Epson tw3500 has a thick purple line run across the hello bottom of the screen. First occurred after bulb was changed. Bulb was changed again but issue remained. Now the projector only turns on 1 out of 10 times and still has the purple line.
  • 27 Answers
SOURCE: epson powerlite 7700p video problems
could be, colour change is typical of a pj lamp expiring.
check first the connection lead between pc and pj
to make sure pj is seeing all signal pins on sub d lead.
check pj with video sig input, if thisis ok it's not the lamp failing
Posted on Feb 26, 2008
INTERLOGIC
  • 326 Answers
SOURCE: brand new projector- has lines across the screen scrolling
check the lighting coil
Posted on Jan 17, 2009
SOURCE: Infocus screenplay 4805 projector
check the wireing in the new bulb . My new one had the wires in the wrong holes like if there are 4 slots in the connector then my orignal was in slots 1 and 4 the new one was in slots 1 and 3 so I took the wire out and put it in the #4 slot and put it in and unpluged the machine and did a reset and restart and it came on green. Hope this helps.
Posted on Jan 28, 2009
SOURCE: XR-10x bulb timer has timed out. How do I reset the projector?
you need to reset the lamp timer see http://www.ercservice.com/PDF/Lamp-Sharp-XR10-XR20.pdf
Posted on Apr 16, 2009
SOURCE: I replaced the bulb in my projector and now it
You need to hold the help button on the remote control for ten seconds, that should reset the lamp hour. NEC decided to make it inoperable after 2100 hours on the bulb.
Posted on Nov 23, 2009
A small horizontal line going across the bottom.Now a horizontal shadow appeared above the line.Each day a new shadow appears & lighter then the rest.Now a thick box of silver/purple lines at bottom.
Seems like back-light fault. If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Aug 12, 2016 | Televison & Video
Split screen, kind of inverted w/white wavy lines
It is a calibration problem, let me see if I can find some schematics for your tv.
Jul 19, 2008 | Panasonic CT-32SL14 32" TV
Red line across the top of the screen. bulb was just replaced
HELLO,
IF YOU HAVE A SOLID RED LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
I HOPE THIS WILL HELP OUT IN RECTIFYING THE FAULT AND DO TAKE CARE IN SOLVING THE PROBLEM , BECAUSE THE TELEVISION CONTAINS HIGH VOLTAGE....
May 13, 2011 | Televison & Video
My Epson PowerLite 1725 projector has a wide green bar displayed in the middle of the screen with a purple shadow on its right. Do you think a bulb replacement would fix it?
im afraid that sounds like some dead pixels. and if thats the case then no a bulb wont fix it. call epson tech support and see if they will replace it for free.
Mar 05, 2011 | Canon LV-LP12 Projector Lamp for LV-S1,...
Thick purple line scrolling up from bottom of screen continually
if it is a uniform pulsating line, then it is the main board or engine. if it is a fuzzy line it is the light tunnel
Apr 26, 2010 | InFocus IN72 Multimedia Projector
Red and blue streaks across the screen top and bottom
The Convergence Amp IC's are bad. You should call a good TV Tech for this repair.
Jul 11, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Purple-blue haze and line across my Mitsubishi wd62530 screen
hi this fault could be the convergance ic also the resistors and capacitors need to be checked, thanks
shaun
Jun 26, 2017 | Mitsubishi WD62527 62 in. LCD HDTV
Purple blotches
Ok, so I'm about to flip a lid with my TV. I am showing purple quater sized blotches all over my screen. I bought it for a discounted price because of this issue, in hopes i could fix it. I took the back panel off the TV. ( about a 6in * 6 in plate) removed the light bulb and cleaned the bulb and lens, where the light bulb faced. I used a dust cleaner and special cloth. NOTHING! I took the entire front screen off cleaned it and then cleaned the mirror and second lens.... NOTHING! Then i heard that dusk sometimes gathers behind the lens and that should be cleaned. Try this, Its 4 screws, just be careful and remember the way you took it out, because it has to be replaced the same way.
Lindsey <3 AZ
Nov 28, 2007 | Epson Livingstation LS57P2 57" Rear...
Thick color lines on screen
Hi ,Sorry, this is not a solution. I have a question about your line. Is it transparent? (can you see through if the picture is bright)Does it remain there all the time if you change inputs? My LG 42" just had a blue transparent line appear on the right side of screen. Tried a few trouble shooting things w/ no change. About 1 hour later it went away. Did you find a solution and what was it?
Sep 05, 2007 | LG 42PX5D 42 in. Plasma HDTV
Projector Colour Problem
Could be a few things....first you need to isolate a signal source issue or a faulty LED lamp. Simply unplug your signal source and run the menus on the projector. Purple Gone with source unplugged = faulty source our signal Purple still there = faulty device Sounds crazy but make sure you have no interference devices running real close within say 2 feet. cell phone, microwave, magnets, high voltage eletricity...etc
Jun 06, 2007 | Offspring Technologies C5YP-BIN-25 25...
26 people viewed this question
k24674
