Question about JVC New Original RM-C1450-NP Remote Control
Search Fixya...REMOTE RM-C1450
Need info on how to find local channels off of an antanna.
  • PAUL YASKULSKI Jul 16, 2013
    I can not locate the scan on the remote.
    Top Expert:
  • JVC Master
  • 12,223 Answers
You must searh in yellow pages Internet, in locals where you are living now.
God bless you
Posted on Jul 17, 2013
Controller RM -C1450 how to turn off caption on screen
Hi, in most cases, all you have to do to toggle the captions on and off is to press the "C.C. / SUB T." button on your RMC1450 remote control.
Oct 27, 2013 | JVC Televison & Video
Need the codes for a chunghop RM-88E remote for an Emerson T.V. Please
Sorry, I couldn't find that particular remote's manual but you could just go out and buy a Universal remote at your local large drug store or electronics store and use its included manual to have it find the codes for your TV and lots of other devices to be controlled by the same remote. It is very simple to do and the device stores each code for you.
Jan 15, 2013 | Televison & Video
How do we change a channel to accept VHF
You can use the remote and push the input button until it shows digital channel. But in order to get VHF you need the access the channel search in menu. You also will need a descent "digital" antenna as the Digital signal is no where near as relaible as analog was. Also older antanna's do not seem to work very well with the digital signal. I recommend an outdoor version because a single wall can interfere with digital signal. If thats not an option get a descent amplified indoor antenna. If you do a channel search without an antenna more than likely you not find any channels.
Dec 14, 2010 | Samsung Televison & Video
The program light blinks all the time. I do not have a remote. I have a convertor box on the tv and an antanna but I keep getting a message saying to check antanna and connections, no sinal. I get a few...
I'm assuming you are getting more than two digital channels into the converter so the problem lies in how the converter is connected to the TV, which I presume is via a coaxial cable, right and you have the TV tuned to analog channel 3 or 4, right?
If that is all true, the RF coax cable solution is not going to work. The few channels you were getting, either side of 3 or 4 is just RF bleed.
Try this, acquire somehow a A/V hookup cable that has 3 RCA male jacks on each end. One cable will have YELLOW ends, This is composite VIDEO. There will be two others colored RED and WHITE (or perhaps black). This is for the AUDIO. The outputs on the converter and the inputs should be colored the same way. Hook the two up, noting which INPUT (1, 2 or 3) on the TV you have plugged into. Not sure of the exact number your TV has. Make sure you change the TV to INPUT whatever. You may also have to re-scan your converter. As long as your antenna is connected correctly gto the converter you should gain a lot more channels. Let me know how you make out.
Nov 24, 2010 | Panasonic PV-DF2735 27 in. TV/VCR/DVD...
Program sony remote to operate dish vip722
The Sony RM-YD029 Remote control will work with the Dish Network VIP722 DVR HD Satellite Receiver, but the Dish Network VIP722's Primary remote address must be set to 1.
The procedure below will allow Sony RM-YD029 remote control to operate Dish VIP722.
Using the Dish Network Remote Control -
1. Press menu 2 times to get to system info page
2. In the system info page the primary remote address is in a white box (bubble) followed by a Green TV (1)symbol that says IR and indicates you the channel your remote control one is configured. The Sony RM-YD029 will work when this primary remote address number (in the white box) is set to 1.
If the Primary Remote Address of your VIP722 Remote control 1 is not set to channel 1, here is how to change it:
1. While displaying the system info page, press and hold the SAT button on your dish network remote until all other modes are flashing, about 3 seconds.
2. then press the '1' button on the numeric pad of your dish remote
3. then press the '#' button on the numeric pad of the dish remote
4. then press the 'record' button (red dot button - stores setting)
5. At this point you should see a number 1 in front of the primary remote address on the dish system info page
Ensure you enter the corresponding IR code into your Sony remote control per the instructions in the manual or Sony's web site. My 722 works with Sony IR code - 01775.
Sep 08, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Need Dish DVR ViP722 remote code.
If you are looking to have the Dish remote operate your TV, just do a random search for your tv. First, hold down the tv button on the dish remote until all the rest of the light up. Next press the tvpower button on the dish remote. Next, press the channel up button (this is the up arrow button) until the set turns off. When it does turn off, press the # key at the bottom right of the remote. The tv button will light and flash twice. That's it. Your done. Hope this helps.
Feb 20, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
How do i tune my philips 3590H philips dvd recorder into digital
The User Manual for your DVD Recorder is available here... http://www.p4c.philips.com/files/d/dvdr3380_05/dvdr3380_05_dfu_eng.pdf
Info related to your specific problem is as follows...
Setting your TV channel
programmes
Before the recorder can start recording
the TV channel programmes, you need to
search for the available TV channels and
store them in the recorder.
Note: Make sure you have successfully
made all the required connections to the
recorder, the TV and Satellite Receiver/
Cable Box (if any) and switched them on.
Tuner settings can only be changed
when there is no disc in the disc tray.
A Press SYSTEM-MENU on the remote
control.
�� The system menu appears on the TV.
B Use ���� keys to highlight
{ System Menu - Channel Setup }
and press ��.
Modify Channel Information
Sort Channels
Channel Search
Edit
Sort
C Use ���� keys to highlight { Channel
Search } and press OK.
�� The automatic TV channel search
starts. This process may take several
minutes. Once complete, the total
number of channels found appears on the
TV.
Automatically scan all the receivable analogue local TV
channels and store these channels on the recorder.
�� Use ���� keys to highlight { Channel Search } and press OK.
�� The automatic TV channel search starts. This process may take
several minutes. Once complete, the total number of channels found
and stored appears on the TV.
Modify Channel Adjust a stored TV channel to your preference, improve the
Information reception and the sound quality of that TV channel.
1) Use ���� keys to highlight { Modify Channel Information } and
press OK.
�� The channel menu appears.
2) Use ���� keys to select one of the options.
{ Name } – You can use the numeric keypad 0-9 to select
the channel preset number which you wish to
change.
– Use ����keys to change alphabet/ number and
use ���� keys to select different entry fi elds, then
press OK to confi rm.
{ Scan Mode } – Select TV channel search mode based on
channel allocation or frequency.
– Use ���� keys to select { Frequency },
{ Channel } or { S-Channel } (Special Channel),
then press OK to confi rm.
{ Frequency } – Shows the frequency of the current TV
channel.
– If required, use ���� keys to start the automatic
frequency search and press OK to confi rm.
{ TV System } – Set the TV system that produces the least
distortion of picture and sound.
– Use ���� keys to select a suitable sound mode,
then press OK to confi rm. (See chapter “TV
System Guide” at the back of this manual for
more information).
{ NICAM } – Turn on or off the digital sound transmission
system which improves the sound quality of the
TV channel.
– Use ���� keys to select { On } or { Off }, then
Dec 12, 2008 | Philips DVDR3380/05 DVD Recorder
No uhf with antannae
UHF channels are basically "line of sight" type signals. You need to be pretty near those UHF stations.
You need a Uhf or combination Uhf/ Vhf antenna to receive them - - Usually an out-door type.
Your TV needs to be set in the "antenna" mode to tune beyond channel 13 "air type" channels. Channel 14 is the first UHF channel if you're in the antenna mode. If you're in the "Cable" mode then channel 14 is a cable channel which is operating at a different frequency from UHF.
I hope this will help you!
Stargazer
Mar 21, 2008 | Orion STV2763 27" TV
Sharp television without remote
should be able to go through on the tv unit itself to auto search the channels, i've done in numerous times for friends in dorms who lose their remotes or don't know how to reprogram for the new cable channels. it should be on the tv by the channels and volume buttons.
Oct 09, 2007 | Sony RM-Y133 Remote Control
JVC New Original RM-C1450-NP Remote Control Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
