My letters on my screen are red and blue and black and I can't read any of them.
    Champion:
  • 247 Answers
Get into the ez main menu on tv and reset the ad9883 sub menu adjust u will need a tech to do this as u need skilled personnel so as not to damage the tv
Posted on Jul 19, 2013
Emerson flat screen won't power off and screen flashes blue ,green, red and black?
Sounds like the main board causing that type of symptom. You can get replacement main boards from www.tvrepairworld.com
Jan 10, 2013 | Televison & Video
Since a week ago, the player doen't want to read bluray discs. It reads the dvds but not the bluray discs.
The DVDs use red light, and the blue rays use blue light, 2 systems. Have you tried a cleaning disc?
Sep 05, 2012 | Sony BDP-S580 3D Blu-ray Disc Player Black
Nozzle check for Printer
take out the colors and see if the black prints. if not you could need a new one.
Sep 02, 2012 | Canon MX700 Office All-In-One InkJet...
51F59A red screen all the time
1. entire grill below front screen must come off (usually held in place by screws in back on either side.)
2. locate and remove inspection plate dead center behind it.
3. Locate small black plastic block with 6 black controls built in; three (look carefully) left to right are focus--DO NOT TOUCH THOSE.
The other three are Screens and will be marked with tiny letters r g b (red, green, blue) and green is always middle.
Locate the red screen (not FOCUS).
With set on adjust red down just slightly(usually less than 1/8 turn.
Since the set will be on TAKE CARE NOT TO TOUCH ANYTHING INSIDE THE SET WHEN YOU DO THIS.
IF YOU HAVE QUESTIONS ASK BEFORE YOU TRY THIS.
Nov 20, 2011 | Hitachi 51F510 51" Rear Projection...
The water is not draining completely out of the dishwasher between cycles
Unplug the motor from the harness and do a resistance check of the motor. Between the grey and red/black wires you should read approx 5 ohms and between the blue and red/black wires you should read approx 3 ohms. This will verify the electrical operation of the motor. If either check reads an open circuit, the motor is bad. Then reverify the voltage between the grey wire and the red/black wire and then between the blue wire and the red/black wire. Do this with the motor disconnected from the harness. You should have 120vac on each reading you take when you put the unit into drain. Make sure the unit is in drain and the door is closed. If you now don't have the voltage, then it's the control
if you checked between grey and red/black i have about 3 ohms and the same between blue and red/black. For the voltage if you have 120 v. between blue and red/black but only 43 v. between grey and red/black. you should replace your control board If you chose to replace it, take a look at the parts breakdown for the door as to what to take apart to get to the control. It isn't as obvious as you would expect. Good Luck
Oct 25, 2011 | Whirlpool Dishwashers
Our shredder is a Kobra 240 ss5. It will turn backward but not forward. The circuit board has a burn on it. Can I order a new circuit board for it?
By now you mave resolved your prob however.... yes you can order replacement PCB's.
The part # is 27.045
Before you just replace the "blown" pcb you should also check the motor; or, when you install the new pcb you will just blow the new pcb also.( if the motor is faulty.)
To check the motor you will need a multi meter.
There are 3 wires...black, red & blue wires. Using black as the common wire measure black to red..this should be approx 6 ohms, the same when you measure black to blue. Between blue and red you should get about 12 ohms. If you get a short on any of these readings then the motor will have to be replaced BEFORE YOU REPLACE THE PCB.
You don't say what country you are in..these readings and the part number are good for the USA &Canada.
The part # will be different if you have the 240 ss5 E/S model.( has a blue light on the panel.)
Hope this helps.
Apr 05, 2011 | Elcoman 240 SS5 Shredder
Words on screen are 3 different colors blue red green, no picture just black screen when changing input and input channel words showing in diff colors
YOU may have two problems, 3 d picture or letters suggests convergence problem, Tell me more, all inputs have no function?
The more you tell me the better I can help.
I am expert with these sets and know them well.
SD TECH
Nov 06, 2010 | Mitsubishi WS-65807 65" Rear Projection...
Samsung Tocco Lite says ''download'' on blank screen
I turned it off, then took the battery out for 5 minutes then put in back in and turned it back on, this should work, however for me it didn't so i turned it off and on again on doing this it went to the normal loading screen
Jan 27, 2010 | Samsung Tocco Ultra Cell Phone
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
