Lg WF-T1391TP (Fuzzy Logic)
Good day. This washing machine has all its functions except washing. When on wash cycle, it fills the machine and the electronics believe it is doing its wash cycle, however, the spindle does not move as it is supposed to. I found the belt tension to be a bit loose, adjusted that, but to know avail. Motor runs , but nothing happens.
SOURCE: LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine not spinning
hi...I have an LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine & it's stop when 3-4 second start washing, wash and spin led appear also the buzzer bip contibuosly...any ideas?it's software problem....need advice
Posted on May 22, 2011
  • 5102 Answers
SOURCE: Lost manual to LG washing
I do not know this model. However, on other top load LG washers, the powdered detergent goes in a box at the back (top) of the washer, and the fabric softener when diluted gets poured into a spot near the left side of the top of the washer. (The bleach goes near the front of the washer.) For front-loading washers, the detergent and fabric softener are poured into the detergent drawer. The largest compartment is for detergent (wash cycle) and is usually on the left. The smallest compartment is for fabric softener.
Manuals for most LG appliances are available at their site. Start at http://www.lg.com/au/support/product/support-product-profile.jsp?customerModelCode=WF-T502C&matchedModelCode=NOT_MATCHED&searchEngineModelCode=WF-T502C&initialTab=documents&targetPage=support-product-profile . The manual is in a DjVu format.
A partial manual is also available here: http://monitor.diplo-best.com/review/LG/WF-T502C . You will need to review the washer or enter a code.
I hope this helps.
Posted on Jun 13, 2011
  • 6277 Answers
SOURCE: my washing machine fuzzy logic wf-t1391tp does not
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
(If these actions have not cured the problem, it could be the control board OR the main motor. Motors will show weaknesses when commanded to spin.)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 13, 2011
  • 867 Answers
SOURCE: My LG Fuzzy Logic 5.5kg WF-T552TH machine works fine on small loads, but if I put a large amount of washing it, just runs through water and never starts the wash cycle. Water just passes through.
This is a very common issue and simple to fix, the height of your drain hose is too low, it is siphoning the water out of the machine once the water level gets up near the level of the drain hose.
Posted on Mar 02, 2012
Testimonial: "Thanks heaps. Will give it a try. Not sure if you can help with something else, there is a small leak from the bottom up the back. I have closed the outflow drain as tightly as possible but don't think it is related. Any idea what the leak could be?"
caroldon
  • 17129 Answers
SOURCE: my LG washing washing machine Fuzzy Logic 6.5kg WF-T6560NT won't drain
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged. Now remove the drain hose clamps and remove the drain pump/valve, clean the drain pump/valve, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Posted on Jun 12, 2012
What causes my LG fuzzy logic fully automatic washing machine model WF-T1050TP does not do washing cycle but can spin during spin cycle
it appears the motor's sensors could be going bad on it so the diagnostic computer doesnt know what to do but spin the motor in a spin cycle contact LG for a replacement motor for this washer
Sep 11, 2016 | LG Washing Machines
How do I fix my LG WF-T1391TP top loader washing machine, as water does not flush out after a wash cycle, sometimes after a rinse cycle?
sounds like the drain pump could be clogged up might wanna lay it on its backside and take the motor out and inspect it for any buildup inside of its self as this can/will damage the drain pump however if there is nothing there inside the drain pump then the pump needs replacing
Aug 24, 2016 | LG Washing Machines
Lg fuzzy logic manual wf-t552th
I have an LG WF-T502C T552.
It makes a loud squeal noise on the spin cycle.
I am thinking of replacing the belt. Is it possible it could be the bearings or the transmission?
Dec 24, 2013 | Washing Machines
Lg fuzzy logic wf t652
Front loader? Coins do get into the baffles. They may be riveted on. I would leave it alone, personally.
Dec 01, 2013 | Washing Machines
I have a LG top loader Fuzzy logic 6.5kg model WF-T655th spin cylce not working, the light is flashing. I have a load in the machine, how do I emppty the water out of it. Have misplace the manual.
I have a LG washing machine WTF655TH, it has stopped working, its full of water, but when you push the one button, it trips, how do i get it working again
Jan 16, 2012 | LG Washing Machines
I have a fuzzy logic 8.2kg top loader WF-8071TTP. We had a power failure while the machine was in a washing cycle. Now I start the machine fills with water and when the wash cycle must start it give a DE...
'de' does stand for Door Error. There is likely to be a problem with either the lid/door solenoid/lock or the 'lid/door closed' sensor becoming apparent with the extra movement of washing requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
John C
Jul 13, 2011 | LG Washing Machines
My LG Fuzzy Logic WF-1011STP rotating plate has come loose!
i had this problem last week at a customers house. first buy some thread loctite, then remove screw. put loctite on thread not 2 much, tighten back up. leave over night. should fix problem. please reply if u need more help. good luck
Apr 07, 2010 | LG Washing Machines
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
