Canon ir1600 check printer cover after paper jam
    New Friend:
Debes revisar la puerta lateral de abajo del baypas y/o charola de alimentacion manual. esta por lo general cierra mal de un lado y no activa el actuador del sensor de esa puerta. suerte espero te funcione.
Posted on Jul 23, 2013
Please help with cannon PIXMA MP150 printer problem, when trying to print, It reads that paper is jammed but I've checked several times and no paper is jammed. Printer will not print due to this...
Hello and Welcome to FixYa!
Paper jam means their may be small bit paper jam in side
, actually there are some "micro sensors" that detect a paper jam. There will be tiny piece of paper inside those sensors, thus tripping the sensor and paper jammed keeps coming up.
To solve this first of all Open printer cover and check to make sure no paper or foreign objects obstructing the printer feeder
, If you become sure that now really there is no paper, dust or foreign objects then Turn the printer off, and disconnect the AC power-cable. Open the printer cover & now give the printer a "blow-job" by compressed air.
If still problem exist then best & final option is to just contact to any Canon Printers service provider.
I hope this solution helps you
Thank you for using FixYa!
Aug 04, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Printer stops showing symbols when on and when is ok, an idicator states paper jam...there is no paper jammed...checked thoroughly.
Hello and Welcome
If you are facing this error their may be small bit paper jam in side
There are some "micro-sensors" that detect a paper jam. There will be tiny piece of paper, or a lump of dust, inside those sensors, thus "tripping" the sensor and saying you paper jam.
To solve it :
After it if still you have error then it is probably that your Canon printer is in need of servicing by a service professional.
So go to the Canon Service Center. If you want to get support on Call then
Call Canon Support by phone, at 1-800-OK-CANON (1-800-652-2666)
I hope this will surely help you.
Don't forget to do Rating by Clicking on Four Thumbs which are given below to this solution if it is HELPFUL
Thanks
Mar 03, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Want to correct a system error E000 on canon IR1600 photocopier
E000 indicates a low temperature problem in the fuser unit.
  • Check the fuser for any jammed paper and remove it
Check and replace with spare part if needed:
  • the thermo lamp,
  • the thermistor in the fuser unit
A code reset is needed:
  1. Press ADDITIONAL FUNCTIONS, #
  2. Go to #7 PRINTER, press OK
  3. Go to #4 PRINTER RESET, press OK
  4. YES = (*)
  5. Power cycle the unit.
Jan 05, 2011 | Canon iR1600-2000 PS
I have a paper jam and it says to open the front cover, put the front cover just shows the ink cartridges and there is no visible paper jam. how do i find the jam and remove it? It's a canon image...
The paper jam could be in three places.
First:
Open the cover of fixing section, its above bypass, and check for jamed paper
Second:
Open the transfer cover, these cover has handle and it goes by pulling toward you, and check for jamed paper.
Third:
In hight of first paper cassette, on left sideway of copier, beaneath the bypass are small door, open it and check for paper jams. Be sure that you closed them properly because if they arent closed the check printer cover message will arrise.
Hope that helped
Jul 07, 2010 | Canon ImageRunner 1600 Copier
Canon G3 model (same as ir1600), LGL size not found
oopppsss! you have to go back into service mode and reenter all the door spec from the front cover and that should get you back. But you may also have to do more service mode adj.
Apr 17, 2010 | Office Equipment & Supplies
Printer jam
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
toi-i-10
Jul 21, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon MX860 Rear Paper Jam
I have a small piece of paper jammed in my Canon MX-860 that Cannot be seen from anywhere. Can you help me find so I can clear it
Jun 27, 2009 | Canon Office Equipment & Supplies
I have a peice of paper jam in the output area of the imagerunner 1670, but the machine dosn't open to allow access to this area. how do i get the paper jam resolved.
Your jam is in the fuser section of the machine. Unfortunately this area this area is not for users to access. You will need to remove covers to get to the fuser unit. You may be able to access the paper by removing the whole drum unit (make sure you remove the toner cartridge first). Then look into the machine to the left. You may see the tail end of the document for removal. Otherwise, you will eed a service manual to dis-assemble it yourself.
IR1600 Service Manual
May 05, 2009 | Canon ImageRUNNER 1670F Copier
Paper Jam Problem in Canon LBP 2900
I have a same problem .... somebody help us. :(
May 23, 2008 | Canon LASER SHOT LBP-2900 Printer
Canon mf5650
Check the paper setting in your software. Paper size should be A4 in all instances. Hope it helps
Oct 04, 2007 | Canon LaserBase MF5650 All-In-One Printer
Computers & Internet Logo
97 people viewed this question
David Payne
David Payne
