Question about LG DLE2350 Electric Dryers
How do get the drum out of dryer mo,dle2350
Wanta replace thebelt
  • LG Master
  • 8,220 Answers
Their is videos on youtube that show how to disasemble lg dryer like this one:
http://www.youtube.com/watch?v=Sy_ZK5f-WS8
Posted on Jul 16, 2013
Why is it now squealing when in spin mode
If your dryer is the kind with rotating drums, might be a bearing. You should disassemble it and check if can be replaced
Dryer Repair Replacing the Drum Bearing GE Part WE3M26
Dryer Repair Replacing the Rear Drum Bearing Assembly Frigidaire Part...
Dryer Repair Replacing the Rear Drum Bearing Kit Part 1 GE Part WE25M40
GE Dryer Repair Noisy or Screeching Rear Drum Bearing WE25M40
you can fine more youtube video tutoriala looking in google for terms
Youtube DRUM DRYER
Sep 02, 2015 | Dryers
OPC Belt reset
Sir/Madam
I suggest You watch official video In Brother Printer Official Website For Your Brother Printer Issues:
How do replace thebelt unit With Video Instruction Brother
I Hope You Resolve Your Brother Printer Issue and Brother Printer Problem By Now,
Or
In case You still need Brother Printer Help assistance Then I suggest You Follow Us On For:
Brother Printer Support
Nov 07, 2012 | Brother OEM Brother OP4CL OPC Drum Belt...
Washer makes a buzzing noise when it tries to spin
Hello. Loud noises coming from a Washing Machines are most often caused by looseobjects inside the unit or by a broken dryer belt. The Washing Machines beltallows the dryer's motor to run smoothly. Continuous wear and dry conditionsmay cause the belt to dry out, eventually Washing Machines cracking and thensnapping. This will cause a loud noise within the unit. Repair and fix thedryer belt of a Washing Machines to get rid of loud noises. Instructions And Things You'll Needed to solve the problem.
Screwdriver ,Replacement Washing Machines belt 1 Stop the Washing Machines and look inside the dryer's drum for any looseobjects such as coins, pens or anything else that may have been in a pocket ofclothing. Remove the object and restart the dyer to determine if the noise hasstopped.
2 Unplug the Washing Machines from the wall outlet to disconnect all power tothe unit. 3 Remove the lint trap from the lint compartment on the top of the dryer. 4 Remove the screws that hold the top panel in place. Pull the panel off toaccess the
dryer belt.
5 Tilt the dryer forward and lift the dryer drum to remove the belt. Check theWashing Machines belt. A belt that is worn, cracked, split or broken will causeloud noises. 6 Slide the old belt off of the drum and pull it out to remove it. Take noteon how it is positioned over the drum.
7 Install the new belt. Lean the front panel away from the Washing Machines andslip the new belt over the drum. Locate the position of the old belt and slipthe new belt following the old belt's position ensuring the grooved side of thebelt faces down. Push the idler pulley towards the motor to allow you to slipand loop the belt around the motor pulley.
8 Place the top panel on the Washing Machines and screw it in place.
9 Open the Washing Machines door and use your hand to rotate the drumcounterclockwise a few turns to ensure the belt is secured.
10 Plug the Washing Machines into the wall unit and begin use . Thanks.
Sep 13, 2011 | GE Energy Star WCVH6260F Front Load Washer
I have an Electrolux front load dryer Mo. # GLER331AS2 and the drum is no longer turning but the belt is in good condition. What could be the problem. The motor sounds like it is working when I use the...
Your belt may have slipped off of the idler pulley, or maybe the belt idler spring has come unhooked from the belt.
I will include a website that shows the belt configuation...
Please rate me
http://www.applianceaid.com/images/belt-config.JPG
Dec 31, 2010 | Electrolux FEQ332ES Dryer
How can i reach inside in order to change thebelt?
Pull of the back panel of the unit for access.
Apr 17, 2010 | Maytag MDE9316 Dryer
Hotpoint aquarius tumble dryer, drum not going round but still
If you can hear the motor going, then the belt probably needs replacing, if no motor action, then prob is more serious.
Please rate my solution.
Thanks.
Jul 15, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Drye squeaks louldly and smells hot drum stops turning
you have a drum ball that is chrome looking that fails a lot
you need to get the kit and direction from a parts house to fix it ..
mine breakes about every 6 mo
5 boys in the house
Apr 02, 2009 | Kenmore Dryers
My dryer drum is no longer turning when I press start.
On some dryers, actually the front comes off easier. Yes, you need a better view down there. Make sure the dryer is unplugged! Let me know what you find.
- Jim
Jul 15, 2008 | Danby DCD5505W Electric Dryer
LG DLE2350 Electric Dryers Logo
46 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
