Question about Sharp N1275FC Cougar AR-407 AR407 Copier Main Board
AR507 network /scanner quit working
Took the back off the machine to get access to clean the filter on cooling fans. cleaned fan on N1275FC board but did not remove it. turned machine back on and now the scanner and any link to the machine is lost. I can ping the nic card and have a green light on it. I reset the print controller board to insure good contact with pins etc but not working so what happened ???
  • nick Jul 16, 2013
    found it !! nic card had a bad connection to the cougar main printer board.. lifted it up and reseated it and it works fine again--tech told me the board was toast -----always check all connections first...
    Habit-Forming:
  • Sharp Expert
  • 190 Answers
Bad connection somewhere sure.
Posted on Jan 08, 2014
myob247
  • 1342 Answers
SOURCE: AJ-5030 Lost Manual
Get your manual HERE
Clean the glass in the scanner.
Posted on Apr 27, 2008
SOURCE: Clean up scanner error
drivers
Posted on Jun 13, 2009
  • 120 Answers
SOURCE: sharp AR-C260M stuck on initializing print
Your AR-P16 or P16N print controller is broken or needs a firmware flash.
Posted on Feb 09, 2011
dwylie76
  • 80 Answers
SOURCE: Were is Sharp AR-M455N back print control board
On the back of the main print engine (Main engine looks like a block under the scanner) toward the top. Your scanner unit will be connected to it. I think there is like 3 or 4 screws to take out and then you can slide it out.
Posted on Nov 10, 2011
dwylie76
  • 80 Answers
SOURCE: What's your problem?Were is Sharp AR-M455N
Whats with norpole 12000 btu window air conditioners w/FO CODE,now all i have is a expensive fan!
they eventually do need serviced by a good repairman .freon leaks out .control boards fail etc .
Jul 18, 2016 | Filter Heating & Cooling
Over heatin and quit rezponding
this problem is probably due to fan being clogged with dust, a simple solution is to get compressed air can and spray out all the air ports on the side and under the laptop, if that does not work it will need and internal clean with new thermal compound for the cpu
Apr 13, 2014 | Compaq Presario CQ62-112TU
Di2010f code C004E
Power unit cooling fan is bad or jammed with dust!. looking at the rear of the machine on the right side lower there is a vent. remove the back panel (will require removing the upper back panel also. There is a filter with that motor. it mite be jammed in the fan clean it and tape it to the metal cover or just remove it then will have to check on every once in while. That fan cools the Power supply inside the machine. Might be burn it out worse case the control board that controls it is bad.
May 21, 2013 | Minolta DI-2010F Copier
When i power up the laptop can hear the fan come on then it shuts down.
sound like you have an overheating issue, try removing the access panels on the base of the machine (unplug from the power first) and look for your fan, quite possibly there will be a fair amount of dust surrounding the fan blades, clean these to the best of your ability, and the remove the fan and check where it blows through the heatsink. This is an area which is prone to dust build up. Clear this area, refit the fan and access panels and try starting the machine.
Hope this helps.
May 08, 2011 | Computers & Internet
Took filter out to clean and now have a humming sound when the hood is turned on but the motor is not working.
When you took the filter out to clean it you got something against the fan blade....probably when you reinstalled the filter,,,pull it back out and try the fan... if it works then you know the filter is installated wrong...
heatman101
Mar 14, 2011 | Baumatic Kitchen Ranges
ACblower working great except made a little raquet sometimes but would usually quite.Cut car off when returned to crank car again no air though vents.Compressor still kicking on like should.Fan just gave...
It ispossible that the filter is choked and the blower fan is choked. Occasionally the fan is getting struck with the dirt.
So you might have to remvoe the dash and access the blower fan , clean the filter and the cooling pipes to get your AC more efficient and less noisier.
The filter cleaning must be done occasionally, specially if you are driving with windows down as ddirt will accumulate into the filter.
so check this out.
Credit if this advice is helpful
Aug 26, 2010 | 1992 Dodge Dynasty
Fluttering sound when trying to tun set on, never comes on and shuts down. Sounds almost like a motorboat sound, but not quite. Recent bulb change. Made sure all vents and air filter were cleaned. Took the...
Maybe the fan is going out. Since you said bulb change I assume your tv is a projection tv. If so I think those tv's have fans to help keep it cool. If the fan is not working properly or failing, the tv may be shutting itself off so further damage does not occur. Check the fan. What is the model number of your tv?
Mar 08, 2010 | Hitachi 43FDX01B TV
I have a Cool Mist V3500 humidifier. The fan
TRY POURING IN SOME WHITE DISTILLED VINEGAR AND RUNNING IT. THE VINEGAR LOOSEN UP ANY SCALE AND JUNK. AFTER RUNNING UNIT FOR AWHILE, DRAIN OUT ANY REMAINING LIQUID AND ADD DISTILLED WATER OR FILTERED WATER. RUN UNIT AGAIN. THEN DRAIN OUT ANY LIQUID. NOW THE UNIT SHOULD WORK AS NORMAL. IN THE FUTURE, TRY USING DISTILLED WATER OR FILTERED WATER.
Dec 13, 2009 | Vicks Cool Mist V3500 Humidifier
Sharp N1275FC Cougar AR-407 AR407 Copier Main Board Logo
21 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
