Aquos usb my 64 Gig. puts up a message usb memory is disconnected please check connection What does this mean and how do I fix it?
SOURCE: how to unprotect the memory card
i am having lg 6600 it is showing protected how to un proected it?
Posted on Mar 10, 2008
SOURCE: unprotect memory card
To set the memory card in unprotected mode, you have to do the following.
On the side of the SD chip, there is a little switch. Shift the switch away from "lock", then insert the card back into the camera.
This unprotects the card. You should now be able to take pictures and videos.
If this does not solve the problem, then it is very likely that the SD card is faulty. I would recommend using Panasonic, Lexar or Sandisk memory cards.
~Lexar SD card
~1 Panasonic SD card
~2 Panasonic SD card
~Sandisk SD card
Posted on Jul 13, 2008
SOURCE: How to Transfer Music to my Phone?
First of all, be sure that you have enough space in your phone for your music files. If not, you really need to insert a memory card. The bigger the memory, the more music files you can store in it. Then be sure that your phone is properly installed on your PC. Try also plugging your USB cable to another port. If you have been having problems with it, install it again using its driver. After these steps and your phone is recognized, you access your memory card and there, you can copy music files from yorr PC and paste into your memory card. I haven't used this Nokia model so I suggest you copy and paste music files directly and not by folders so it'd be easier for you to play those music (non-stop). For further question, feel free to comment or add clarification.
Posted on May 27, 2009
SOURCE: Information message when I attempt to open a
You could try turning OFF Digital Driver Signing, press F8, It is at the bottom of the list, at boot up and set it OFF. Also ensure you run everything, install everything as Administrator. If this tuning off works, it must be done Every time you Boot. & OR try setting compatability mode for XP SP2, right click files and select comp mode. Do this for ALL exe's
Posted on Mar 08, 2010
lock123
  • 6831 Answers
SOURCE: Hello, I'm getting the message "Memory Card Error
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Dec 02, 2010
Trying to clone a netbook disk
john
correct the limitation on those devices is usually chip on board bandwidth the smaller devices just don't have the horsepower for a large disk
Apr 12, 2012 | Computers & Internet
What's your problem?My husband got a Vivitar ViviCam 7028 as a rewards gift from his company and we've been busy taking lots of photos and video on it, but when I try to download the photos to my...
The first problem is explained by the error message. Your camera is consuming too much power to go through a USB hub. Try connecting it directly to a USB port on your computer, without going through a hub.
The second problem is most likely related to the card reader. You didn't specify the exact model of Belkin reader so I can't give you a definite answer, but it appears the reader is designed for SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it will not work with devices not specifically designed to work with SDHC cards.
To sum up: If you want to use a USB port, connect directly to it without going through a hub. If you want to use a card reader, make sure the reader is SDHC-compatible.
If you have additional questions, or some part of the above isn't clear, please feel free to respond to this post.
Oct 22, 2011 | Cameras
Hi i just built a new PC with 2 x 2gig memory now under computer properties it says 4 gig installed but only 2.99 gig useable and the new motherboard will support upto 16 gig. Using Windows 7 Ultimate...
Looks like one of the 2gb mem card you bought and installed is defective.
Check each one and clean the gold terminals using a pencil rubber eraer, clean it an install it again, move it to side to side just to perfectly fit the contacts.
If both mem card is working the problem would be the memory socket terminal, either it is dirty or the pin connector is burned.
If one is not working, return the mem card and have them replace it.
Hope FixYa helps you out!
Sep 13, 2011 | Computers & Internet
I have a LG Cu920 model and bought a micro sd 8GB card and used the USB data cable to connect to the PC and i am unable to get connection established as it displays connecting to mass storage device and...
When it displays insert memory card for connecting as mass storage device, switch off the phone and reconnect so the phone will perform as a memory storage device.
Good luck.
Mar 16, 2010 | LG Vu CU920 Cellular Phone
I would like to buy a new dell but not sure how much memory i would need. I don't recall how much memory is in my previous dell. It is a dell dimension xp. Would you please let me know how many GB there...
With any new computer you should get 4 GB of memory, the more the better. There are two version of Windows you can get 32 or 64 bit. The 32 bit version of Windows has a 4 GB maximum on the memory, the 64 bit versions go much higher depending on the version you get. 4 GB will give most people more than enough to do what they need. To see how much memory you currently have just Right-Click on the My Computer icon and select properties. In the window that comes up you will see the memory you currently have.
Jan 30, 2010 | Dell Dimension 3000 PC Desktop
Can not connect to USB Port - Error Message (Warning - Drive G:\ containing photos in library has been disconnected. Please reconnect drive and click retry.) Never have gotten this message after hun
Try unplugging a few other things like USB hubs before plugging in the camera. If this does not work, please advise what other messages you get when attempting to connect the camera.
If you are PC savvy, check out device manager in control panel to see if this gives you any more indication as to what the problem is.
Apr 30, 2009 | HP Photosmart E327 Digital Camera
Getting "Not enough memory available to complete this operation" error message using Sound Recorder
This problem occurs because of a design limitation in Sound Recorder and not because of any problem with the underlying multimedia. That means that the program is unable to access more than 2 gigs of memory by design.
Apr 08, 2008 | Microsoft Windows XP Professional With...
Memory card problem on SPH-M610
I had the same problem. The store where I got my phone checked another phone off the shelf and it had the same problem, and so did another one. But they gave me a 512 mb card and it works. But I still want my 64 mb card working.
Aug 27, 2007 | Samsung SPH-M610 Cellular Phone
Televison & Video Logo
133 people viewed this question
Top Televison & Video Experts
