Question about Kitchen Ranges
SOURCE: Oven not heating to correct temperature
First thing that should be checked is proper voltage. Low voltage can cause this problem. Have that checked by a professional first then let me know what you find.
Posted on Oct 18, 2007
SOURCE: Electric Kitchen aid, model kerc607...broil elements
What is the complete model # from the sticker on the range? I will need that so I can look into this for you. I will say that I have seen, in several cases, where the oven control gets a surge and fries after an element has broken.
Posted on Nov 10, 2007
SOURCE: I have a Kitchen Aid range model KGST307GBS0. The
The door light switch was broken (upper right face of oven). The door switch is automatically activated when the door is opened to turn on the oven light. When the door is closed the switch is depressed to turn off the light. It seems the switch position is detected by the oven and if it is in the open position it will not allow the oven to function properly (reach temperature or allow the cleaning cycle to run). I temporarily locked the broken switch in the closed position, which allows the oven to function. A new switch was ordered for replacement.
Posted on Jan 03, 2010
SOURCE: Replace oven baking element on Kitchen Aid model # KESC300BWH6
It is easy!! After you remove the two screws pull straight out and do so easily, there are two female spade connectors on the element that you'll have to remove. When removing don't pull on the wire itself,pull on the connector. You may have to use pliers.
Posted on Apr 05, 2010
SOURCE: Stove was on bake set to 350. Only the broiler
The F3 E2 error code indicates that the electronic oven control board in the range senses an over-temperature condition in the oven.
This can be caused by a failed temperature sensor probe, a wiring problem between the sensor and the control board, or a failed electronic oven control board.
If the oven is apparently not overheating when this error code appears, then your likely failure is the temperature sensor probe.
If the oven is overheating, then you likely have a failed electronic oven control board due to a stuck relay not cycling the oven heating element off properly.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question*$%
Posted on Sep 29, 2010
Testimonial: "Thanks for the quality information and advice. Gave me the options and answers I needed to get this fixed!"
Jan 28, 2016 | Frigidaire Ovens
Aug 06, 2014 | Whirlpool Stove / Oven / Range Electric...
Aug 19, 2017 | KitchenAid Kitchen Aid Superba Series...
Jul 13, 2011 | Frigidaire Kitchen Ranges
Aug 29, 2010 | GE Spectra JGBP35 Gas Kitchen Range
Apr 05, 2010 | KitchenAid KERA205PSS Electric Kitchen...
Aug 18, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Aug 11, 2009 | Frigidaire Gallery GLEFM397DS Electric...
Oct 29, 2007 | Kenmore 96212 / 96214 / 96219 Electric...
