Question about Denon Avr-1712 7.1-ch. 3d-ready Home Theater A/v Receiver Avr1712
Comcast remote
When I use the "All On" on the Comcast Remote, the receiver turns on but the audio goes off. I have to shut it off and turn it on again for it to work. Any suggestions on how to fix this?
SOURCE: Remote locked
I had the same thing happen. This fixed it...
1. Press master power switch OFF
2. Hold down Speaker A & B buttons simultaneously then press master power switch
Display will flash at 1 second intervals denoting that the microprocessor has reset.
3. Release Speaker A & B buttons
Remote should now work.
Posted on Oct 26, 2007
SOURCE: My receiver isn't turning on
Replace the internal fuse
Posted on Nov 05, 2007
marsrover
  • 682 Answers
SOURCE: Denon AVR-1707 Receiver - remote stopped working
please apply a new fresh battery to it-confirm from right orientation(polarity)-try to apply a contact cleaner spray over the bad button and press it many times.-remove any thing between remote and receiver.-you can use universal remote and confirm befor you buy the new remote that it support your receiver.
Posted on Jul 12, 2008
  • 93 Answers
SOURCE: Denon RC-978 remote... every button shuts receiver off
Drop the front panel of your receiver,there is ZONE 2 ON/OFF switch.
Good day!
solutiondoct
Posted on Nov 06, 2008
alpug
  • 1961 Answers
SOURCE: Denon AVR-1708 Have you ever heard
Hello!
I hate to ask but, was there any light interference between the remote and the Denom device?
using your cellphone camera again to test the infra red emission of your device. Aim the camera to the infra red of your device. you must see at the screen of the camera that the infra red is illuminating.
if not the infra red sensor of the device is busted or faulty
and needs replacement. It could also mean you have a cold solder on the ir sensor board inside the Denom AVR-1708.
If you have a soldering iron and lead, try to reach the ir sensor board by opening the case of your device. Resolder all terminal junctions. And see if it works normally again.
I would still suggest you have it check by a certified technician, to avoid inflicting more damage to your unit.
Good Luck!
Posted on Sep 23, 2011
Comcast remote codes for apex digital dt502
Brand: Apex Digital
Most likely code: 10765
Others to try:
10748, 10879, 10767, 10890, 11991, 10889
To program your remote:
  1. Turn on your TV
  2. Using the code list, find the first five digit code that is listed next to the name brand of the TV that is to be programmed
  3. On the Comcast remote, press and release the TV key
  4. On the Comcast remote, press and hold the SETUP key until the TV mode key blinks twice then release the SETUP key
  5. On the Comcast remote, enter the first listed five digit code
    Note: If this number is entered correctly and is an accepted TV code, the TV mode key will blink twice. If the code is entered incorrectly or is not an accepted TV code, the TV mode key displays one long blink and exits programming mode
  6. Aim the remote control at the TV and press the POWER key once
  7. The TV should turn OFF - if it did not turn off, repeat steps 1-6 with the next TV code listed, until a working code is found
Nov 03, 2013 | Apex Digital DT502
Turning off close caption on xfinity tv
The Comcast boxes let you enter a special menu only when the box is turned off. Just turn off the Comcast box and press the menu button on the remote you will then see a menu for the box where you can turn on and off close captioning
/uploads/images/turning-off-close-caption-xfinity-tv-35300106-2-1.jpg
/uploads/images/turning-off-close-caption-xfinity-tv-35300106-2-2.jpg
Mar 13, 2013 | Comcast XFINITY
My comcast remote won't turn on or off my yamaha rxv365 audio receiver only controls the volume the code i put in was 30176
It controls the volume just fine. It's the power that doesn't work. I'm having the same problem with my Yamaha receiver. Different model. Multiple Comcast remotes too.
Apr 14, 2011 | Yamaha RX-V363 Receiver
Need the remote code for my receiver to program my Comcast remote
Here you go dude:
http://www.comcast.com/MediaLibrary/1/2/CM/VanityURL/documents/comcast_on_demand_remote_manual.pdf
Oct 25, 2009 | Yamaha HTR-5250 Receiver
I have comcast TV & Internet. I have a Comcast
Sadly mos households in this country operate their tv with two remotes because so many times the components are not compatible. sorry i couldnt help u more
Apr 06, 2009 | Sony RMT-D112A Remote Control
Closed captions will not work thru my tv remote
I hope this was resolved but this is a dish page and I am unable to answer Comcast issues.
Feb 14, 2009 | DISH Network 811 HD DTV Receiver
Comcast remote
The volume keys should be working by default, but you may have volume punch through turned on (meaning the remote is sending signals for TV or CABLE volume function no matter what mode you are actually on). To unlock volume control for AUX mode, do the following:
1. Press and release AUX
2. Press and hold SETUP until the remote blinks twice
3. Type 993
4. Press and release VOL-
The remote should blink four times to confirm unlock.
Jul 05, 2008 | Yamaha RX-V1400 Receiver
Denon Avr-1712 7.1-ch. 3d-ready Home Theater A/v Receiver Avr1712 Logo
22 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
