Question about Tools & Hardware - Others
Norge 18 Ga L cleat flooring nailer
The nailer keeps jamming and it is shearing off some of the nails. It is new and has only nailed 500 sq. foot of bamboo flooring. Could you help solve this problem.
  • 8 Answers
SOURCE: nail gun wont fire
First - the air pressure has to be high enough - check the regulator on the tank to make sure it is delivering in excess of 60-70 psi (which I am sure you have already done).
If you have dry fired these guns (i.e. shot them off with no nails in them while you were lubricating them maybe) the mechanism inside could be damaged. I had that happen to one of my nailers (same brand). That was when I learned not to dry fire them...
Since both of them are not working though I would be more inclined to look at the air supply first.
Posted on Sep 10, 2009
brewerstool
  • 141 Answers
SOURCE: My Sears Craftsman 18 gauge brad nailer won't nail
Your driver is not returning. Depending on the model that you have there could be a couple of problems. The most likely is that your piston stop is crumbled and some of your seals are worn or damaged. Whether or not you can fix the nailer depends on if the parts are available from Sears Parts Dept. If you would like some more information about fixing your nailer please post which model it is that you are trying to fix and I can see if the parts are available. I will post the information back to you.
Posted on Oct 12, 2009
  • 10 Answers
SOURCE: using the BOstitch flooring nailer, good air
1. check to make sure the magazine does not contain a jam.
2. check to make sure the driver retracts fully to allow the cleat to advance
3. Be sure to have at least 90psi and to hit the head hard enough to fully fire the nailer.
Posted on Oct 31, 2009
  • 10865 Answers
SOURCE: my floor air nailer is jammed and there is no
Hello. Sometimes putting a few squirts of a penetrating lubricant such as WD-40 into the firing mechanism will free it up. The method to do that is to give it two squirts, let it sit for a few hours and then test it. Then if it is still jammed, a couple more squirts. The faster method is to disassemble the head where the ram goes up and down and clean and lubricate the parts. DO NOT have the gun hooked up to air when you work on it. Joe
Posted on Mar 13, 2010
  • 1388 Answers
SOURCE: gun fires mor than one nail at a time porter cable
There are two issues that people have with nailers that sound the same however are totally different. Firing more that one nail at a time can be taken as; two nails being driven with one fire or the nailer vary rapidly firing a second time almost instantly after firing the first nail and each time only drive one nail. Problem of double fire (either type) is very common with nailers (the gun very quickly fires twice), however two nails at once can only happen if the wrong gauge nails are used in the gun. A 15 g nailer can very easily pass two 18 g nails or, with more difficulty, pass two 16g nails. To help prevent the driver blade from hitting two nail heads at once, most drivers are slightly tapered at the tip so that the driver will hit the first nail and the tapered part will push the other nails back into the rails slightly. Remove the head of the nailer and pull out the driver. Measure or compare the thickness of the driver to the thickness of the nail head. If you are sure that you are using 15 gauge nails, check the driver for taper. The tapered part should face the rails. If not tapered, try carefully grinding a taper keeping the tip cool so that you do not effect the hardness. You could also check for other brands of 15 g nails with slightly more spacing between the nails. There is a big difference in quality among brands of nails. Good luck with your repair
Posted on Jun 02, 2011
18 ga. Floor nailer will not shoot fasteners
Must be oiled everyday.
Had to take mine apart....metric hex keys
And clear the jam.
Remove from air source first.
Apr 24, 2016 | Norge 18ga. Floor Nailer Flooring
Doesn't fire full pressure
Set your compressor at a higher psi. Maybe you need a better compressor
Oct 26, 2013 | Porter Cable 2" Flooring Cleat Nailer...
My gr200lcn floor nailer keeps getting nail stuck in it on the first nail filred
Depending on amout of use, driver blades do need to be ground square or replaced to make full contact with the nail head . There could be other factors causing problem however. The nails do need to align with the path of the driver. Make sure that the first nail is directly under the path of the driver. If the nails are not made correctly or the wrong nails are in the gun, the angle of the nails may be preventing full contact of the driver to nail head. Good luck
Dec 24, 2012 | Grip Rite GripRite GR200LCN 2 Floor Cleat...
Nail is jammed in my porter cable fcn200 cleat nailer --how do I get it out?
It looks like those guns have a problem with driving the last few nails... so don't let them go all the way down before refilling...
There also should be a tool included to relase the nose so the jamm can be cleared...
Checkout the reviews here there is a ton of helpful info there...
http://www.amazon.com/Porter-Cable-FCN200-Pneumatic-Flooring-Nailer/product-reviews/B00005JRKG
heatman101
Nov 26, 2010 | Porter Cable 2" Flooring Cleat Nailer...
Staples wont penetrate wood and keep foldin up
are the nails proper for nailer? the gauge of the nail is important
Oct 02, 2010 | Stanley Bostitch MIIIFN Flooring Nailers
Will work fine for one or two nails and then nails jam in the gun or it shoots two or three at once.
This is iffy... but PC nailers are nit picky. If you used someone elses nails, it can (and will) jam and mess up.
So, if Porter Cable nails are being used, clean and lube the nail shoot (with a few drops of air tool oil).
If that does not work, Invest 19 dollars in a new, 18 guage nailer at Harbor Freight. I have 2 of those and they have been trouble free for 3 years.
Nov 15, 2009 | Porter Cable 1" 18 Gauge Brad Nails...
Using the BOstitch flooring nailer, good air pressure and using cleats. but when i tap with hammer noting happens. the nailer goes off as if it had gone off but no nail was driven.
Sep 25, 2009 | Stanley Bostitch MIIIFN Flooring Nailers
Porter Cable 18 ga Brad nailer - BN200 Will not reload
Strip and clean the whole diaphragm and spring arrangement. Also check whether a bad nail hasn't damaged the piston guide and caused it to jam when on return stroke.
Jun 13, 2009 | Porter Cable 18 Gauge 2 " Brad Nailer Kit...
Question regarding Bostitch MIIIFN or MIIIFS
Read the warranty for Woven Strand Bamboo floors. I think you find this is the wrong tool. You`ll probably find that you need an 18ga 1/4" crown, so it don`t split!
Thanks,
Jeff
May 02, 2009 | Stanley Bostitch MIIIFN Flooring Nailers
Tools & Hardware - Others Logo
281 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
