Question about Shark Ep604 Retractor Lightweight Stick Vac - Factory Serviced
THE BOTTOM FALS OF THE VACUUM MISSING A RED RELEASE CLIP TYPE WHERE CAN I GET THIS CLIP
Mine too!!
Posted on Dec 26, 2013
No solution is dispensing from the machine
Hello, this is Ava with Think Crucial.
First, water tank and formula tank should be filled correctly. Second, make sure the tank is seated properly and reprime the pump. Lastly, make sure that the caps are on securely and the red rubber auto-load gaskets are in place. If the red auto-load gasket is missing, check to see if it's stuck in the reservoir and place it back at the bottom of the tank outlet connection.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.thinkcrucial.com/search?type=product&q=bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
Oct 08, 2016 | Bissell 9500 ProHeat 2X CleanShot Upright...
How do you change bag
Hi! Below are step-by-step instructions on how to change the bag on your vacuum. This vacuum takes a Dirt Devil Type D replacement bag. I have included a link to the instruction manual, as well as a link where you may go to purchase replacement bags for your vacuum.
1. To Remove: squeeze front panel release lever and pull towards you.
2. Grasp cardboard collar of paper bag with both hands and pull past raised locking tabs on the dirt tube. Dispose of old paper bag.
3. Important: Extend bag away from hole before installing. Press in opening to clear paper away from hole.
4. To Install: Push cardboard collar past raised locking tabs on the dirt tube with both hands. Be sure paper bag is fully extended and tucked in at the top and bottom.
5. Replace front panel by putting the two bottom tabs in the slots on the vacuum. Push front panel so release lever attaches.
http://bit.ly/1DEkilx
Type 3 Pack
Hope this helps!
Jun 01, 2014 | Dirt Devil Vacuums
Cant get the bottom lid of dyson dc7 dirt bin to open
I am sorry to hear you are having difficulty opening your clear bin. The mechanism that releases the bin base is actually part of your cyclone assembly. When you pull the trigger, a small clip at the bottom of your cyclone releases the bin base. If this clip is missing or broken, part replacement may be needed to resolve the issue.
You can call us directly to order the the cyclone assembly at 0800 298 0298 (UK) or 1-866-693-9766 (US). The part is also available on our website.
Best wishes,
Jessica
Nov 24, 2012 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I can't get the bottom of the canister to open in order to empty the disrecarded material.
Remove the cannister from the vacuum. The bottom lid should release if you depress the red button at the top of the cannister, if this does not release the bottom lid, you will have to depress the red button while pulling the lid open. Either the release mechanism need repair or there is something jamming the bottom lid.
Let me know if you have any other questions. Thanks.
Nov 04, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
How do you put a Hoover runabout belt on vacuum
I found this on another site and it worked for me. RonL
Looking at the brush, remove the two screws from the black plate holding the brush. There are two clips that holds this plate once you remove the screws. This should be easy to remove with a flat type screw driver. Now is the tricky part to remove the top cover of the vacuum so you can access the compartment to put the belt on. The whole top part of this vacuum comes off. If you look above the part where black plate was, there are two more clips on the top left and top right hand corner. These two hold one end of the top cover. It is not as simple as pushing the clip to one end to slide out. You have to find a gap between the edge of top cover and bottom structure(right next to each clip) and shove the flat screw driver in and push the top cover away from the bottom structure and push down the top cover. You will notice that there are invisible hinges between the two which locks in the top cover.
Do the same procedure for the bottom right and left edges(right next to each end of the brush) of the vacuum and separate the two(bottom structure and top cover) out using the flat type screw driver..
Jan 05, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Bissell Pro Heat Powersteamer- Filed it up, turned it on, asusual, but no water flowing from machine at any setting. Vacuum part works.
The water sprayers on your Bissell are probably clogged. I had this problem this morning, myself, with my machine, about 15 months old. They get clogged up with mineral deposits. This is a *fairly* easy thing to fix yourself. Read all the way to the end before trying this fix.
Unplug the Bissell. Remove the water container pieces from the top of the base. You'll probably reveal two red plastic pieces mounted in the Bissell's base, about .75" x .75". These spray water on your brushes when you press the water-and-soap trigger at the top of the Bissell's handle. These water sprayers tend to clog. See the metal spring running up the hose, behind each red water sprayer? As you squeeze the red plastic sides of one red water sprayer, use a screwdriver or other tool under the spring to wedge up the hose, to release the sprayer from its mount in the base. Stick a finger in the hole of the base of the Bissell where the sprayer was mounted and run it around the edges there including on the underside of the base to clean out any gunk you can find. Clean any gunk you can off the red water sprayer with an old toothbrush.
Now you need to remove the water sprayer from the hose. You need a pair of pliers. Use the pliers to squeeze the brass colored clip that is keeping the red water sprayed mounted to the end of the small hose there. Move the clip down the hose so it compresses the spring and is no longer on the red plastic water sprayer. Now you can twist and pull the red water sprayer out of the end of the hose. You'll need a little hand strength to do this. Just be careful not to break the water sprayer by using a tool. They're not particularly delicate, but breaking one would render your Bissell useless until it was replaced, so use a little care.
When you've removed a red water sprayer from the hose, put the outer end of the red water sprayer in your mouth and seal your lips around it, and try blowing through it. You can't blow air through it, right? It's clogged. Open up a paper clip and push it back-and-forth through the small hole in the end of the water sprayer back towards its middle. You'll probably push out a line of white mineral deposits. Clean them off the water sprayer with the old toothbrush, and try blowing through the water sprayer again. If air passes through clearly, you've fixed it. Now you have to put it back together. Push the water sprayer back on the end of the hose. Use the pliers to reposition the brass clip on the end of the hose over the water sprayer. Push the red water sprayer back into position in the base of the Bissell.
Now do the same for the other red water sprayer.
I had a problem when I fixed this on mine this morning, because when I pulled one water sprayer off, the hose advanced up under the spring and I couldn't reattach the red water sprayer, because it couldn't reach the end of the hose. So try to use the brass clip or some other means (rubber band, tape, another clip) to keep the hose from crawling up inside the spring after you pull the red water sprayer off the hose. If the hose gets up under the spring anyway, despite your best efforts, I fixed this by removing the six screws on top of the Bissell base (the surface of which the water tank mounts on top of), and then pried it up. You can pull out the hose, reattach the red water sprayers to the hoses, position the hose *very carefully* inside the base (there are mounts under there they need to fit into, so you don't break anything), push the red water sprayers through the mount holes and mount them, and then reattach the screws to the base.
There's something else you may need to do that can help get the water flowing. This one's easier. The Bissell uses pumps, which need to be primed. Sometimes an air pocket inside the machine keeps water from flowing. To prime the pumps, separate the two water tank pieces. Fill the base as usual and mount it on the Bissell without the top water tank piece. Plug the Bissell in and **turn it on**. (The Bissell must be running to do this.) Kneeling on the floor in front of the Bissell, reach up and press the soap and water release trigger at the top of the Bissell's handle and hold it in as if you wanted water to go through. On top of the water tank is a plastic grommet hole about 1 inch in diameter, through which you pour water to fill the tank. Seal that hole with the flat of your hand. You'll feel a bit of suction. Lift your hand up and down a few times. Release the trigger and repeat a few times. Now that you've cleaned out your water sprayers and primed the Bissell's internal pumps, I'm hoping water will GUSH through your Bissell once again.
As you probably have learned the hard way, as I did, it's VERY important to do a lot of cleaning of the Bissell after each use, more than the manual tells you to do. Clean the bottom of the unit. Empty all the water. Thoroughly rinse out both water container pieces. Unscrew the three clear plastic pieces, one in front, two on the sides, that surround the brushes, and rinse them thoroughly in water. Clean off the brushes and all the lint and gunk around and above the brushes. (A water spray bottle and toothbrush are helpful here.) Tip the machine and blow all the water out of the hole in the base. Release the red clip springs on the red water sprayers and blow on them. Doing this will slow the failure of the Bissell. It's a great little machine for the money, but it does have a learning curve and need more pampering than a vacuum cleaner, doesn't it??
May 18, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell Bagless Vacuum cleaner
There is no release, the part is a plastic handle release lever, you can find those at www.hesco.com, the cost is approximately 2.29 each, I have replaced more than 20 of these on the commercial vacuums for my cleaning crew, the part is easily broken and easily replaced. I always have 6 or more on hand.
Turn the vacuum over, remove the bottom plate, with a flat head screw driver punch out the old part. turn the vacuum upright again after the broken part is removed. With the body laying back on a hard surface, carefully push in the new part. Unfortunately, these are plastic, too bad they cannot design a more sturdy part for this.
Apr 10, 2008 | Bissell 3522 PowerForce Bagged Upright...
Kirby vacuum
The Kirby air flow can be reversed to become a blower (not pump).
This is ideal for blowing up low pressure items such as air beds etc.
Take off the complete bag assembly by twisting at the bottom and unclip at the top.
Fit the flexible hose to where the bag attached, align the arrows and twist fully until located.
Remove the front brush assembly, lift the front head light flap, detach the belt by twisting the square knob to the red position (off). un-clip the front assembly.
Your kirby should be supplied with a box type attachment (air intake guard) that fits on the front covering the motor spindle and making the safety switch.
Once fitted your kirby should now blow.
Mar 16, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Opening the dust holder
If you tilt the dust cover downwards a little once you've pressed the button and then squeeze the sides of the of the dust cover slightly it will pop off the bottom clip
Oct 10, 2007 | Black & Decker CHV1500 Bagless Handheld...
Dirt Devil vacuum Release pedal not working
take off the bottom like you are replacing the belt. You will find a little metal clip that controls the upright lock.  It may be lose or broken.
Oct 01, 2007 | Vacuums
Shark Ep604 Retractor Lightweight Stick Vac - Factory Serviced Logo
Top Shark Vacuums Experts
Thomas Perkins
Thomas Perkins
Ruth summersides
Are you a Shark Vacuum Expert? Answer questions, earn points and help others
