Chat live im jw can i use a motherboard tray from my old pc with a new motherboard ive got for my new build ,there both atx boards ?
    Champion:
    New Friend:
  • 219 Answers
ATX is a standard size, so the mounting holes should be the same on both boards.
Posted on Jul 18, 2013
SOURCE: d9840 60003 mainboard
I am having the same problem, I found this info useful, hope it helps. http://forums12.itrc.hp.com/service/forums/bizsupport/questionanswer.do?admit=109447627+1215449263004+28353475&threadId=820435
Posted on Jul 07, 2008
SOURCE: PC build problem I am
DO YOU HAVE A MOTHERBOARD MANUAL?.Are you sure you have power to the correct plug in on the board?some boards require more tahn one plug in.http://www.computerhope.com/comp/iwill.htm.http://www.computerhope.com/help/mb.htmhttp://www.computerhope.com/help/mb.htm#support.These links will help.I can be of further help if you have the need.RICHARDM69
Posted on Jan 03, 2009
  • 119 Answers
SOURCE: atx control wire
Here you can find all info, drivers and manuals:
http://www.abit.com.tw/page/en/download/download_manual.php?pFUN_KEY=11000&pTITLE_IMG=/download/images/download.gif
Posted on Jan 06, 2009
gotgeek2
  • 565 Answers
SOURCE: instructions on atx case wiring to motherboard
Assuming that the computer is laying down on it's right side, and you are viewing the F panel (the front panel header) from the right side of the motherboard (the bottom of the computer), pin 1 is on the bottom left of the F panel, pin 2 is on the top left, pin 9 is on the lower right, and pin 10 is on the top right (no actual pin)...
1 HD_LED_P Hard disk LED (+) 2 FP PWR/SLP *MSG LED (+)
3 HD_LED_N Hard disk LED (-)
5 RST_SW_N Reset Switch (-)
7 RST_SW_P Reset Switch (+)
9 RSVD Reserved
4 FP PWR/SLP *MSG LED (-)
6 PWR_SW_P Power Switch (+)
8 PWR_SW_N Power Switch (-)
10 Key No pin
Usually the wires and the pins are color coded, (the colored ones being positive.) Sometimes the connections are written in very small abbreviations on the motherboard.
Posted on Jan 28, 2009
  • 30 Answers
SOURCE: foxconn atx lga775 motherboard #661gx7mi-s i
Check here ><
Posted on Feb 18, 2009
I want to upgrade the mother board in my Vaio PCV-RZ44G Desktop so that I can run Windows 8. What board forms are compatible and is an Intel I3 or I5 CPU better?
You would be better off applying the money to a new computer. You are opening "Pandora's Box" . You will end up with a old case with ALL new components. That may or may not work, A.K.A., "pain and heartache".
Jan 07, 2013 | Sony VAIO PCV-RZ44 (PCV-RZ44G) PC Desktop
Tip
Form factor
<span>The</span> <span><b>form factor</b></span> <span>sets the</span> <span>standard for</span> <span>the size of</span> <span>a</span> <span><b>motherboard</b></span> <span>and</span> <span>the</span> <span>design</span> <span>and placement</span> <span>of</span> <span>holes</span><span>,</span> <span>slots</span> <span>and ports</span><span>.</span> <span>His</span> <span>case</span> <span>must</span> <span>format</span> <span>the card</span> <span>you</span> <span>choose</span><span>.</span> <span>Most</span><b> <span>motherboards</span></b> <span>today</span> <span>are</span> <span>set by</span> <span>the</span> <span>ATX form factor</span><span>.</span> <span>The</span> <span>home theater enthusiasts</span> <span>looking</span> <span>to consider</span> <span>a</span> <span><b>PC</b></span> <span>for the living room</span> <span>to</span> <span>a</span> <span><b>smaller MicroATX board</b></span><span>.</span> <span>These</span> <span>cards</span> <span>use</span> <span>the</span> <span>general</span> <b><span>ATX</span> <span>design</span></b><span>,</span> <span>but</span> <span>also</span> <span>fewer</span> <span>slots</span> <span>I /</span> <span>O</span><span>, so</span> <span>that</span> <span>an adjustment</span> <span>board</span> <span>shorter than</span> <span>in</span> <span>a small</span> <span>box.</span>
on Jan 09, 2011 | Computers & Internet
Uatx motherboard in mini atx case
Probably however if you upgrade the motherboard you will have to upgrade the CPU, and the memory, possibly the hard drive if the old board is IDE and the new is sata. Also you would have to upgrade the power supply if it's so old it may not have sata power connectors.
Dec 24, 2012 | Compaq Evo Workstation W6000 PC Desktop
Will new micro atx boards fit inside of a hp 4550z case?
Yes i think you will be ok as i can see and your old motherboard is microatx but i strongly recommend you to change case because is not only about motherboard.You will need and better and new power supply and if you want to build a good system with air flow for not overheating your new cpu and other hardware i strongly recommend you to change and chassis!!You can find a "nice" case with $50-$70 bucks if you dont want to spend money on case,but you will need power supply for sure
Jan 07, 2010 | HP Computers & Internet
Would this motherboard fint in
Yes, the board would physically fit in the 5000 series case. In fact, any micro-ATX form factor board would fit. But you will need a new power supply as well. Motherboards used in those computers did not need the 4-pin power cable required on new boards. You should also consider cooling if you are building a high-performance system. The 5000 series case doesn't offer much room for adding cooling fans - only one place on the rear panel. But they are nice cases. I've built several systems in them.
Jan 31, 2009 | Compaq Presario 5000 PC Desktop
Problems on PCCHIPS M701G Motherboard
connect your three pin socket in your power plug
Jan 12, 2009 | PC Chips M701G V1.1 Motherboard
Replacing Asus CUV4x Motherboard with Asus p5vd2-vm-se motherboard? I have my old computer that i want to replace with new set of motherboard. My old computer has the following specification: Asus CUV4x...
Hi eibral2345, sorry but there is no chance the motherboard, Asus P5VD2-VM-SE will run the Samsung memory. It’s the old style 3.3V PC133/100 SDRAM. The new Asus motherboard,
P5VD2-VM-SE uses Single-Channel DDR2 - 667MNz or 533MHz memory. Here is a link to the specs of the Asus CUV4X: http://www.pcstats.com/articleview.cfm?articleid=314&page=3
Here are the specs for the Asus P5VD2-VM-SE MB: http://www.asus.com/products.aspx?modelmenu=2&model=1787&l1=3&l2=11&l3=369&l4=0
Will the new Asus board fit in your case? It should!
The larger measurement is the height of the board.
The Height + Width of the new board is smaller than the older board.
Have more questions?
Good luck eibral2345!
Mike
Sep 26, 2008 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
My first PC build....gone horribly wrong =(
Please CLICK HERE for more info on your power supply.
My guess is that your power supply is dead. If the fan doesn't spin it may be that the fan died first and the PSU overheated.
Now, if you are fortunate nothing else got damaged. You can remove the PSU (the mounting screws are on the back of the case, there should be four) and buy a new one at your friendly local computer parts store. Get one rated for at least as much power as the old one. We can give you a hand on this if you tell us what the lable on the side of the PSU says.
I should caution you that there is a chance that when the PSU went it damaged other parts of your system.
Goodluck..
May 06, 2008 | VIA ASRock K7VM3 Socket A/...
Bad motherboard.gateway atx tower
whatever socket that is 454 soket mobo i think or befor ethat so old look on ebay for one that can take your chip how do u know mobos bad no power or im open for chat anytime also thx nick helpap
Jan 06, 2008 | Gateway (4000597) Motherboard
Computers & Internet Logo
David Payne
David Payne
