Ramsond fc code on ramsond ductless ac model cmvs-25v9a-a27a
2 Suggested Answers
  • 73 Answers
SOURCE: my amcoraire mini split ductless
Support@Pridiom.com
201-266-8234 option 2
Posted on Sep 02, 2011
How close to the ceiling can the inside head be
Hello, try at least, 2 inches, because the interior unit takes air from upside.
Sep 16, 2014 | Ramsond 18,000 BTU 1.5 Ton Ductless Mini...
Leaking water from the inside unit
When the air gets cooled it also gets dehumidified, on the inside unit there should be a condensate drain. Check the drain to see if its clogged, also check to see there is a drain, I have seen units installed by "pros" who have forgot to intall it
Apr 14, 2014 | Ramsond 12,500 BTU 1 Ton Ductless Mini...
Newly installed, the outside unit will not run but the fan on inside will run
checkto see if your getting 24voltsat the condensers control wire and chech for power voltage
Jan 08, 2013 | Ramsond 12,500 BTU 1 Ton Ductless Mini...
Part Board PFC70 (ZB102B9129) shorted out. model # AOM243HX mini split AC component. Where can I get one?
Ramsond has this board in stock. Contact tech support/parts at 866-777-7071
Jun 01, 2011 | Kitchen Ranges
MY RAMSOND MINI SPLIT HIGH PRESSURE LINE IS FROZEN EVERY TIME I TURN THE UNIT ON
The expansion valve or the capillar tubes are inside the condenser and the gas (freon) is already expanded right outside the condensing unit all the way to the evaporator and beacause the diferential of temperature between this copper line (which is not high pressure anymore) and the outdoor air , there's condensention that freezes up.
Oct 15, 2009 | GE Quiet-Aire Ductless Split System Air...
I am concerned the wiring diagram provided for a Ramsond 12000 btu split system 240 volt is wrong. (1 2 3 N L L N) I assumed the L's were slots for the hot legs.
Those terminals on a ductless split are reserved for the communication wires from the out door to indoor unit. L L N should be line 1, line 2, and neutral (ground) there should be a 1 2 3 N terminal block in the indoor unit also, those terminals would most likely be for the communication between the two units.
May 17, 2009 | GE Quiet-Aire Ductless Split System Air...
Ramsond a/c trouble code E7
Indoor/outdoor communication, you can check the connecting cable may have damage.
Dec 17, 2008 | GE Quiet-Aire Ductless Split System Air...
Ramsond split AC 12000
HI YOUR BROBLEM I THINK IS THE SENSOR FOR THE ROOM TEMP
Sep 02, 2008 | GE Quiet-Aire Ductless Split System Air...
Heating & Cooling Logo
65 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
