Question about Vehicle Parts & Accessories
I can't drive the car a mile and it's still running hot. Please can someone help me
  • Vehicle Part... Master
  • 3,799 Answers
You should drain and flush your radiator then follow the instructions in the Manual when you refill (with Coolant not plain water) And make sure you have the heater turned all the way up. Fan off and AC off. It would seem as if you may have an airlock in the system. You may be able to cure this by bleeding the system, but as you don't say what make and model your car is I can't be more specific.
Posted on Jul 16, 2013
  • 1 more comment
  • shalondra flowers Jul 17, 2013
    2001 mercury grand marquis
  • Michael Green Jul 24, 2013
    There is another possibility, you may ahave a failed head gasket. A garage can test for this by diping the radiator header tank. A good sign of head gasket failure is a creamy substance on the oil filler cap- this is an emulsion of oil and water. head gasket failure can cause overheating due to the combustion gasses heating the coolant.
    Problem Solver:
  • 7 Answers
Lets start with the easiest most obvious to rule out first. 1. make sure you dont have a leak in the radiator,its hoses, heater core or any were in the system that may becausing you to lose coolent. 2. check and see if the themometer located in the system is working to make sure its opening as needed. these 2 things make up for about 65% of vehicles running hot or over heating, and are the easiest to check and cheapest to fix. be very careful not to be fooled into unneeded repairs by a so called car professional. check around town and see who the locals recommend id ask about 10 to 15 different people and see who the reccommend and have my vehicle brought there. are possibly if your mechanically inc. you can get the information on how to do the work yourself depending on your vehicle
Posted on Sep 17, 2013
  • irelandnut Nov 21, 2013
    thermostat is stuck take it out and try
I have nissan maxima 2000se is overheating ..i drive 60 mile after i saw the car runs hot and smoke too much..i stop and i call repair car...when his came he open radiator and he put water ( radiator is...
I fail to see why you tried to ruin the motor
& may have succeeded
Drive 60 miles AFTER it overheats
Then drive 3 weeks without wondering about
the overheating issue
Someone should take the car away from you
Stupid & then tell the whole world on the internet
Sep 01, 2013 | 2000 Nissan Maxima
My 93 lexus ls400 keep turning off ever since i had a tuneup done. I notice that the ac condenser fan is not working but i dont run the ac.It doesn't read that it gets hot But it seem if the car g
Be sure you check engine oil level often. The low oil sensor will disable the ignition. If you turn A/C on the cooling fan should run continuous, Check the fan relays. Make sure coolant level is correct at recovery bottle, never open radiator cap. A scald hazard exist, be careful. This car is old and complicated, and is beyond your skill level to repair. Try to inquire here for advice, whenever possible. Don't throw good money at bad money
May 27, 2017 | 1991 Lexus LS 400
Zafira 1.6 petrol 4 injectors open when hot
I woud suspect if it is all 4 it is an open circuit in the wireing. When faulting & won't go follow the injector wireing back from the injectors & slightly bend the wireing harness while someone is cranking the vehicle. Pay particular attention to where the harness runs near the exhaust (if it does) & check for any melted parts of the loom or conecting plugs. Also disconnect the loom at the 1st place along the loom & look at the connector for anything unusual.
Jul 01, 2012 | 2006 Opel Zafira 1.6
Engine shuts down after driving about 20 miles let cool down for 10 min. and it will go again
You didn't say whether or not the car is running hot so I'm guessing here. If it is running hot then the temp switch could shut it down for obvious reasons. So could the oil pressure switch. The oil pressure switch will shut your engine down if the oil pressure drops below a certain point. This is caused by lack of oil pressure. Lack of oil pressure can be caused by low oil level, weak oil pump or oil too thin to lubricate. If the engine is running hot that can thin out the oil to the point of no use to the engine. If you have a high mileage engine and are still using 5W30, 10W30 oil then try upgrading to 10W40, 15W40 or even 20W50.
Your engine could be running lean which would create a hot situation that would cool fairly quickly. If this isn't adressed you can look at catastrophic engine failure in your future.
You could also be looking at an internal problem such as warped heads, bad head gasket, worn out oil pump.
If it was my car, I would be taking to someone to find out the exact reason it is doing this. I would likely take it home and fix it myself but I think you should have a professional diagnose this more accurately. Hope this helps.
Oct 29, 2011 | Cars & Trucks
Hi, It's me again, the 97 Crown Vic. I understand exactly what you're saying and will have someone look under my car ASAP. The one thing that I just don't get is.... even when it's not...
Your car has a temperature senser and as soon as the temperature is above a certain level the engine fails as a way of safety. its a safety control switch . First start the engine when it is cool and then check the performance of the fan. Is the generating enough air to cool the engine.as it is running check the temperature gauge i the car and see the level . It could be the fan not providing enough air cool the engine.
Jul 20, 2011 | Ford Crown Victoria Cars & Trucks
1998 Ford Expedition 5.4 liter engine. Can someone please help me with this issue. Whenever I drive my truck it will not run hot, but if I turn on the A/C and drive for about 20mins. The truck will run...
Sounds like your temperature sensor has gone bad. It's not an easy fix by any means, and that should only be done by a professional mechanic. Hope this helps.
Jun 23, 2011 | 1998 Ford Expedition
Vehicle Parts & Accessories Logo
375 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
