Question about Refrigerators
Ice not releasing on beko gnev320s
Push the arm for ice makes a loud noise doesnt release the ice even when theres ice in there,works ok on the water dispensor.
SOURCE: no water for ice maker
make sure wire is in down position this is like the on and wire up is off
Posted on Jul 14, 2007
fridgetech
  • 473 Answers
SOURCE: Admiral Refrigerator makes hollow ice
Hollow ice cubes are due to low water pressure to the fridge. Water thru the door should have good pressure behind it. This is a good indicator of water pressure. Should be able to fill a glass quickly. Causes for low pressure are self-piercing saddle valves on the water line (switch to drill type (1/4") valve) or reverse osmosis system or filtering system on water line to the fridge. R.O. systems should not be used. Increase water pressure and that will fix the hollow cubes. The loud noise may be the sound of the water valve on the fridge when it is acivated. This sound is normal and some are louder than others.
Posted on Oct 05, 2007
fridgetech
  • 473 Answers
SOURCE: Ice maker not making ice
Chances are it will be best to replace the ice maker but give me your complete model # from the sticker inside the fridge.  Also, make sure the fill tube to the ice maker isn't frozen up.  There should be a 3 digit # in front of the 52554100.
Posted on Oct 18, 2007
maklean
  • 1665 Answers
SOURCE: no water to ice maker
  • The water line that's attached to the back of the refrigerator. Make sure you have good water flow. If the flow is poor, repair, clean, or replace the tubing or the shut-off valve that supplies the water.
  • The water-inlet valve. Replace it if it has failed.
  • Posted on Jul 28, 2008
    itls
    • 17 Answers
    SOURCE: GE side by side refrigerator: water/ice dispensor
    I bought a brand new smartwater replacement filter and after a very short time, my water stopped coming through the door.. took out the new replacement filter and inserted a brand new one .. problem solved.. apparently some of the g.e. smartwater filter replacement cartridges don't have the high enough two plastic inserts which are attached to them at the top of the filter when you screw them on... if you have taken your cartridge in and out a few times, i think it wears down the plastic so it doesn't fit properly and won't put up whatever it is supposed to push up to make the water come through.. I personally think this is a g.e. problem with the replacement filters...
    Posted on Mar 16, 2009
    I just got the side by side Frigidaire professional and every few hours there is a loud noise that comes out of it that last like 3 seconds
    Thanks for your post, friend!
    I see that your Frigidaire side by side refrigerator is making a loud noise every few hours. There are a lot of normal operating noises within a refrigerator. It is possible that your evaporator may create a boiling or gurgling noise. Or you could be hearing ice being released into your ice bin. If you have your manual they should list some normal operating noises within your refrigerator. I hope this information has been helpful. -Matt
    Oct 19, 2014 | Frigidaire Refrigerators
    I get a loud grinding noise from my ice maker. What can make that noise?
    Thank you for your information you provided, could the noise be described as a clicking or ticking noise? The reason I ask is I have heard for this to be a motor driven harvest and the heating within the ice maker is not engaging to release the ice, so the unit continues to push the ice out causing the gear to jump a tooth. If this is the case the only fix is replacing the ice maker to fix the issue. Other possible cause of grinding is the water in not entering the ice maker (hollow ice cubes) so the water is accumulating around the fan motor and freezing up. As the fan turns on the grinding is the fan motor cutting away at the ice. Gain access to the fan motor and check for ice around the fan, if its there remove that ice. The cause is that the water is not getting into the ice maker and causing this issue. Good Luck, I hope this helps.
    Aug 30, 2014 | Frigidaire FRS6HR45KS (26 cu ft) Side by...
    Beko DW450 not engaging into cycle on any programme
    Not sure, this link may help. Ask Question Get an Answer ASAP
    type in the name of your appliance.
    Feb 26, 2014 | Beko Dishwashers
    Beko WME8772W washer not working
    clean the filter first
    look in the pump for any bits in it
    Feb 06, 2014 | Washing Machines
    Frigidaire FRS6LR5E ice maker won't stop making ice
    Ice maker wire signal arm is being held down by some item in the freezer. Move item and release wire signal arm. Any ice cubes that are frozen together over the wire signal arm. the ice rises in the ice bucket and pushes the wire signal arm up and this is what stops ice production as ice is used then arm comes down and starts ice production all over again. if there is nothing holding arm down then you will need to replace ice maker.
    Oct 07, 2013 | GE Monogram ZDI15C Automatic Icemaker
    Automatic Ice Maker making grinding noise and will not release ice
    The mold heater on the bottom of the ice maker is shot, that is why the cubes will not release. The grinding is the sweep arm trying to push the frozen cubes out.
    May 06, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
    Noise when spraying
    The wash arm(spray arm) is not a tight fitting item,as for the noise the when spraying have a look at the spray arms the are a few holes on each side and top and bottom of each arm,you will need to remove the arms of possible they normally have a quik release system where you push two small fingers together and the arm releases,then inspect these holes and you will probebly find that some are blocked this cuases a uneven flow of water and thus makes the arm rotate un even and make a noise if you find there is food of sorts in these holes remove and put the arms back and that should take care of the increased noise.
    Feb 05, 2009 | GE 24 in. GSD2030Z Built-in Dishwasher
    Fan in freezer very loud noise
    There is probably an ice build up behind the plastic rear panel. The ice build up gets so thick that eventually, it obstructs the fan and then you get that loud noise as the tips of the fan are chipping away at the ice.
    What you need to do is to remove the rear panel and thaw the ice build up. To remove the rear panel is usually only 2 screws at the bottom.....you will find that the panel is difficult to remove due to ice build up behind it, so gentle heat from a hairdryer is a good way to accelerate the thawing process....once the panel is removed, you will see the ice build up......mine was about 2 inches thick!!!
    I used the hairdryer to thaw it all out and then once cleared, switched it back on and have never had a problem since.
    By the way, my F?F is a Beko CDA563FS......the one with the water dispenser on the front and frost free.
    Hope this helps
    Feb 01, 2009 | Freezers
    Ice maker makes ice but doesnt kick it out
    seem likes the heater on the ice maker mold is not working , you'll need to replace ice maker
    Dec 15, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
    Firgidaire FRS20ZRG Side by Side Refrigerator/Freezer Ice maker not working
    reach into the icemaker and with a finger pull up on the ejector blades on the icemaker watch the blades and see if they go all the way around
    Feb 13, 2008 | Refrigerators
    Refrigerators Logo
    57 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
