Ricoh copier 2075 error sc402 - Office Equipment & Supplies
5 Suggested Answers
jaylex
  • 417 Answers
SOURCE: Fault code SC402
Transfer roller leak error 2
A current leak signal for the transfer
roller is detected.
A current feedback signal for the
transfer roller is not detected.
• High voltage supply board defective
• Poor connection of the PCU
• Transfer/separation unit set
incorrectly
• Transfer roller damaged
The above is what SC402 means the most common thing is that someone tried to change the toner and pull out the drum unit a little way.
OPen right hand door open front door lift green toner handle press green button and pull toner unit out press the green button further and keep pulling and then the toner unit will come out totally.
To the right of that is the drum unit pinch the unlock and pull out then push all the way back in. Reinstall the toner unit close all covers and turn machine on.
Hopefully this will work if not there is going to be a problem with the other possibilities listed above
Thanks J
Posted on Jan 02, 2008
SOURCE: ricoh copier aficio 401 error sc 419
How do i clear SC 548 error on aficio 1022 copier machine
Posted on Jul 09, 2008
NALDZ
  • 38 Answers
SOURCE: Functional Problem with RICOH Copier Error No-SC:541
YOU NEED TO RESET THAT CODE
Posted on Oct 22, 2008
  • 161 Answers
SOURCE: Error code SC 548 on Ricoh Aficio 1022 copier. Need to reset m/c
sc 548- service call - fusing unit not set properly
the fusing unit connector may be loose.
u can reset the error by entering the service mode (careful -do not change anything )
to enter the service mode press [all clear](yellow button) ,[1],[0],[7],[clear](orange button)and keep the button pressed for about 5 sec.
go in copier options , then mode 5, then option 810
and execute(or 1 & ok)
(careful -do not change anything else)
Posted on Jan 16, 2010
How can i find the firmware to fix error sc 990 of ricoh 2075?
Contact your nearest Ricoh service center, don't try anything by yourself you may incur controller damage
Dec 25, 2015 | Ricoh Office Equipment & Supplies
Sc335 ricoh model 2075
need more information as to what the problem actually is or error message you are getting before anyone can help you with this
Jun 25, 2014 | Ricoh Aficio 450 Copier
Ricoh 2075 error code sc101
Ricoh MP 2075 SC error 101. Found that the Exposure Lamp would stay on after reaching home position and this fault would appear. Found the solution was to replace the IPU PWB
Apr 22, 2014 | Office Equipment & Supplies
Hw do l clear error sc402
I have just found this site and I am sure it will be of use to you
www.scribd.com/doc/8007865/Codici-Errore-Ricoh
Feb 20, 2012 | Gestetner Office Equipment & Supplies
Error code on display. Sc402. what does the error
Transfer problem
Your Transfer unit disconnected or bad connection.
Unlikely, but a transfer power supply could be faulty.
A piece of paper stuck in the transfer area could also cause that code to come up.
If the machine is dirty and you see toner all over when you open the right side of the copier, have it cleaned thoroughly, that will most likely solve your problem.
Aug 24, 2011 | Ricoh Aficio 120 Copier
Fuctional problems sc402. ricoh aficio 150
SC402: Transfer roller leak error 2
A transfer roller current leak signal is detected.
The current feedback signal for the transfer roller is not detected.
- Possible causes -
  • · High voltage supply board defective
  • · Poor connection of the PCU
  • · Transfer/separation unit set incorrectly
  • · Transfer roller damaged
Jan 26, 2011 | Ricoh Aficio 150 Copier
Error Code SC402 in Ricoh Aficio 270
transfer roller negative current error
Jun 25, 2010 | Ricoh Aficio 180 Laser Printer
I have a ricoh 1022 giving me an erro message "Funtional problem within copier" code sc402. can you send me step by step to fix this problem?
Transfer roller leak error negative electrode.The feedback voltage of the transfer roller is insufficient.Verify the correct instalation of the transfer unit or the separation unit.Check and clean the transfer roller.Verify the connection of the PCU unit(loose).
Nov 21, 2009 | Ricoh Office Equipment & Supplies
Fault code SC402
roller is detected.
incorrectly
Thanks J
Nov 19, 2007 | Ricoh Aficio 180 Laser Printer
289 people viewed this question
jasbo
jasbo
