Question about Health & Beauty
Dinamap v100 Error code 0000 after installing a new battery
    Problem Solver:
  • 17 Answers
You have to set the date and time. This is done in the configuration mode. To enter the configuration mode hold down the menu button while pressing the power button for 3 seconds. The menu button cycles through the options the + and - buttons change the setting.
Posted on Jul 26, 2013
Error e-83
Hole in hose or cuff
Sep 08, 2014 | CRITIKON DINAMAP PRO 100 Monitor
Error message on screen that says PO 1.15 V100
The error is likely to be from the satellite as the set model listed does not have that kind of error.
Nov 29, 2012 | RCA P52926 52" Rear Projection Television
My dinamap is showing error 950 when i hit the inflate start button. what is wrong?
HI From a Tech Guy,
Your issue is caused by motor over current.
Check the pump motor assembly under the foam cover.
remove torx screw on top.remove cover that has two nipples.
check inside mesh filter/ dust filter. if black is dust.
spray contact cleaner and blow with air. let dry.becareful not to use slovents may damage blue mushroom check valve.reassemble all.test should be ok.
hope it helps
cheers
Mar 12, 2012 | General Electric Dinamap ProCare Series...
There is a discripincy between dynamap temperature and thermometer readings. Is there an expected % difference between dynampa readings and thermomters?
Hello dear
Thermometer reading is more accurate then dinamap reading.
In dinamap take three reading and then the average of these three are the correct one, But in thermometer the first reading is accurate.
Well in dinamap it shows usually plus minus 5 difference.
Hope the answer will help, do rate it please
Regards
Feb 28, 2011 | Health & Beauty
I keep getting an error code E83 Timeout:Inflation. I need to be checking my sons BP. Is there a trouble shooting i can perform? What do i do?
How old is the cuff? If it has written on it "single use" and you've been using it a while you may have microleaks which means you need a new cuff. Also, check the hose for holes (usually found where the hose splits and connects to the cuff). Last, check the Dinamap to hose connector are the black orings still on the connecting posts?
Critikon/Ge utilizes the oscillitory method for determining NIBP. In other words, it pressurizes the cuff, stabilizes, decreases pressure slightly, stabilizes, etc. so a leak in the cuff or hose won't allow the pressure to stabilize resulting in an E83 error.
Nov 04, 2010 | General Electric Dinamap ProCare Series...
My dinamap is giving me E13 msg. and I have tried replacing cuff, hose and checked all connecters. I have 3 units so have tried the same connectors and hose with cuff on another unit and it works fine....
E13 indicates not enough battery power. Does this error come on when plugged into AC? If so, please check the front of the unit to see if the green charging light is on (seen under mmHG), I bet you it's not illuminated. Check your power cord to power brick connection and the barrell connector to Dinamap connection (one of them is probably loose). If they are seated fine yet no indicator is lit, replace the power cord and if that doesn't solve it then order a new power brick.
Oct 21, 2010 | General Electric Dinamap ProCare Series...
Error code on radio, wont go back to 0000
Try seeking free advice here
ukbookshelf.co.uk
Jun 10, 2010 | Car Audio & Video
Adjust time on a procare 400 dinamap
GE Procare 400 DPC-420N Unit turned off. Hold down Menu button while pressing the On button. Press Menu button several times until see a display to the left of the ?min? on the display area. Use + and ? to set time.
Feb 24, 2010 | General Electric Dinamap ProCare Series...
Ok i have a sony ericsson cellphone and the phone has locked me out i wanna know how to unlock it with a code or a master unlock code
If you haven't changed the default code then 0000 will work, but if you have changed it, then follow these steps;
  • Open this link, select your phone and download the software. (PLEASE CLICK HERE)
  • Follow the onscreen instructions to install the software.
  • Once installed, turn off the mobile and remove the battery. Now reinsert the battery and insert the cable (DCU-60 that comes with the box) while holding the 'c' or '@' button on your mobile.
  • Your computer will detect a new device and install it.
  • Once installed please unplug your mobile, remove the battery. Now reinsert it.
  • Download xs++ from here
  • Extract this file and run XS++.exe
  • In XS++, click Connect.
  • Hold 'C' or '@' key on your phone and then insert the USB cable.
  • u can get some information about your phone when it's connected
  • click or tick GDFS at the bottom.
  • Then click Phone Lock, and reset it to 0000.
  • It will either reset the code to 0000 or will show you the code on right hand side. Note that code.
  • click Settings at the bottom, then Disconnect.
  • unplug the USB cable, remove then reinsert the battery
  • You are done, Enter 0000 or the noted one.
    If I was helpful, Kindly do Rate!
    Regards,
    Waqar.
    Aug 19, 2009 | Sony Ericsson W380i Cellular Phone
    Dinamap ProCare 300 error 'E13' displayed.
    E13 indicates the battery is too low. The reason this occurs when you press 'inflate" is due to the battery being low and the inflation pump requiring more power to start the process. Make sure your green charge light is illuminated when plugged into AC (most likely it isn't). Check your power connections first: power cord to brick connection and barrel connector to Dinamap connection. If you pressed those in and still no charge light, replace the power cord, if still unsuccessful you'll have to buy a new power brick.
    Apr 07, 2009 | General Electric Dinamap ProCare Series...
    Health & Beauty Logo
    141 people viewed this question
    Top Health & Beauty Experts
    Robin Hill
    Robin Hill
    wcdoc1953
    wcdoc1953
    Are you a Health and Beauty Expert? Answer questions, earn points and help others
