Need diagram for 1998 Jeep Cherokee sport spark plug wiring
hi, you didn't say what engine you have, I'll assume it's the 4.0 L in line 6 cylinder. Standing on the PASSENGER side of the jeep, the spark plug at the front of the engine is #1, the next is #2, and so on to #6 which is at the back (nearest the windshield).
The distributor is between you and the valve cover on the engine. Pretend the top of the distributor cap is the face of a clock.
The #1 spark plug wire goes in the cap at what would be the 6 o'clock position, (as viewed from your position standing on the passenger side, facing the side of the engine). The firing order direction is clockwise, so the 'hand' of the clock (actually the rotor in the cap) would continue to the next distributor cap plug in, which would be spark plug wire to #5 (8 o'clock position), then #3 (10 o'clock position), #6 (12 o'clock position), #2 (2 o'clock position), #4 (4 o'clock position). So all this means isi your firing order is, 1,5,3,6,2,4 If you have a different motor or any questions, let me know. Good Luck! countrycurt0
