Question about Canon EF-S 18-55mm f/3.5-5.6 USN Lens
Ultra Wide Angle Lens
I have a Canon T3i and in need of an ultra wide angle lens (10-22mm). I checked the entire planet and the cheapest price I found was $459.00 for a used lens. Is there any less expensive lens out there or is there any tricks that I can use that will give me the same result that the 10-22mm Canon does?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
Ultra-wide lenses are going to be expensive no matter what. If you're willing to go with third-party lenses you can save some money with something like a Sigma http://www.adorama.com/SG1020EOS.html ) or a Tamron ( http://www.adorama.com/TM1024EOS.html ).
Posted on Jul 16, 2013
2 Suggested Answers
Obertelli
  • 3006 Answers
SOURCE: My canon EF-S 17-85 IS
There are moving contacts inside the lens which communicate focal length data back to the body via a voltage level, and they have either become worn or dirty.
Either way, when you set the lens to 35mm or less the voltage which passes the information drops out and the camera signals the error 99 to inform you that the lens has stopped talking to the camera.
This is not a user fixable item. The lens must either be repaired or replaced and the problem will get worse if left unrepaired. Contact an official Canon Service centre in your country, you'll find that there is usually a fixed cost repair menu, and often if the fault is a known issue the repair might be free even if the lens warranty has expired.
Posted on Jul 22, 2011
I just bought a Rokinon 10mm T3.1 Ultra Wide Angle Lens for my Sony Nex 7. I am getting an error message when attached that says Lens not recognized please attach correctly.
Samyang 10mm 2 8 Wide Angle Lens Unboxing Impressions Sample Pictures
Regarding a 3rd party lens it always have some problem. Manually pictures can be taken , if completely not supported. Check the video and find similarities. Like keep F- 22 IN LENS , ( or the highest FNumber ) .. turn on manual controls.. then shoot.. check if this helps and inform
Jun 23, 2015 | Rokinon Cameras
Wide angle lens
You can save a little money with a third-party lens like a Sigma ( http://www.adorama.com/SG1020EOS.html ) or a Tamron ( http://www.adorama.com/TM1024EOS.html ).
Jul 16, 2013 | Canon EOS 600D Rebel T3i Digital Camera...
I HAVE A CANON EOS REBEL T2 35MM FILM CAMERA AND AM PURCHASING A CANON TI1. CAN I USE THE SAME LENS ON BOTH CAMERAS?
Yes, you should be able to use them. Be aware, moving to digital there is a 1.6 crop factor. The means your 100 mm lens will have the field of view (FOV) of a 160 mm. No, it does not mean it is a 160 mm it is the fFOV is the same as a 160 mm. Also, at the other end is were you will most want to purchase a wide angle lens.
Example: your 28 mm film lens now has the FOV of 44.8, not wide angle. As you can see wide angle is where the move to digital crop sensor cameras lose out. To get back to wide angel you would need a 17 mm lens, that would give you 27.2 mm FOV.
To figure FOV take the lens multiply it by the crop factor. On a Canon it is 1.6, on a Nikon it is 1.5, the 4/3 sensor is 2.0.
Nov 01, 2010 | Canon EOS Rebel 2000 with 28-80 lens 35mm...
Permanent smudge or scratch in coating of front element. Price of a new element? Is the element able to be re-coated?
Re-coating is not usually possible and will cost more than a new lens element.
The front element is one of the most expensive parts of the entire lens so replacement is often not cost effective. Fitting it and ensuring correct optical alignment is not a DIY job.
The real question is whether the marking is readily visible in the images and if so whether it's a minor artefact which can be edited out? If so, then repairs to the lens are simply not worth doing.
Jun 15, 2010 | Canon EF 14mm f/2.8L USM Ultra Wide-Angle...
Vivtar 20mm wide angle lens #22100295
This lens was manufactured by Kino (aka Kiron) made in 2001. I will try to find out it's compatibility list and post it here when I have it.
Jul 08, 2008 | Vivitar Super Wide Angle 19mm f/3.8 Manual...
Does Tokina-12-24mmF/4Pro DX complies with Nikon-D3 FX Format
Barrel distortion like you describe can always be a problem, especially at ultra-wide focal lengths like yours at 12mm. Some of this can be compensated for in software... Adobe Photoshop CS2 and Elements do a reasonable job, IMO, Bibble Pro (www.bibblelabs.com) does even better, especially with the 3rd party plugins like Percy perspective correction. These are things we have to live with when we have smaller sensors and ultra-wide angle lenses. There is nothing wrong with your lens, you will probably find that this distortion is minimized if you use a longer focal length (say 14mm) and/or stop down the lens a bit.. try f8, wide angle lenses have huge depth of field.
May 20, 2008 | Tokina 12-24mm f/4 Pro DX for Nikon
Lens
Have you ever heard the expression "Good, Fast, Cheap ...pick any two" ? Well, it's that situation. The kit lens is cheap, and it has a good zoom range (including wide-angle) but it's not very high quality. The best lens for you is probably the 17-55 EF-S -but it is $1000. It is a great lens, and it's efficient and light sensitive, along with image stabilization. Without knowing your budget, I would also recommend the 28-135 EF IS, but it doesn't cover the wide angle range. That one is $400. There's also the 17-85mm, which also has Image Stabization. That one is about $500.
Aug 09, 2007 | Canon Digital Rebel / EOS-300D Digital...
Conversion lenses
Product Description Stock # List Price Notes M-CON 40 (Close-up Lens) 200 713 $164.95 *Step-up ring (43-55mm) included. WCON 0.7x Wide Angle Lens 200 864 $139.99 Requires 43-55mm step-up ring TCON 1.7x Tele converter Lens 200 862 $129.99 Requires 43-55mm step-up ring
Sep 04, 2005 | Olympus Camedia C-770 Digital Camera
Conversion lenses
Sep 04, 2005 | Olympus Camedia C-765 Digital Camera
Which conversion lenses can I use with the C-720 Ultra Zoom camera?
You can use the WCON-08 wide-angle or the B-macro (close-up) conversion lenses with the CLA-4 Conversion Lens Adapter on the C-720 Ultra Zoom camera.
Sep 04, 2005 | Olympus Camedia C-720 Ultra Zoom Digital...
Canon EF-S 18-55mm f/3.5-5.6 USN Lens Logo
64 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
