you can go to ebay and find a replacement remote for the TV. There should be a way to disable captioning at the set, though.
Sep 08, 2009 | Durabrand Televison & Video
I, have a LHT874 theater system no sound when watching tv
HI, check if you have to turn up the outputs on your tv or even switch them on,also make sure you are useing the audio outs and not an input then set your system to the same input the cables are pluged into and set sound to prologic 2.
Hope this helps.
CABLE GUY.
Feb 24, 2009 | LG LHT854 Theater System
Vizio LCD 37 Inch Turns Off Randomly
I had a similar problem with my 32 inch plasma tv. I called vizio's
1 800 number and the guy said to unplug the tv from the wall and hold down the power button for a minute and then plug the tv back in outlet and turn on. And it works I guess from what I understood from his heavy accent was that the tv retains power and this resets it somehow. hope that was helpfull!!
Jan 15, 2008 | Televison & Video
Ps2 slim will not power up
usually, there is a problem with a ribbon cable of power/reset switch. Try using a replacement ribbon of the same type.
Nov 01, 2007 | Sony PlayStation 2 Slimline Console
Toshiba 40SL412U LCD TV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
