Question about HP Pavilion N5350 Notebook
Screen light When I turn on my computer it comes on but I can barely see the screen. The screen does not light up.
  • Ryan McQuary
    Ryan McQuary Mar 07, 2009
    When the computer powers up, you can faintly see the picture, but the backlight doesn't come on. Can I get a new backlight, or should I just get a new LCD screen, or is it even worth fixing?
Mine has done that too, its not the brightness
Posted on Mar 30, 2008
    Problem Solver:
  • 11 Answers
Babystew, not to offend, did you try to increase the brightness I believe its on your model.
Posted on Aug 28, 2007
6ya staff
SOURCE:
Black screen on my digital camera
Sounds like the back light has gone. Probably not worth fixing as it would probably be to expensive because of whats involved in the repair. It's only cheap Sanyo rubbish anyway.
May 11, 2012 | Sanyo LCD Screen Display For Xacti...
What's your problem?the screen turns very dim to where you can barely see the picture
Your monitor is going bad or your video card is going bad. Try using another monitor on the computer to isolate the problem. Borrow a monitor from a neighbor, friend, relative or co-worker and see if you can barely see the icons and desktop on it. If the borrowed monitor is bright and clear and you can see things ok, then your original monitor is going bad. If the borrowed monitor shows the same problem of barely being able to see things, then your video card in the computer is bad.
May 06, 2012 | HP Pavilion Slimline s3600t Desktop PC
My HP DV5 1159se was working fine last night and then this morning I go to turn it on as usual and a blank white screen comes up. The start tones are the same and I could even type my password in to log on...
If the inverter board or the back light behind the screen were bad your display would be blank, "but windows would be visible barely" the white screen indicates a bad LCD and must be changed. It is also possible the video cable from the motherboard to the screen has come loose and will need to be reseated back into place to fix it.
Mar 23, 2011 | HP Pavilion dv5-1159se Laptop
Turned on computer and my screen saver picture looks like it is coming off the screen it is like it is off center i can barely see the start at the bottom of the screen
I would start with finding an option "Auto-set", "Auto-align", "Reset to default" or similar function in the monitor menu.
Oct 24, 2009 | NEC Computers & Internet
Screen stays blank when turned on
take your computer to your dealer and send it for repair.
The problem is most likely the inverter for the screen.
actually to see if that is the problem you can try to put bright light to the screen and see if you barely see the picture.
May 28, 2009 | IBM ThinkPad R51 Notebook
Screen went almost completely dark, can barely see at all.
I had a similar problem with an HP DV2000 notebook computer. Here's the solution for the HP model DV2040TX: Problem identified and FIXED. Not the screen, not the screen power supply. The problem was the micro-switch within the right-hand-side screen hinge. This switch turns off the screen when you close the lid of the notebook - probably to prevent overheating. The switch had failed mechanically (technical term: "fallen to bits"). As a low-cost fix, I have unscrewed the main casing including the screws inside the battery compartment, removed the silver panel covering the speakers, flicked the switch "ON" using a jewellers' screwdriver, and removed the small metal tongue that is operated by a cam on the hinge. Thus, the switch is PERMANENTLY ON. Computer operates normally, shuts down normally using Windows. Just need to be aware not to close the lid without shutting down the computer beforehand. Hope this helps you. All the best, OzKluger
Jan 23, 2009 | HP Pavilion dv2000t Notebook
No screen at start up
either you darkened it or the back light went out. try the briten it with the FN key
Dec 05, 2008 | Toshiba Computers & Internet
This is a hardware failure of the LCD back-light or a loose connection which requires partial disassembly to verify. Most likely it will require an LCD replacement. If you have an external monitor you can connect it to the video output so that you can see.
Nov 28, 2008 | HP Pavilion dv4000 Notebook
Computer monitor screen remains black
try giving the monitor a hot slap or spank at the back, believe me, you'll be surprise, you've got nothing to loose
Jul 20, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
My screen won't turn on
check the cable throu lcd, possible the cable lost contak. that was supply on the screen. re-chect all connector first before you replace the bulb.
Oct 25, 2007 | Sony PCGFX120 VAIO Notebook
HP Pavilion N5350 Notebook Logo
59 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
