T con board schematic - Televison & Video
Vertical colored lines on entire screen, sound ok
Hi.
Probably the t con board of your TV is faulty. T con board is the one which drive the lcd pixels. You have to replace the T con board to get it work properly.
Here i have added the picture of the T con board of your tv for reference.also added the video to know how to replace the T con broad.
RCA L32WD22 T-CON BOARD UT-5531T03088-76J
Samsung TV Repair How to Replace Con Board in LJ94 02 705E Model How to...
www.electro-medical.blogspot.com
Sep 09, 2015 | RCA L32WD22 32 in. LCD HDTV
I have LED Vizio TV, it has sound and back light but no picture, how do I fix?
The fault you refer here is normally caused by T'Con board itself. Please check all the voltages comes to that board, from its main power regulator board. Refer some schematic diagrams related to the wiring and voltages of T'Con board. Will get some idea about it. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
If all the voltages to it is correct, and still no video, the display panel should be checked.
Jun 15, 2015 | Vizio E701i-A3
I am getting a green screen with no picture. I have replaced the lamp and still have the green screen
It isn't the lamps. It is in the controller circuit board.
The cost may be more than a new TV. Get a LED or LCD Flat screen.
Jun 08, 2015 | JVC 52" Projection Tv Hd-52g886 Main Power...
How does a T-con Board works?
It is difficult to type in all here by this window, as it is too much. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 18, 2014 | Samsung UE40B7020 40 in. LED TV
VIZIO E472VLE Will not power on.... I have changed the power board and the main board but it will not power on. Does anyone have a schematic for this TV?
First check the inverter boards,if inverter boards is defective,you also could not turn on your tv.
if not you need check main boards,
From Wisiny.com can find those parts,power supply,inverter boards and t-con
Sep 26, 2013 | Vizio 47 E472VL 1080p 120Hz Widescreen LCD...
Vizio sv320xvt mainboard not sending +5 to t-con
The missing +5 seems to me to be a real clue--try to follow it back to mainboard etc---it can be a open or just a processor is not switching it on---impossible to really get a component schematic with voltages etc as they do not want to sell and do not sell discrete parts--if you find it is there Google the internet for that board--seen some on ebay from dropped or junked sets and others elsewhere.
I do not like "replace the board either" but in some cases (which is what the maker wants it is the way the repair work is done now.
over 30 years here in experience from tube type sets to current junk.
Nov 06, 2012 | Vizio SV320XVT 32 in. TV
My 42 inch LG tv keeps going very dark on 1 side of screeen. Any solutions?
This problem is most likely caused by the T-CON board. It could be a bad connection of the cable from the LCD to the T-CON board. or the T-CON board could be bad. Sometimes you can disconnect and reconnect the flat cable(s) to the T-CON board and solve the problem. Else you can replace the T-CON board.
The T-CON board is the board that drives the picture to the LCD screen.
Mar 01, 2011 | LG Televison & Video
Turned on monitor and screen stays white no icons..etc
It sounds like the T-CON board (part of the LCD panel assembly) is not getting 5vdc. Check the power supply and logic bd caps. Check fuse on the T-CON BOARD.
See LCD panel pictures and bad caps:
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Service manuals: http://elektrotanya.com/?q=showresult&megnev=acer&megnev2=al1716&kategoria=monitor&kat2=schematics
May 15, 2010 | Acer AL1716B 17" LCD Monitor
Pico fuse
It's on the T-con board itself at location Cp1 which you will find printed on the board itself.. The fuse is a tiny s/m (surface mount fuse but you can use a pico fuse of same value. According to schematics it's a 1.5a fuse. Simply solder one across the s/m fuse and if it opens then change the board. Samsung p/n# Bn81-01286a
To test the fuse use a VU meter set to continuity.
Pico fuses are readily available at almost any electronics supply outlet. I get mine from ACME Sales in Florida (least expensive) but even your local Radio Shack might sell them...
Bill
Sep 04, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Televison & Video Logo
82 people viewed this question
Top Televison & Video Experts
Electro Med Services...
