Is there some one that can help me solve a refrigeration problem?
The freezer accumulates ice on floor then melts onto the fridge
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Computers & ... Master
  • 102,366 Answers
What make and model freezer?
Posted on Jul 16, 2013
Freezer has ice on floor
if there's ice on the freezer floor it's usually caused by a blocked drain,when the fridge goes into defrost a heater comes on and melts the ice off of the evaporator coil,under the coil there's a drain,this can get blocked,the water can't drain into the drain tube and the water leaks onto the freezer floor,next time send the brand name and model number.some machines newer bottom mount freezers you have to change the drain tube,if it's an older fridge this happens,you have to melt out the drain and clear the tube,i use a steamer to do this but you have to shut the fridge down,get at the drain melt it out with hair dryer then you can try a turkey baster to push water through the drain hose and see if it clears,sometimes you might have to remove the back bottom panel,find the drain tube and snake a plastic wire tie up into it to clear the junk in there.hope this helps.
Dec 05, 2017 | Refrigerators
Whirlpool refrigerator--water freezing in floor of bottom freezer then leaking onto floor
whirlpool bottom freezers with ice forming on the freezer floor is nothing new. It is formed most likely by an ongoing issue with the design of the defrost drain becoming clogged and there is a revised kit for it part# W10619951.
Whirlpool has extended the warranty of this issue only to two years from the date of purchase and will usually give you the part but charge for install.
It can be put in in less then 10minutes using just a 1/4" hex bit and a small flat blade screwdriver to release the clip on the old "slide" style drain.
Once installed,it is best to defrost the fridge for at least 24 hours (doors open and unplugged) to make sure all ice is melted from inside the unit.
If your drawer was not closing,you would have frost.. If your defrost timer (which virtually no newer units have since digital controls are the norm with adaptive defrost) then you would have frost,not ice.
The fact that you have water is telling me it is defrosting and re freezing.
List a model# for further support if needed please
Feb 08, 2018 | Whirlpool Refrigerators
Fridge ice accumulation inside and water dripping outside
Hi, Are you getting ice build up in the freezer side as well? There is a air shuttle between the fresh food side and the freezer side. thwater might be getting in the freshfood side from there. Look at the bottom rear panel in the freezer for ice build up. Ig=f there is ice, you will need to get to the drain from inside the freezer and check for blockage.
Please let me know if I can help you further.
Vic
May 10, 2009 | Refrigerators
Water runs out of freezer door overnight ,at times
Have a look at this link:
http://forum.appliancepartspros.com/refrigerator-freezer-repair/7670-leaks-water-floor-front-freezer.html
or this one:
http://www.ehow.com/video_112132_fix-leaking-refrigerator.html
Apr 17, 2009 | Westinghouse Refrigerators
Water accumulating in bottom of freezer and leaking onto floor
Yes the drain is clogged and the water that supouse to go through became ice so it make it worse.Put hot water in the drain hole until it runs through,it'll go to an evaporative pan on top of the compresor to keep it warm and vaporize the water.
Apr 04, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
Water accumulating in top shelf of refrigerator
Get yourself a thermeter and see what the tempeature is in the freezer. It should be "0" degrees or colder. If it is hanging around 30 degrees +/- you may have a compressor or control problem. You may have a drain tube clogged that takes the water out of the freezer. I am not familar with your model but many freezers are similar.
Mar 15, 2009 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Water leak front left corner of freezer.
Your defrost drain line in the freezer is frozen closed.
You must turn off the fridge.
Remove the visible ice.
Use a hair dryer at the drain opening in the lower back of the freezer to melt the drain line ice.
Mar 11, 2009 | Electrolux Refrigerators
Ice forming on freezer
The drain is plugged. This fridge will defrost every 8 hrs or so. When it does , it will melt the frost that has built up on the evaporator. This melted frost will run down a drain under the evaporator to a drain in the bottom directly under the evaporator. When the drain gets plugged the water cannot drain out of the freezer compartment. After several defrost cycles the melted frost will overflow onto the freezer floor. When the fridge starts back up it will freez this water is the bottom of the fridge. sometimes this water that is now ice will melt on the next defrost cycle and actually run out into the floor. You will have to unplug the fridge or turn it off, then remove the cover to the evaporator. Get a hair dryer and melt the ice aruond the evaporator and drain. Once the ice is removed, check the drain and try to clear it. Once clear, replace everything but the shelves. Plug the fridge back in or turn it back on. Observe and listen for the evaporator fan. It should be running now. When working on the ice on the evaporator always be carefull. The defrost heater can be damaged if up push or pull on it too much.
Nov 15, 2008 | Samsung RF265AA Bottom Freezer French Door...
Our Whirlpool top freezer unit is leaking water into the refrigerator. The model number is ET21NKXGW01 and at the top of the inside of the fridge, water is draining out into the fridge. The defrosting...
We were able to fix the freezer water leak. We unscrewed the false freezer floor and the inside back panel. Ice had accumulated on the freezer floor and the defrosting drain was frozen. We removed the ice by using a blow dryer then poured boiling hot water onto the frozen drain hole. The frozen water in the drain pipe hole eventually melted and the water released into the defrosting drip pan at the bottom of the refrigerator. Problem solved. We no longer have water leaking into the refrigerator.
Aug 05, 2008 | Refrigerators
Computers & Internet Logo
David Payne
David Payne
