Aeg lavamat turbo 16830
My AEG lavamat turbo 16830 won't turn on, no display or error code.
    Problem Solver:
  • 5 Answers
Start at the beginning,, check your fuse
Posted on Jul 17, 2013
  • Diana Waterer Jul 17, 2013
    I have already changed the fuse and still no change unfortunately.
  • 4 Answers
SOURCE: error code e60
Hi I had this on my zanussi not long ago I pressed the reset button in for 5 seconds and it stopped . The computer board needed resetting. Hope this helps
Posted on Jul 08, 2008
SOURCE: AEG LAVAMAT 74620 - Washing Machine CE error code
Replace Water distributor (Dispenser Drawer) then will be Ok
Rafiq
Posted on Dec 01, 2008
  • 44 Answers
SOURCE: AEG Lavamat Turbo 12830 - error code E20
Hi
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
regards
Posted on Mar 21, 2009
SOURCE: the door handle of my AEG Lavamat turbo 16830 is
Hi there, we too have a similar problem. Our new door handle part has arrived but we are having huge problems fitting it as we cant prise the grey outer trim off the door and thus can't get in to put the new door handle in.
Please help! How can we get the trim off without resorting to serious damage with a screwdriver!!!?
Posted on Jan 23, 2011
  • 884 Answers
SOURCE: What's your problem?AEG Lavamat 62800 keeps stopping and displaying error E50. What is the problem and how do I fix it?
Believe this is a motor fault. Change the brushes as a first fix attempt.
Posted on Apr 23, 2012
AEG Lavamat Turbo 16830: error code E41. The machine will get approx. 20 minutes into a cycle then trip my mains circuit breaker.
It sounds more like a heater fault where the heater is shorting out. Try disconnecting the heater and test it with a meter, put one terminal from the meter on either of the heater terminals and the other on the heater casing, if you get a reading the heater needs replacing. If there is no reading then reconnect the heater terminals and do the test again this will test through the heater wiring, it will at least give you some idea as to where the fault is.
Mar 28, 2017 | AEG Washing Machines
AEG Lavamat 64809 error code E30
Lavamat?! Where in the *&%^ is this machine from? Yugoslavia! I'm guessing it will not allow water IN Because only the Spin (Centrifuge) cycle works?! So if that is so you need your water inlet valves replaced, there are Two. Even in machines named after a Bar of Soap!
Jan 04, 2014 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG Lavamat 16830 won't drain
The simplest way is to lay the washing machine on the right side so that you filter closer to the floor and from bottom of the washing machine is accessible drain pump. It can be fixed by three screws
or just turn pump counter clockwise and pull out.
Dado
Mar 29, 2017 | AEG Washing Machines
AEG Lavamat 11842 Error code E66
http://bastlman.wz.cz/2010/08/AEG-Lavamat-error-codes.html
Feb 23, 2013 | AEG Washing Machines
I have an AEG Electrolux 16830 - I get an error code E10 - pressing the start switch recommences the program and it completes as normal. How do I reset the machine so this does not happen. An engineer...
E10 indicates that the water inlet hose is squashed or kinked.
First check the filter for coins or other junks.
Make sure the drain hose isn't blocked, restricted or kinked.
Hope this helps.. Good luck! ;)
Thanks for using
FixYa - a 4-thumbs up rating is greatly appreciated for answering your free question
Jun 06, 2011 | AEG Lavamat 16810 Front Load Washer/Dryer
The door handle of my AEG Lavamat turbo 16830 is broken, I ordered a new one but would like advice regarding installation please. Thanks
Dec 19, 2010 | AEG Lavamat W1450 Front Load Washer
Hi
regards
Mar 21, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG Lavamat 16830 washer dryer
can anyone tell me how to remove the rear panel of a AEG lavamat dryer. regards Roy
Jul 20, 2008 | Washing Machines
Washing Machines Logo
185 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
