Question about Baby Gear
Easylife sport buggy instructions
Are there instructions available dor folding an Easylife Sport buggy?
SOURCE: how do I fold my Zooper Sport?
OK, I finally figured out how to fold & unfold this ******!
To fold: Stand behind your stroller. Go to the joint in the middle of the push handle. You have to simultaneously push up on the button underneath the joint and pull back on the little trigger at the front of the joint. I've found that this will require both hands. Doing this will unlatch the joint, and you now need to push it forward to fold the handle into a "V" shape. Now look down to the crossbars just above the rear wheels, and you'll see a handle (kind of like on a sutcase) above a sort-of triangular-shaped piece of plastic. Lifting up on either of these will collapse the frame the rest of the way. Push the rear wheels as far forward (toward the front wheels) as you can, and it will latch shut. If you swivel the front wheels around to the rear, the stroller will stand on its own
To unfold: From above and behind your folded stroller, with it standing on its front wheels (as described above), place both of your hands on the side/corner joints of the rear push bar. From the top, run both of your thumbs down the back side of both rails. Your thumbs should hit a 'bump', then a slightly smaller 'bump' immediately underneath the first. That second 'bump' on each side is the latch that keeps your stroller folded. Squeeze both the latches on each side with your thumbs, and you should hear them unlatch. Now the frame is free, and you have to push down on the suitcase handle in the middle while lifting up on the center joint of the push bar. Pull back on the push bar until it latches, and then keep pushing down on the suitcase handle until the whole thing latches.
Posted on Jun 14, 2008
SOURCE: instructions required to fold britax verso buggy
I have the User Guide, I can photocopy and post to you if still required?
Posted on Oct 24, 2008
  • 91 Answers
SOURCE: i cant fold my maclaren twin buggy!
I will try to explain this best I can without actually having it in front of me. First off, start on one side or the other, doesnt matter which, take the top of your foot and pull up on the metal supports on the bottom of the back side of teh seat. You want to pull up in the center, under where the plastic "step" looking piece is. repeat this on the other side. Then you will push down on the littel lever that sticks out of the right side of the buggy. This releases the lock. Usually, you will then have to pull up again with your foot in the same place as before and push the handles of the stroller forward. The buggy should collapse. You may try some 3-in-1 oil, silicone spray or Pledge furniture pilish on the lever and "joints" to make it fold a little more smoothly.
Posted on Apr 10, 2009
SOURCE: How do you collapse the maclaren quest sport buggy
lift the black bit on the back at the bottom with your foot, and press the black handle that sticks out on the right hand side down,
Posted on Aug 25, 2009
SOURCE: I have a safety 1st
Up on the handle. Slide and squeeze and then push forward and down.
Posted on Oct 19, 2010
I am a grandmother left with the lovely grandchild and an in-line Phil & Teds buggy that I have no idea how to open. It's a black one if that helps identify the model.
If you have the Sport or Explorer model, then if you stand the folded chassis upright, so that the handle is touching/near the floor, and front wheel facing away from you, on the right hand side (the joint where the chassis folds) there is a light grey button which you press in, then pull the front wheel outward and lift the handle bar up, this should get the chassis open. Ensure that the chassis makes an auible 'click' when opened, that way you know it's up properly.
Hope this helps.
May 27, 2011 | PHIL & TEDS SPORT BUGGY Jogger
I cannot unfold my Phil adn Teds Sport
Take off the front wheel, this allows the buggy to fold a bit tighter and lock. You now should be able to push the grey button to unlock it.
Aug 11, 2009 | Regal Lager Phil & Teds Sport Buggy Double...
I cant unfold it, have never had a problem before.
Are you sure you don't just have the two little straps on the side locked on?
Jun 14, 2009 | Regal Lager Phil & Teds Sport Buggy Double...
A screw is missing from my maclaren buggy
hi,
I had this problem and just went to my local diy shop and they sold me a nut, bolt and washer. You just need to make sure it'll fit in the hole. Cost me 15p!
May 22, 2009 | Maclaren Quest sport - Placid Blue...
Baby Gear Logo
70 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
