Question about Canon Imagerunner 5055 Digital Copier
Error code e000025 0001 on ir 5055 - Canon Imagerunner 5055 Digital Copier
4 Suggested Answers
  • 199 Answers
SOURCE: which one is better to buy IR 5075 or IR 5065
The all above models are same with minor change for speed
You need model as your daily output requirement
All models are heavy duty.
you can select any one for upto 10,000 print or copy per day or for 20,000 & up print/copy select ir 5075
Posted on Jun 15, 2009
  • 62 Answers
SOURCE: jam code 0211 in canon
Clean or replace roller after fusing unit.(heater) Slide out middle section>Lift green handle on left to expose rollers.
Posted on Sep 03, 2010
muleskinner2
  • 270 Answers
SOURCE: canon ir 5055 has an
This is a fixing error code - there is too much temperature difference detected by the thermistors. Mostly a error reset will take care of the problem. You have to get into service mode first. Press the additional function key, then press the 2 & 8 keys at the same time, then the additional function key again. Then copier, function, clear, err, then OK. This clears the error code from the copier. Then power cycle the copier and the copier should be operational. If this doesn't work then you will have to have a technician fix it. DO NOT keep resetting the code. There is something wrong with the copier that needs to be taken care before major damage is done to the copier. Good Luck
Posted on Dec 09, 2010
IR 5065. Where is waste toner receptacle located?
You must empty the toner box and with soft clothes try to clean all the sensor window on used toner box and put it again.
Mar 03, 2016 | Canon Image Runner Toner Black...
I have error sc 00001-01 in my copier canon ir-5055
Check the connector of each thermistor,replace if neccesary.After fixing the problem reset the error in service mode:COPIER<FUNCTION<CLEAR <ERR,and turn machine OFF
Jan 14, 2015 | Canon Office Equipment & Supplies
Error 000400-0100 canon ir 5055
Call the cannon support team (877-690-9305) Help you to resolve the issue
Jan 01, 2014 | Canon CLC 1140 Copier
Canon ir 5055 has an error e000004-0010. how di I fix this?
Dec 08, 2010 | Canon imageRUNNER 5570 Copier
Jam code 0211 in ir 5055
try to clean all rollers and look for any sensor damadges.
... or call service!
Aug 18, 2010 | Canon imageRUNNER 5000 Copier
Jam code 0211 in canon ir 5055
Aug 18, 2010 | Canon ImageRUNNER 1670F Copier
Which one is better to buy IR 5075 or IR 5065
Jun 15, 2009 | Canon imageRUNNER 5000 Copier
Waste toner
to change the waste toner on your IR 5055, stand directly in front of machine and look on the right hand side of it where the power switch is a black button on right hand sdie at the back and you will see 4 screws and a metal plate that will come off the waste toner bottle is in there just empty it out and refit to machine all will work, now on your IRC3170 just undo front door and you will see a clear bottle just undo the black screw and take out the bottle and you will see a couple of little clear windows in the bottle make sure you take them out and clean them before you emtpy the bottle, this is where the machines shines a light through it to tell if the bottle is full or not so make sure you have them clean. refit the bottle and all will be ok
May 26, 2009 | Canon imageRUNNER C3170U Color Copier
VS 5055 has distoration, discoloration, screen not complete.
Do self diagnosis test by pressing input and menu on set at the same time for 5 sec. It should blink a 2 digit code. Remember code and let me know.
Nov 23, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Canon Imagerunner 5055 Digital Copier Logo
175 people viewed this question
old marine
old marine
