Question about Sony VAIO VGN-N170G/T PC Notebook
Wireless problems Can detect wireless networks but cannot connect
Go in the internet [OPEN NETWORK AND SHARING SYSTEM] then go in [CHANGE ADAPTER SETTINGS] then disable the Ethernet and restart your laptop and after restarting go to same settings and enable your Ethernet. hope it works
Posted on Jul 16, 2013
Cannot switch on wireless connection Packard bell laptop does not have switch
Wireless problems with a Packard Bell PC or laptop can be caused by a variety of issues.
The best troubleshooting resources are the documentation that came supplied with the computer, and the Support section of the Packard Bell website.
Unable To Detect Wireless Network
If the Packard Bell machine is unable to detect a wireless network, the computer itself or the network could be at fault.
Check that a wireless signal is being broadcast via another PC or device, and check that are wireless adapter is installed, complete with the latest drivers, which are available at the Packard Bell website.
Unreliable Wireless Network
If the wireless connection is unreliable, intermittent or very slow, it suggests a problem with the Wi-Fi broadcast.
Try positioning the computer closer to the router broadcasting the wireless signal, or use a signal booster to improve the range.
Download and install the latest driver updates from the Packard Bell website and through the Windows Update tool.
Unable To Connect To Wireless Network
If the computer can detect the network but is unable to connect to it, a network security key may be required. This should have been configured by the person who set up the network. Consult the documentation that came with your router for details of how to change it or generate a new key.
Hope this helps
Oct 23, 2012 | Packard Bell Computers & Internet
Acer Aspire 5733 Wireless connection lost
Check the wireless router and high-speed modem.
If the two are not powered on, or if the Ethernet cable connected the two is not completely inserted into both connection ports, you are unable to access the Internet on the Acer Aspire One laptop computer.
Activate the wireless Internet connection on the laptop computer.
Right-click the wireless icon on the desktop, then choose "Enable" from the pop-up menu.
Without activating the wireless receiver on the Acer Aspire One, the laptop is unable to detect any wireless network.
Select the appropriate network you wish to connect to.
Your computer may be attempting to connect to a different Internet connection, preventing you from access the network you desire. Right-click the wireless icon, select "Search for available wireless networks," then choose the network you want to access.
Restart the computer.
The system may have booted and failed to detect the wireless receiver. Restarting the computer corrects this issue.
hope this helps
Sep 13, 2012 | Acer Aspire 5733 Laptop
I can not access my internet. It says I have no connection, yet my wi-fi is turned on and I can not detect any problems with the wireless adaptor. I have tried to get help from the router company and...
If your device can detect the wireless router and can connect to the wireless network, that means that there is no problem with the wireless adapter. You need to check if your broadband / internet modem is connected properly to your wireless router.
Jul 03, 2011 | Acer (BCM94318MPG) Wireless Adapter
HP 550 - Unable to detect just a particular wireless network
Given all the circumstances, I can only guess that, for some inexplicable, apparant reason, your network card in your computer is the culprit. Try to get a friend who has the same model to swap cards with you, then you'll know for sure. The other problem could be something to do with the signal and some slight anomoly that is causing your card a problem in detecting it. A communications signal is complicated, and some wireless modems have better circuitry than others, depending on the model. But no matter how we speculate, this is just one of those Twilight Zone enigmas! Best of luck- tricky problem, for sure.
Apr 07, 2010 | HP Business Notebook 550
My computer was wireless then one day when i try to connect it says no wireless networks in range. my wireless button is on but i still can't connect how can i fix this problem
maybe theres a problem in the wireless network that you are connecting to, that why your computer detected no wireless connection in range if there no wireless network to connect to you will get this message there nothing wrong with the adapter or you are far away for the computer to pick up the signal its either way
Nov 20, 2009 | Computers & Internet
Wi-fi connection
1. First, you have to make sure that the Wi-Fi of your laptop is turned on.
2. Make sure that there's an available wireless network in your area so that you can test if the computer can detect any available network.
3. If you're running Win XP, right-click the wireless icon on your system tray and select "View available wireless networks"
4. If you can't detect any wireless network, right-click the wireless icon on your system tray and select Open Network Connections.
5. Right-click the Wireless Network Connection icon and make sure to enable it.
6. If it's already enabled, try to disable it and then re-enable it.
7. If you can't still detect any wireless network, try this:
- Click the Start > Run > type msconfig > hit Enter
8. Locate the Wireless Zero Configuration and click on it once.
9. Once it's highlighted, locate the Start button on the upper left hand corner of that screen.
10. After starting the Wireless Zero Configuration (WZC), try to detect the wireless network again.
Apr 08, 2009 | Advent 4211c Notebook
Wireless network undetected and problem with wireless lan
first check for whether the wireless switch on laptop is turned on or not u have to keep it turned on .further install the drivers for wireless lan
Nov 21, 2008 | Toshiba Satellite A100-S8111TD Notebook
Acer aspire 5360
Please make sure that the wireless antenna switch is on. Then enable the wireless feature using the hot key combination for your laptop (if available but need not be done since you were able to detect networks earlier). If you are using Vista, please click on Start-Connect to to see if your laptop is now able to detect networks.
If laptop is not able to detect any networks, please uninstall the wireless network adapter by going to Start - Control Panel - Classic View - Device Manager - Network Adapters - select the one for the  Wireless Network Adapter - properties - driver tab - uninstall - ok. Then please restart your laptop. Click on Start - Connect to  and see if your laptop is now able to detect networks.
If laptop is still not able to detect wireless networks, please click on Start - All Programs - Accessories - System Tools - System Restore then choose a restore point (date) which is a possible time when your laptop was able to detect wireless networks. Laptop will restart automatically and notify you if the restoration is completed. Try Start - Connect to. Hope it works this time. Thank you.
Sep 30, 2008 | Acer Aspire 5630 Notebook
Wireless connection
If this laptop has a wireless switch, make sure it's on.
Did you get the wireless hub?
Wireless is controlled by the wireless zero service, which should turn on automatically when your adapter is detected.
You can turn it on manually in Control Panel/Admin Tools/Services
Nov 03, 2007 | Acer Aspire 3000 Notebook
Intel PRO 2200BG will not detect any network
This IS the solution: Set it to use 802.11b _ONLY_ Do this in Windows: Start->Settings->Control Panel->System->Hardware->Device Manager->Network adapters->Intel(R) PRO/Wireless 2200BG Network Connection->Advanced->Wireless Mode = 802.11b only Driver version: 9.04.36 (04.04.2007) PROset/Wireless Software: not installed OS: Windows XP
Aug 15, 2007 | Intel PRO/Wireless 2200BG 802.11g/b
Sony VAIO  VGN-N170G/T PC Notebook Logo
32 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
