Question about HP DeskJet Office Equipment & Supplies
Cartridge chip reset - DeskJet HP Office Equipment & Supplies
  • 193 Answers
Ribbonjet tech
Posted on Jul 16, 2013
How do I reset my Epson T200XL ink cartridges?
Resetting the Epson Ink Cartridge Chip With Software A freeware program called SSC Service Utility enables users to download and install software that helps to manage their Epson printer. The software offers several functions, one of which is resetting the ink cartridge chip. Other settings allow users to freeze the internal ink counters or to reset the internal ink counters. It supports over 100 Epson printer models, but some printers may not respond to the commands from the software.
Using a Cartridge Reset Tool A cartridge reset tool is a small plastic piece that fits against the cartridge. The contacts on the reset tool correspond to the contacts on the printer's ink cartridge. When connected to the ink cartridge, the cartridge reset tool indicates the resetting of the ink cartridge with a green LED light. The reset tool is beneficial not just for resetting the chip, but also for allowing the printer to use all of the ink in the cartridge.
Troubleshooting Issues With the Reset Tool
Buyers should be sure to check the description for each reset tool carefully to determine whether they can reset their Epson printer cartridge with the tool. If the wrong cartridge is attempted or the reset tool is simply unable to reset the cartridge, users see either a red LED light or no light at all. In some cases, they simply cannot reset the chip any further. Before disposing of a reset tool, always test it on multiple ink cartridges.
Apr 07, 2016 | Epson Office Equipment & Supplies
How do I reset the chip on my ink cartridge for a epson wf 2540?
You're better off buying the auto reset replacement cartridges. Word of warning: Epson printers "SPY" on you and tell you that by putting in the compatibles, you will void their warranty. Second Warning: DO NOT download any Epson firmware upgrades because they will wipe the compatible chips and render them unusable. Always keep your old, used epson cartridges in case you need to reset the printer with the original chips.
Feb 14, 2015 | Epson WorkForce WF-2540 All-in-One Inkjet...
How to reset expired hp 02 cartridge
I'm not sure what you mean by "reset" and whether you are speaking of ink jet or laser cartridges. From my experience all HP laser cartridges have a small chip (with a little circuitry) that counts down your pages and when it decides your cartridge is out of toner you cannot "reset" that chip, you can only replace it, so like when you refill the cartridge. Some of the HP laser printers let you override these toner level chips (my HP 1518ni does) but in many laser printers you are stuck when the chip counts down to '0' pages. Some printers will run if you remove the chip from the cartridge but from my experience most will not.
Ink jet cartridges are somewhat similar but I gave up on ink jet printers several years ago. I know for some brands (Epson?) you can buy a small tool that somehow resets the cartridge chip (so if you refill cartridges yourself); possibly there is something similar for HP ink jet cartridges.
Feb 13, 2015 | HP Office Equipment & Supplies
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
Reset cartridge chip
Unlike Epson printers, Kodak cartridge chips cannot be reset. Replacement cartridge chips are available for about $4.00 each. Do a Google search for them to find out where they are available. The replacement chips will allow you to refill your cartridges and the printer recognize them as full.
Hope that helps,
Bax
Nov 05, 2013 | Kodak Office Equipment & Supplies
How to reset printer canon 8180
1.Attain an ink cartridge chip resetting device from a computer electronics retail store or an online retailer. These portable devices resets the cartridge chip so your printer recognizes the cartridge as being full.
2.Remove the cartridge from the printer by opening the top tray and taking the cartridge out of the carrier holder.
3.Line up the pins on the resetting device and the chip on the ink cartridge, then connect them together, making sure the connection is firm.
4.Hold the resetting device and ink cartridge chip in place, for about 10 seconds, until the LED light on the device turns green. This means the cartridge was successfully reset. Afterward, remove the device from the cartridge.
5.Place the cartridge back in the printer's ink cartridge carrier holder and print a test page.
Dec 18, 2010 | Canon imageCLASS MF8450c Color Laser...
I need to reset the cartridge chip gx3000
how to reset the chip in ricoh gx3000colour printer
Jun 16, 2010 | Ricoh Aficio GX3050 GelSprinter
Thinkjet ink cartridges rejected by epson dx7400 - no matter how many times I try using my chip resetter, which normally works and lets the printer use the remaining ink in the cartridge.
The Epson 69 cartridges have two chips. One on the exterior of the cartridge and one just underneath. You can reset the outer chip before the cartridge is less than 25% full. If it drops below this amount of ink before being reset, the internal chip kills the outer chip. You will need to get a new cartridge or a new chip if this happens.
Dec 19, 2009 | Office Equipment & Supplies
Continuous ink supply system for epson r285. Printer will not recognise the cartridges as full. have used the reset button on the cartridge but still no luck. any ideas?
Resetting the Epson Ink Monitoring System -
Even though the CFS maintains a constant level of ink in the cartridges, the Epson monitoring system will signal that the cartridges are empty after a cartridge full of ink has been used. This ink level information is stored on the Intelligent cartridge chip. These cartridge chips have to be reset with out lifting the cartridges. This is done with Inksupply.com Auto Reset Chips. On older Epson printers, before the Intelligent cartridge, it is done mechanically by removing and re-inserting the Inksupply.com switch activators. CFS cartridges must be reset without lifting them.
Previous Reset Methods -
The resetting methods have evolved over the past couple of years. First the Swedish Reset method was used, then the Equalizer Program, then the F-16 Chip Resetter, and now the Auto Reset Chips.
Hope this helps you. Good luck!
Oct 23, 2008 | Office Equipment & Supplies
Epsom stylus CX4700 won't print - new ink cartridges installed
They cut costs on Epson compatible cartridges by using low quality ink and chips or not resetting the chips at all. Sounds like you got cartridges that the chips were not reset on so your printer thinks all the cartridges are empty. I own a Cartridge World ink refilling store and I would never recommend purchasing compatible Epson cartridges from anyone. I would buy refills of Epson brand cartridges and make sure the seller reset the chips.
Oct 18, 2008 | Epson Premium Compatible** Inkjet...
18 people viewed this question
Seeker5211
Seeker5211
