Question about OFF Deep Woods Dry Insect Repellent, 4 oz
How do you read or find your expiration date on a can of off deep woods
I have 2 cans of deep woods off. ones is dry the other is plain. I don't know which can is the newest and can't find an expiration date. can you help me?
Where do i find the expiration date on a can of off deep woods spray. I have 2 cans and they both appear new. not sure which one i bought first
There is no expiration date on the product. There is a code on the bottle and if you call SC Johnson at 1-800-494-4855 they will tell you when it was manufactured. They say it has a shelf life of 3 years.
Jul 16, 2013 | OFF Deep Woods Dry Insect Repellent, 4 oz
Need to unblock website
Good Day Ida!
Have you tried checking the date and time setting of your computer lately.
That is the the most common reason for having certificate errors when tries to access sites.
Other than that, its an issue with the website's expired certificate, so don't trust that..
Hope it helps!
Post back if you still have questions.
Don't forget to rate my answer.
Thanks
Sep 29, 2011 | Facebook Social Network
Xml.freecause.com:443 - pop up says certificate is expired but I don't understand what certificate it is referring to. I tried system restore (didn't work); tried removing and reinstalling firefox...
The problem is probably with the site, not your computer. Websites that provide secure connections (as I assume the one you are having problems with does since it specifies port 443) are issued a certificate by a signing authority, such as VeriSign. These certificates are only valid for a limited amount of time, after which they expire. That is why rolling the date back can solve these problems (or cause them). You should contact the web master and get them to update their certificate.
In Windows, you can add an exception for an expired certificate by going to Tools > Options, selecting the Advanced Tab, clicking the View Certificates button, selecting the Server tab, and then clicking the Add Exception Button.
If that sounds like a pain in the ***, its because its not meant to be a casual affair. People shouldn't get in the habit of ignoring security certificate problems.
Sep 25, 2011 | Mozilla Firefox
Am using HP 8750 photosmart printer in east timor.I brought 344 cartridges for 97 which the vendor said its equivalent.How to replace cartridges with 344 for a old 97 cartridge.Settings required to change...
Easiest thing you can do to use old ink cartridges:
Move your system Date back to one year before the
Expiration Date(s) before clicking on [PRINT]
(Don't forget to reset the time back after your printing
is finished.)
If you need to print the same job multiple times, set
the date back, print to a File (instead of directly to the
printer), reset the date back and use CopyTo Printer
software to send the file(s) to your printer.
Jul 18, 2011 | Office Equipment & Supplies
Slow oil leak from around the kick starter where the shaft comes out
Changing the kick shaft seal is pretty easy, and you might be able to do it without taking the cover off. Remove the kick starter. Get 2 wood screws that will fit in the seal. Drive one wood screw thru the seal, don't go too deep and hit the case underneath. Drive the other screw exactly opposite. Get a pliers in each hand and pull it out. If the screws pull out, move around the seal and try it again.
Grease the inside lip of the new seal before installing. Find a deep well socket close to the same diameter or slightly larger-this will prevent you from drivng it too deep in the case. Install seal over the shaft and using the socket and a rubber hammer, lightly tap it into place flush with the case. Install kick lever and your riding. Good luck!
Jun 14, 2011 | 2006 kawasaki KX 250 F
Hi, I just bought one and wondering how can I know the manufactured date of the cologne? because I need to know when does it expire. thank you.
A good colgne does not expire, but i would not advice to use it after two years. Some things you can do to preserve it better is keeping it ona fresh, dry place, out of the sunlight, and always withs it's cap on.
May 01, 2011 | Jean Paul Gaultier Le Male By Jean Paul...
How can I determine the "shelf life" of a tube of Nuetrogena Ageless Intensives Tone Correcting Serum? Is there a code associated with the LOT # ? LOT 0840L0080
If you use it daily you don't have to worry about expiration date. I would'nt advice to use it after 6 months opened, but even then it would still work. My advice, use it daily until it's finished, keep it in a fresh, dry place and out of sunlight.
Apr 30, 2011 | Aveeno Neutrogena Ageless Intensives Lip...
I installed my deep freeze software in my laptop.now i forgot that password. so really i cant store anything in my laptop.
Hi!
Sorry I was unable to provide you exact help on this one as I don't know the deep freeze version you are using but you may want to try these steps, if it doesn't work out, please coordinate with us with the version of the deep freeze.
For Deep Freeze Enterprise:
  1. Open the Deep Freeze login dialog on the workstation for which you need to generate the OTP.
  2. Write down the Token code which is located at the top of the login dialog.
  3. Open the Deep Freeze Configuration Administrator and click the One-Time Passwords tab or open the Enterprise Console and click on Tools > One Time Password.
  4. Enter the code you recorded into the Token field and click Generate OTP. Another code will appear in the OTP field. The second code is the password for the workstation.
The newly generated One-Time Password can then be used to disable, uninstall, and re-install Deep Freeze with the correct password.
For Deep Freeze evaluations (with no License Key entered):
  1. Restart the computer.
  2. Enter the system BIOS settings.
  3. Advance the clock by at least 60 days and then restart your computer. This will disable the software.
  4. After the system has started, run the Deep Freeze installation program to uninstall Deep Freeze.
  5. After the computer reboots, re-enter the BIOS and reset the clock to the current date. You can then re-install Deep Freeze after restarting.
If you are running a licensed copy of Deep Freeze Standard submit a ticket and we can look into the issue further to see if there are any other options available to assist you.
Or if you may want, you can also back up all your files then reformat the computer. Thanks for reading my suggestions.
Hope this helps even a bit.
Apr 17, 2011 | Computers & Internet
I was just wondering what the expiration date is on your mascara if it is unopened?
Hello Dear
Expiration date on mascara shows that it would may be get dry on this date. if you unopened the mascara for a longer time after the expiration date, you would not be able to use that. or may be it would have a bad effect on your lashes.
regards
(Please donot forget to rate)
Mar 16, 2011 | Tarte Increases Lash Volume By 424%...
OFF Deep Woods Dry Insect Repellent, 4 oz Logo
46 people viewed this question
Top OFF Home Experts
Donni Steen
Tom Chichester
Are you an OFF Home Expert? Answer questions, earn points and help others
