Question about Altec Lansing Imt702 Im600 13v Ac Adapter Power Supply S024eu1300180
Need new adapter lost mine, got new one but 12v works but will not charge ?
  • Altec Lansing Master
  • 5,455 Answers
Maplin Electronics have a good range of Power Adapters visit one of there shops.
Posted on Jul 19, 2013
Need AC power cord for task force model 202754 tire inflator
This a battery jump pack that is used to jump start a car. Some units have an ac adapter built in so you can charge the battery in the jump start pack. My unit has a spot to connect the ac adapter to the jump pack so you can charge the battery in the jump pack. My ac adapter has been lost. I know I have to buy a new ac adapter so I can charge my jump pack, what I do not know is if the input (from the ac adapter) is 120v 60 hz
I understand that the DC output needs to dc12v. I do not understand the milliamps. The battery in the jump box is 12v 10 ah ( what ever that is). I just want a new ac adapter to charge the jump pack with that is not going to damage anything.
Oct 19, 2017 | AC Cars & Trucks
Need the amp rating for the 12v power adapter on Boston BA635 speakers/subwoofer
The bigger the better. It will either get hot if it's not powerful enough, or work ok. The amperage isn't important. The voltage and polarity are. Worst case scenario is you will burn out the adapter if amperage is too low.
Feb 02, 2015 | Audio Players & Recorders
I HAVE LOST THE POWER ADAPTER, CAN YOU SUPPLY A NEW ONE?
this one will work. http://www.buy.com/prod/belkin-12v-dc-power-adapter-20w-belkin-12v-dc-power-adapter-20w/q/loc/101/10296195.html
Mar 30, 2011 | Umax Astra 1220U Flatbed Scanner
I lost the adapter/charger and purchased a new one of the same size. The light will work when plugged into the car cig lighter, but not while plugged into the dc adapter (has been plugged in for approx. 3...
The battery life for these lights are for about 2 years at the most if left uncharged. The best way to determine if you need new a new battery or batteries would be to dismantle the light, remove the batteries and check the voltage with a volt meter. If they are dead, you may be able to fine a suitable replacement at: http://www.batterymart.com/c-04-12-volt-sealed-lead-acid-batteries.html
Nov 12, 2010 | Vector 20 Million Power Series Spotlight
Can a 12V 6A power adapter replace a 12V 1.5A power adapter?
I'm not an electrician, but I do know that as long as the voltage matches EXACTLY (don't take the chance, most devices don't have a good resistor, or don't have one at all!), the current doesn't matter. I'll explain myself:
A consumer device (your scanner in this case) uses all the current it needed, and it practically doesn't need more! It take just what's necessary!
Connecting adapter which provide LESS is not enough, but more - isn't harmful!
Hope I helped,
Pelu.
Mar 14, 2010 | Canon CanoScan 4400F Flatbed Scanner
What adapter can we buy to plug the venturer portable dvd player into a household mains plug. It only come with the 12v lighter car adapter
What I did with mine is check eBay for a 12 volt, DC LCD monitor adapter. These normally have sufficient amperage to handle these players.
I did a search on eBay today using search phrase:
"new power supply ac adapter for LCD monitor 12v 5a"
and came up with one for about $14.00 with shipping. You will need to check the plug when you get it and, if it does not fit, get one from Radio shack or, as I did, cut one from an old adapter I had laying around.
Most of these units require that the positive side goes to the center conductor of the plug (check the diagram on the player case over the plug to be sure) so make sure you set it up the way the diagram shows or very bad things will happen to your player.
You may be able to find a 12 volt adapter at Radio shack or somewhere else but these units need (according to the specs) about 1 amp from the supply to work and charge correctly. You "may" be able to get by with an 800 milliamp supply but I have not tested this.
Good luck
Dec 28, 2009 | Venturer PVS177W Portable DVD Player
Durabrand DUR-7 dvd player
the 12 volt car adapter only puts 9v to the dvd player. It is poorly marked. It really only runs on 9v. If you plug 12v into it it will smoke... thats what mine did.
Aug 14, 2008 | Durabrand DUR7 Portable DVD Player
Sony PSP not charging
ok heres what you do 1. try blowing in the adapter slot 2. take out the mem. card & the battery for 24 hours 3. buy a new psp
Apr 30, 2007 | Sony PlayStation Portable (PSP) Console
How to find replacement adapter for GR-D70AS
Order the original adapter from JVC. The adapter supplies the correct current requirements to operate the battery charge circuit. JVC's web site is JVC.COM. The correct charger will provide up to 1.5 amperes of current for the charge circuit at approx. 11 volts DC. Good Luck Joe Weibel Custom Electronics (customelectronics.org)
Feb 10, 2007 | JVC Cybercam GR-D70 Mini DV Digital...
Altec Lansing Imt702 Im600 13v Ac Adapter Power Supply S024eu1300180 Logo
41 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
