Question about Gear Head-Computer KB5850W Keyboard and Mouse USB Wireless RF Keyboard - Black - USB
How to disable sticky keys oonn ccuummpuutteer
I seem to have locked my keyboard and can only use the one on screen, since this computer is touch screen
By the sounds of it, you have enabled your computers Sticky Keys. To disable the Sticky Keys, go to Control Panel -> Accessibility Option and disable everything.
Note: Sticky Keys are enabled by pressing the shift key five consecutive times.
Feb 27, 2015 | Dell Computers & Internet
links:
http://www.pcadvisor.co.uk/how-to/windows/3512425/how-turn-off-sticky-keys/ and
http://www.techrepublic.com/blog/windows-and-office/quick-tip-disable-the-sticky-and-filter-keys-in-windows/
Aug 18, 2014 | Computers & Internet
Shift key is not working
You might consider using, at least tempory, a external usb keyboard with a touchpad, you can get get them at Wal-Mart for around $20.00
Otherwise consider taking it to a computer shop and have them test the keyboard and if need be order you a new one. If this computer is still under warranty then I would would talk to the support team that you purchase it from. Good Luck.
Mar 28, 2014 | Computers & Internet
Dell latitude D610 sticky keys
Hello there...This is a simple task.u only need to press shift key 5 times, then a pop-up window would appear asking u to enable or disable the sticky keys.u can then select whatever u feel like...
Jan 22, 2013 | Dell Latitude D610 Laptop Computer -...
Turning off my green keys on HP pavilion desktop keyboard?
How to turn off Sticky Keys: disable the Ease of Access feature
Tip: use the Windows Ease of Access Center
How to turn off Sticky Keys: what are Sticky Keys and why turn them off?
Sticky Keys is a Windows Ease of Access feature that makes it possible to use keyboard shortcuts or type capital letters without needing to press more than one key at once. Normally, you'd hold down the Shift key while pressing a letter to type a capital, or hold down the Ctrl key while pressing 'S' to save a document. It's even trickier if you want to use a shortcut such as Ctrl-Alt-Del or Ctrl-Shift-Esc.
With Sticky Keys, you can press Ctrl, Shift or Alt, let go and then press another key - Windows will interpret this as pressing two keys together. You should also hear a beep if you have speakers connected.
That's great if you're disabled and can't press two keys at once, but what if you want to disable Sticky Keys?
How to turn off Sticky Keys in Windows 8
You can't press Shift another five times. Instead, you need to bring up the Start menu (or Start screen in Windows 8) by pressing the Windows key. Now type "ease of access" and click on Ease of Access in the list of results.
If you're using Windows 8, you need to click on the Ease of Access Keyboard settings result, and then it's a simple case of sliding the Sticky Keys toggle to 'off'.
If this does not help you. Let us know the below details to understand the issue bettery.
What is the OS?
What do you mean by hot keys? ex.......
Rgds,
Divya
Sep 02, 2012 | HP (395366-001) Keyboard
What are sticky keys My shift will not work and I keep getting a message about sticky keys
Hi
Please try to press both the shift keys at the same time
this may disable the sticky keys and return the keyboard to normal
this quite often happens when you hold the shift key down for longer than 8 seconds or more
many thanks
Aug 16, 2011 | Computers & Internet
HP ProBook 1. Everytime i try to type in a box the screen closes to the desktop 2 my font size always changes; i have to continually change it back to 100, how do i get it to stay.
Seems the on board keyboard had problems ( sticky ) Have you try using Usb keyboard? I guess the 'Sticky key' is Ctrl or Alt key. you can try pressing Shift key 5 times repetedly ( to disable sticky key )
Try remap keyboard > ( to disable sticky key with application )
akee.4shared.com
Aug 15, 2011 | Computers & Internet
Shift key not working
You have 2 Shift keys on the keyboard. If the other shift key is working then the shift key that is not working is defective. You should consider replacing the keyboard on your laptop. There is no setting on Windows that can disable the shift key.
**Note : If both Shift keys are not working, Try to check if sticky keys feature on windows is on. Sticky keys should be disabled. To disable sticky keys, Click on start and Go into control panel > Accessibility Options, and under keyboard there is sticky keys. Remove the tick and click apply and OK.
**If "Use Sticky Keys" is unchecked, that means sticky keys is disabled.
May 29, 2010 | HP Compaq nc6000 Notebook
Can't type anything without weird things happening the \'p\' prints,
hi, check that Sticky-keys arent turned on.
to toggle Sticky-keys on and off, press the shift key 5 times fast, then either Disable the sticky-keys tickbox, or click Settings for more configuration settings.
when sticky-keys are enabled, you can press shift and release, and the shift key is still enabled. this also goes for Alt, and CTRL.
so if it is enabled, pressing P will attempt to be Ctrl-P - which is print.
Sep 10, 2009 | Acer NSK8458AN Keyboard
Both shift keys not working in my laptop
WEl Bro I Read Your Problem ITs A Very Complicated Isse So I have a Easy Solution For It The Solution is that Put Your Key BOard in Water OR Through From the Window OR Put it Into Your Dusbin :D
Jun 29, 2009 | Compaq Keyboard
Gear Head-Computer KB5850W Keyboard and Mouse USB Wireless RF Keyboard - Black - USB Logo
15 people viewed this question
Top Gear Head-Computer Computers & Internet Experts
David Payne
David Payne
Are you a Gear Head-Computer Computer and Internet Expert? Answer questions, earn points and help others
