Question about Windchaser Outdoor Misting Fan WC161 Stand (Pedestal)
Someone knocked the fan over and bronxe cowling(cover) broke. Can I order replacement?
Can a pull cord be replaced on a briggs & stratton 2300 psi gas pressure washer
yes take the top cowling cover off that houses the pull start normaly 4 to 6 bolts around the lower edge of this & you can pick this cord up from most diy stores or tool rentle firms just be carefull when the cowling is off that the cord spool/pully will most likely be under spring pressure unless the cord as broken completley hope this helps
Aug 16, 2014 | Garden
How to remove the glove box from a 2006 porsche cayenne
Replacing the fan doesn't take many tools, just skill. The fan is under the passenger side dashboard. Remove the cover that is held in with a T25 screw. After removing the screw pry the cover down. Disconnect the light from the cover. Remove the foot vent under the dashboard by pulling it down. Using a 5.5mm socket remove the screws holding in the blower fan. Removing the fan can be very difficult because the main wire harness goes under one edge of the fan. When you get the fan out check it for water damage. When installing the new fan make sure it slides into the channel in the hva/c box. Working around the wire harness can be frustrating. After reassembling check that the fan works. There are 4 places water can leak into the fan. The hva/c water drain can be plugged. The wiper cowl cover at the base of the windshield can be unclipped from the windshield. And one of the two wiper cowl water drains can be plugged.
May 25, 2014 | 2004 Porsche Cayenne
How to replace the ac blower fan on a 2006 cayenne?
normally the armature of the fan is supported by phosphor bronze bushes that are self lubricating. However if there has been water present then the bushes dry out and make a noise or seize up . If you are mechanically minded and you can get to the motor ,pull it apart and lubricate the bushes with sewing machine oil . If not replace it with one from the wreckers .
May 24, 2014 | 2004 Porsche Cayenne
1998 Audi A4 Quattro, 2.8L, AHA, 75K miles, bought...
im a tech in the bronx and i dealt with the same code for the misfire. burt i realized that there wasnt any power to the coil of #2 cylinder. I replaced the sensor mounted on top of the air filter box, which solved this problem.
May 20, 2010 | Cars & Trucks
WIPER LINKAGE BROKEN OR DISCONNECTED HELP
had the same problem on my 97. your going to have to take off the cowl covers. to do that youll have to remove your wiper arms.
where the arms connect to the car there should be a little circle centercap looking thing, that just pops off with a flathead screw driver. theres a bolt behind that, match it up with the correct socket and remove that. put the arms in the up position as if your cleaning your windsheild, this releases the tension of the arms on the shaft there sitting on. then simply wiggle them loose until they come off.
the cowl covers are the black covers between the back of the hood and the windshield, there should be a few plastic rivets holding them in place, drill those out which is very simple doesnt take a strong drill, then remove the weather strip from the base of them underneath the hood which will just pull out, then remove the covers and youll be able to see the motor and all linkages. mine broke where the motor connects to the links in the middle. get the part from the dealer not a wrecker, reason being is that these cars had a recall on them for a bad seal, what happens is that water gets in the balljoint like seal forces the grease out and causes the links to seperate. the dealer has the corrected parts the wrecker may not. vice grip needle nose pliers work best for attaching the links, then install everything the reverse of removal, youll also need to get replacement plastic rivets for those cowl covers its cheaper to get those from car quest should only cost you 2 bucks. best of luck, takes about 1 1/2 hrs to do depening on where the link broke.
if the links arent broke your motor is probably bad.
Oct 10, 2009 | 1998 Nissan Sentra
Replace valve cover gasket
I have the same problem on a 2003 Town & Country. The cover for the front 3 cylinders is quite straight forward, but in order to do the rear cylinders I believe you are going to have to remove the cowling below the windshield. You will need a gear puller to remover the windshield wipers first, then remove the cowling. Than should give you more room to work. It's still not going to be easy, but it sure beats paying hundreds of $$$$ in labor charges.
Apr 18, 2009 | 2003 Dodge Caravan
Need a T-mobile unlock code for CECT P888
There is no unlock code and you don´t need one. This is a triband phone, which does not work on 850Mhz frequency. So obviously this is the case in the bronx...
Oct 21, 2008 | Dual Electronics CECT P168 Cellular Phone
Windchaser Outdoor Misting Fan WC161 Stand (Pedestal) Logo
Top Windchaser Dryers Experts
john h
Vernon Taylor
Are you a Windchaser Dryer Expert? Answer questions, earn points and help others
