Question about Garden
Scotts L2048 lawn tractor deck wont engage
Tractor operating normally. automatic trans. with a pull/push knob to start/stop blades. However blades are not engaging when knob is pulled. when pulled everything still operates normal but no blade engagement. any suggestions?
I too have been having problems. Have been at my wits end this year working on it and not running when i need it to... i did find this site after trying everything else that didnt help. http://www.lawnmowerforum.com/small-engine-mower-repair/10887-scotts-l2048-pto-not-engaging-correctly.html
Posted on Oct 16, 2013
  • 2,239 Answers
You need to check the wires from the clutch, with the ignition on pull the pto switch out there should be a 12 volt supply at the wires if not replace the pto switch, if you have 12 volts then it is the clutch itself, they are not realy repairable, so may need a replacment.
Posted on Jul 17, 2013
  • 41 Answers
SOURCE: blades not engaging
Tim, first turn key on engage and disengage blade button. See if you can hear the clutch making a clicking noise. If not check switch., if not your problem is in the clutch.
Posted on May 29, 2009
lester482529
  • 226 Answers
SOURCE: mowing deck makes ticking noise when blades are engaged.
A FEW THINGS TO LOOK AT ARE ,1THE PULLY SHIELDSMAKE SURE THEY AREN'T BENT TO CLOSE TO THE PULLEY'S.2 THE PULLEY BEARING'S MAY BE WORE OUT AND TO BREAK .3LOOK UNDER THE DECK TO MAKE SURE YOU DIDN'T GET SOMETHING TRAPED IN THE CUTTING DECK.HOPE THIS HELPED.
Posted on Jun 11, 2009
  • 376 Answers
SOURCE: knob on lawn tractor for blade engagement
Sounds like you need a new PTO switch.
Posted on Jun 15, 2009
bargainbin2
  • 123 Answers
SOURCE: I have a Troy Built lawn tractor, after removing
Clearly the cable either broke, came loose.
Posted on Aug 26, 2009
harlan301
  • 205 Answers
SOURCE: 46" craftsman lawn tractor shuts off when engaging
check the wire from your clutch to were it plugs in. should be on your right side. some have a yellow cover. make sure the wire is not broken. check under your deck and make sure you don't have a large grass build up
Posted on Oct 13, 2009
Pulled the knob to engage blade but blade would not engage.motor stops
possible bent damaged seized shaft, look under deck for excess debris, rope, damaged blades
Jan 28, 2016 | Husqvarna "RZ4621 46"" Briggs And Stratton...
Where is the safety switch to engage the blade
Your lawn tractor will have a lever that raises and lowers the mower deck which houses the two cutting blades. By lowering your mower deck to the desired cutting height, the blades should automatically engage. By raising the deck back to it's highest position, the blades will automatically disengage. Should be simple enough. You can consult your mower manual. If you don't have one, you can easily find it online using the make, model and year of the lawn tractor.
Jul 08, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 56" lawn tractor auto trans dose not drive forward or revers. tryed purging trans no go checked engagment rod ok, belt seems good. I can push the mower by hand as if the trans were not connected...
somehow did the little freewheel lever get pulled in the rear of the tractor to disengage transmission?..usually out is disengage and in is engaged. look around the back panel behind the rear axle for a small lever you can pull or push in.
Aug 18, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Stalls When engaging the blade clutch
Check that the blade brake is disengaging. Slip belt off blade spindles and check that they spin freely. Check underside of deck for clogged grass, ropes, wire, etc.
May 07, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Mower blades willnot engage
make sure the battery is fully charged, check all electrical connections and clean them with vinegar and rinse well with demineralized water afterward.
May 26, 2010 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Oct 13, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 18.5 42'' mower, blades won't engage
You deffinately have a loose wire or connection coming off that switch,youll have to investigate to find out where it is.
Mar 24, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 18.5 briggs/str 42''won't cut
It sounds to me like a very loose belt or very worn out belt and also an adjustment problem.
Garden Logo
208 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
