Philips shl5605Hi there, I want to know how to put the pads out the headphones. I've read lots of forums, and, so far, the conclusion is there's no way to do so, without damaging it. Any tips?
I want to remove the cable in the headphones, and as far as Im concerned its damn hard to do it: the pads and the rest of these headphones look like one, indivisible piece.
  • Audio Player... Master
  • 5,391 Answers
Http://therealchart.blogspot.co.uk/p/technical-help-tips.html
This might be helpful.
At then is a link to a site that sells pads if you damage it too much.
Posted on Jul 19, 2013
Thanks for the help !! Dose anyone know what code dOnE mean on a Jeep Wrangler ?
only reference os far is the wrangle has finished reading fault codes
join this free jeep wrangler forum
lots of good help and information there
Jeep Wrangler Forum Jeep Wrangler Owners Community
Oct 15, 2016 | Jeep Cars & Trucks
Replacement foam ear pads
Yes you can. Go to my blog site and you will see a link to a place that sells them.
Apr 12, 2014 | Philips SBC HP400 Headphones CS01 Stereo...
My 1999 Kia Sportage won't start. I put a new fuel pump in replaced the car battery . Need help please...
Im dealing with a similar situation. But have found that I have no spark. By opening the end of the air intake and giving a little squirt of starter fluid and no start. Opened access to FP and pulled a hose. No fuel. So no fuel no spark. reading lots and lots of forums I have come to the conclusion it is either the Cam or the Crank sensor. The crank sensor is easier to get to and cheaper. I am going to check that first.
Apr 06, 2013 | 1999 Kia Sportage
Can I take apart the logitech A-00006 headphones easily.
The padding comes of easily, hook your finger under from the inside and push out gently. Once removed reviles 2 philips screws. Once they are removed you have to pry the 2 plastic disks that form the swiveling ear piece apart. Then you have access to the speaker, which is glued down with a still very sticky substance but will come up quite easilly, then remove the screw from directly under the center of the speaker, then you can pop off the swiveling earpiece that is on a kind of ball and socket joint, this took quite a bit of force. This is as far as i'm going as I now have access to the damaged part of the wire! And also the 4 screws mentioned in the original question. Hope this helps.
Dec 08, 2009 | Logitech Bluetooth Wireless Headphones
Pads on MDR-V300 need replacing
I've found replacement headphone pads at all of the electronic store outlets as well as WalMart, Big Lots, Dollar Stores, Kmart, etc.
Aug 02, 2009 | Sony Audio Players & Recorders
Philips Headphones SBCHL155
Yes they can be fixed. Hopefully the break is inside and not somewhere in the cord. Remove the foam pad being careful not to tear it. Look for small "phillips head" screws which holds the two halves together. Sometimes the halves snap together. Gentally pry apart. Simply resolder the wires, and put halves back together. You may have to "re-strip" the wires. If you do they are very small gauge wires and delicate. Use a small tip soldering iron.
Jul 19, 2007 | Philips SBCHL150 Consumer Headphones
32 people viewed this question
 Grubhead
Grubhead
